ENEDED
yes
btw: it sucks 9,8 A from my bench power supply @ 4V
Sure seems like it.
But why are they also adding washers to the screws?
if you ground LED- the light is ON in DirectDrive (Turbo) without regulation ;)
Sorry, didn’t think it through… :blush:
Was this thing glued together? Looks like a lot of dirt on both parts of the front like it was.
It might also melt the optic unless it’s glass.
it is for pretect the LED
Hang on
Is it to protect led or manufacture identity?
Lol
Sorry, I'm new here and haven't done this before. How will I know when to order?
FYI, I have seen just the optic for sale (for Manker e14, same thing) on amazon for under $5, so probably even less on BangGood if they stock it.
Re: PVD vs. Flame, pretty sure this is flame. I think it would be difficult (if it's even possible) to achieve such an effect via PVD - plasma vapor deposits are usually (always? maybe?) a single substance or alloy, depositing a single colored layer onto an electrically conductive substance. The thickness is measured in microns, so flaming would be deeper as well, but there is no additional material as in PVD. Think of titanium nitride (TiN) coatings, commonly on motorcycle shock shafts, tooling bits, knives, gun barrels and bolt carriers, etc. - it's a solid gold or grey (titanium carbo-nitride) color usually, or black if it's diamond-like carbon PVD. There are a lot of other colors achieved by altering the substance that gets plasma vaporized, but I've only ever seen one at a time. Masking would leave a much more definite line. Of course I could be completely wrong, however, this is just my experience with it.
also, here is a pic of the inside of my fairly new E14 for comparison with the new astrolux pics: https://scontent-atl3-1.xx.fbcdn.net/t31.0-8/14241560_1010069449118926_8542273863078284397_o.jpg
Dismantling S41S is easier than i thought.
I used a sharp pen knife to scrape off the excess glue around the edge first, then I swapped to 1.5mm straight bit screwdriver to pop out the lens. I approached from the rough surface edges (marked with white arrows in picture) for good grip and to avoid damaging the optics by accident.
Double coil board design.
Freeme, is it possible to measure the lumen output of the xp-g3 version!? :innocent:
Thanks Martin and Freeme!
And good to read you got it in parts easier then you thought Freeme.
Nichia + 18650 extension please
Just google image “rainbow PVD”… you’ll see it is indeed possible. What gives it out is they are too bright to be true. We’ve seen a lot of it lately on ecig stuff.
Manufacturer has confirmed that is indeed heat treatment. Guess we have to take their words for it.
Thanks, its realy a new MCPCB. The opening for the foot of the optic ist too big, that means it can not hold the Optic in place.
Or they have only leaved it white and rotated it 90°.
The heat paste is better as on mine S41 Flashlights.
Was it hard to remove the optic? How do you did it?
Does the parts lego with the S41/E14 from Manker?
… I dont believe that this is a new manufacturer. It was told but I do not believe it.
1 XP-G, Colored, 18650 (colored) extension please
Finally found sometime to update the Interest list. Please check your order again if you have time.
https://docs.google.com/spreadsheets/d/1hBSApUb9CocRHCAxoCvR0qwDiQM14mr-7Mfh1M7Xcbc/pubhtml?widget=true&headers=false
There is no plan for that at the moment. Probably it will be available when there is excess stock.
Will ask for it. SS 18650 tube should be available for sale during pre-order. They are still rushing for colored ones. Will ask final pricing in the morning (China time).
I can't get it light up with A6 tube but I heard it will work with Astrolux S1 tube.
Wait do I see a tail PCB ready for Pilotdog68 famous lighting?
Did I miss this and am I correct there is no little led there?
I have an Bistro driver with bleeder resistor but no tail PCB nice to swap it and use it with that.
Add me to the list.
219B + 18650 tube + gift box
