What did you mod today?
8840 posts / 0 new
vwpieces
vwpieces's picture
Last seen: 4 days 3 hours ago
Another S2+ Triple All soldered stack
Nichia 219C
Fet+1 A6
11A
Was Blue Big Smile
DB Custom
DB Custom's picture
Last seen: 21 hours 42 min ago
First one of the ex-cops light was the Streamlight 20X, a biggish light like a Mag, I probably called it wrong saying Stinger, I’ve found out now the Stinger is smaller. I also have the one that IS a stinger, and replaced the Luxeon K9 or whatever with an XP-G2 S2 0D. Beam wasn’t all that great to begin with, still not with the new emitter, so I did a quick bit of lathe work to seat the unified bezel/reflector a bit deeper… now it’s a nice hot spot with some throw, he should be pleased with it and it didn’t take much on my part to upgrade it.
Finally got the two old Streamlights upgraded, wasn’t as bad as I had thought it might be. lol
ZozzV6
ZozzV6's picture
Last seen: 2 days 41 min ago
Made a lighted tailcap in to my grey S2+ 18350
More info Here
djozz
djozz's picture
Last seen: 33 min 34 sec ago
Wow CRX, those are great mods again. Nice touch with the GITD sheet around the XP-L led Smile
@Chicken Drumstick: I have also a ZB006 around doing nothing because of the cheap build quality. It has a good lens though, one day I will try to make it into something as well.
CRX
CRX's picture
Last seen: 9 min 14 sec ago
Stainless steel Quantum mule with tritium momentary switch, XM-L2 4C on sinkpad, magnetic tail and quantum tunneling composite (QTC) pill.
Moonlight to 1.5A variable.
somnambulism
Last seen: 6 months 22 hours ago
I put some Nichia 219Bs in each of these lights: Jetbeam Jet-1 MK, Thrunite Ti5T, Thrunite Ti.
Here are beamshots, this time in a different order (Thrunite Ti, Thrunite Ti5T, Jetbeam Jet-1 MK). Interesting that the Thrunites have a slightly different color even though their emitters were adjacent units from the same reel.
Here is a before-and-after with the Ti5T (look at the horrible green tint in the before picture! I like it much better now). It’s in the middle of each picture (Left to right: Astrolux A01, Lumintop Tool Ti, Thrunite Ti5T, Olight I3S EOS, Foursevens Preon P1):
And here is a comparison of modded and stock Jet-1 MK:
And a comparison of 1xAA beamshots (Left to right: Jetbeam Jet-1 MK (Nichia 219B 4000K); DQG Tiny AA (XP-G2 4250K); Manker E11 (XP-L ‘NW’); Jetbeam Jet-1 MK (XP-G2); Sunwayman V11R (XM-L))
pilotdog68
pilotdog68's picture
I’ve been working on my X2R. The driver is probably done (we’ll see), but I can’t decide on an emitter. It started with a 90cri XPG3, right now it has a top-bin 3A tint XPG3. I’m not totally happy with either of them, but leaning towards either going back to the 90cri emitter, or trying an XPL HI
-X3-
-X3-'s picture
Last seen: 16 hours 12 min ago
I love what you did there !
Truly imaginative and perfectly executed !
So you use the trit as a pole to press the switch in the tail ? Does it go through a transparent tube ?
"-X3-, is there any place in your house without a flashlight ?"
My Flashlight public album (mods, emitter swaps, eye candy)
My reviews channel (French language, Olight, Thorfire, Sofirn, Lumintop : 60+ lights tested)
My personal channel (including Olight SR mini, S1, S2, S1A and S-mini disassembly)
M4DM4X blog, saves you $$$
MRsDNF
MRsDNF's picture
Last seen: 3 hours 35 min ago
CRX has been on fire lately churning mods out of his flashlight factory. Smile
pilotdog68
What do you think guys, which should I do in my X2R?
1. XP-G3 4500k 90cri – Low Vf for high numbers even on a low battery – In the back of my mind I know it’s 90CRI, even if the tint isn’t great
2. XP-L HI (tint TBD) – Higher lumens from less power – better tint, but not 90cri
-X3-
-X3-'s picture
Do you have any purpose (yes, that’s a real question here LOL )for this light ? Outdoor or Indoor ? To me, that’s the first questions for tint choice Smile
pilotdog68
It will become my all-purpose light when I just need to grab something on the way out the door. Primarily outdoor use.
