Hi. I
nterested in the 219B (5000K) heat-treated version. Also the (coloured) 18650 extension tube as well.
Cheers
Enercig IMR18350 700mAh - 14A - 18350 & 18500 - Li-ion - Rechargeable...
Hi. I
Cheers
Put me down for 1 XP-G3 SS and a 18650 extension tube. Thanks!
Can you put me down for 1 xpg3, 18650 extenion tube, heat treated thank you.
Pre-ordered! Thank you for setting all this up!
Expected to stock on October 10 2016
Edit: My apology for wrong pricing $42 $38 for Colored version.
Nichia 219B / CREE XP-G3 / CREE XP-G2
_______________________________
Silver $7 / Colored $9
S41S discussion thread here : https://budgetlightforum.com/t/-/41252
Got one.
Can get 11% off if you use code 10annv11 For the anniversary.
Any idea what the tint for the XP-G3 is going to be?
12% with 10annv12%
The price was so good I had to get a plain SS and a colored SS one, each with a respectively matching extension tube. :smiling_imp:
Edit: It looks like they didn’t intend the coupon to work on the pre-orders. I got charged more via PayPal than it was showing in my cart. It looks like the coupon doesn’t work on them at all now. I got $6.96 off with the coupon (which is 12% off the color SS + the two tubes). In my cart before I started checking it was showing $11.52 off. Oh well…
Ordered
Thanks freeme for the groupbuy and Bruno28 for the tip!
So… I dunno much about the different coatings. I THOUGHT (and I’m probably completely wrong, but wanted to ask) that the colored model was somehow a treatment applied to the stainless steel. However, the listing claims that the material is “Constructed from aero grade aluminum alloy Colored + Copper” on the colored version, with “HAIII military grade hard-anodized” coating. It also lists the weight as 90g without the battery.
When I compare that to the Stainless version, “Material : Constructed from Stainless Steel + Copper” The features list claims:
and also lists the weight as 90g.
I think someone needs to check the listings, because now I’m confused.
I got a silver and coloured too. And I went to try your code and they don’t allow now. It’s been marked as promo and you can’t apply codes to promo.
Yeah, it looks like they caught it right as I was checking out. It worked on the two tubes and the colored SS version, but didn’t on the normal SS as I got $6.96 off. Before I started the checkout process it was showing $11.52 off in my cart.
Ordered Plain SS Nichia + Tube.
Thanks freeme.
Preordered.
Plain G3 + tube
If I am not mistaken the $38 price is public, not just this forum. Also looks like the $38 price is only for the first 500 sold.
Are the 18650 tubes available?
Pre-order placed for
ONE Astrolux S41S - Nichia 219B
and
ONE S41S 18650 Extension Tube Silver
Thanks for setting this up!
I have taken some beam shots for you guys to compare with. I will post it up within half a day time.
Want to see tint / lumen difference between the xpg2 and xpg3 before ordering
Ordered before the price goes up. Now the long wait begins.
Is the Efest 18350 Purple a good battery for this? 10.5 amp discharge.
Yes, it is.
But this one gives the light even higher output (measured):
Here is a cell comparison:
Hi, i think this is a preproduction sample … New ceiling bounce (30 sec.) Efest Purple IMR 1537 Lumens AW IMR 1382 Lumens Tensai/Enerzig IMR 1696 Lumens. That new battery from Tensai is great. Lumens went down much slower. Regards Kenjii
