Test/review of AW IMR16340 15C 550mAh (Red) 2016
Official specifications:
  • 550 mAh Capacity
  • Nominal Voltage 3.7V
  • Lowest Discharge Voltage : 2.50V
  • Diameter 16.00mm
  • Length 34.00mm +/- 0.1mm
  • Max. discharge 8A
  • Size for reference CR123A
  • Working temperature –10 to 60 Degree Celsius
CR123 sized LiIon batteries that can deliver a lot of current.
The discharge curves looks very goo, the batteries are rated for 8A and had a perfect curve at 7A, but has trouble at 10A. This looks good.
As usual with these small batteries the discharge is done before I can register much heat on the battery can.
Conclusion
This 16340 battery looks to be a good high current battery.
Notes and links
The batteries was supplied by aw-akku.de for review.
Comparison to other LiIon batteries
Nice one, I can use these in my direct drive EDC. Thanks for testing!
Btw, these are not listed on aw-akku.de atm.
Thanks for the review.
Time to stock up this AW to replace my older protected AW
Anybody know where I can buy these? In Europe preferably.
Thanks.
Try the website I have put in the info box as supplier.
Thank you