Regardless, if I did an XP-L HI it would be in the 4000k-4500k range, just depends what I can find. Right now I have a 5A that is a little warmer than I wanted for this light, but I just might use it anyways.
Realistically, am I going to notice any brightness difference between the lower bin XP-G3 at 5-6amps vs the XP-L HI at 4-5amps
DB Custom
DB Custom's picture
MT-G2
Big Smile
giorgoskok
giorgoskok's picture
Last seen: 2 months 4 days ago
I still use my modded Ultrafire Wf-501b as a i-don’t-care-if-i-drop-it and “dirty hands” flashlight .
Uses dedomed xpl v5 3c , and the tint is really close to 5A-5C . You can’t imagine how much i enjoy the tint outdoors Smile
pilotdog68
I think my “perfect” tint would be a 4A or 4D, but they’re just impossible to find.
I have one 5A tint HI at home already, but I was planning on using it in my L2.
I think right now I’ll put the XPG3 90cri back in it and see if a frosted narrow optic cleans up the tint at all. If not, HI it is.
The tint options for HI’s just kind of suck right now. KD has a 4B tint, but I’m worried that might be too green/yellow?
Rufusbduck
Rufusbduck's picture
Last seen: 1 year 3 weeks ago
It will run longer on the XPL hi. Unless there is a tint preference I’d go with that. Or get/make a longer tube and use an XHP-50 3D with a couple 18500’s.
Scott
pilotdog68
Rufusbduck wrote:
… Or get/make a longer tube and use an XHP-50 3D with a couple 18500’s.
I’d rather it be less floody if I can, and I actually plan to use an 18350 tube with it sometimes
I actually just ordered on of the 4B HI’s from KD, so hopefully they aren’t green. I’ll probably put the 4000k XPG3 back in it for now, the “3A” XPG3 is way too cool for me. I’ll probably use it to try a dedoming idea I have.
edit:
just got home, put the 5a XP-L in it aaaaaand… its perfect. No way is this emitter leaving this light. My L2 will just have to wait for the 4b when it get’s here.
djburkes
djburkes's picture
Last seen: 2 years 2 months ago
I gutted an Eagletac M25C2 Turbo (a.k.a. Plunger) and added a fet+1 and a dedomed XM-L2 U4 1A…she throws like a champ!! Here’s a few comparison pics with a sexy beamshot at the end.
EE X6, Olight M3XS-UT Javelot, Convoy L6, Eagletac M25C2 Turbo
Olight M3XS-UT with XP-L HI V2 1A
Eagletac M25C2 Turbo with fet+1 & Dedomed XM-L2 U4 1A
DB Custom
DB Custom's picture
Whoa! < schoolgirl giggles
CRX
CRX's picture
X3 wrote:
CRX wrote:
Stainless steel Quantum mule with tritium momentary switch, XM-L2 4C on sinkpad, magnetic tail and quantum tunneling composite (QTC) pill. Moonlight to 1.5A variable.
I love what you did there ! Truly imaginative and perfectly executed ! So you use the trit as a pole to press the switch in the tail ? Does it go through a transparent tube ?
Thanks, yeah correct on both counts.
Added a split ring attachment button to the Hobi
vwpieces
vwpieces's picture
Second Astrolux SS arrived recently.
Decided to Fix one up. Both are 3B tint
Stock is on the Left, Fixed on the Right
Right one now has the 20mm MCPCB soldered direct to copper head. 20AWG wires to FET. Bypassed both Springs with braided copper.
The yellow Dim spot in the center of the spot is gone. Halo of the spot is also more white. More better now…
topping off batts to test current draw on each.
Flashy Mike
Flashy Mike's picture
Last seen: 17 hours 4 min ago
Convoy L2 with short tube, XP-L V6 1A dedomed, FET+1 and 2x spring bypass: nice beam, narrow spot, 280,000 cd at 6 ampere with Liitokala 5200. Handy thrower …
EasyB
Last seen: 8 hours 7 min ago
Nice result. I think the XPL V6 1A dedomed is the best option right now for output and luminance.
KawiBoy1428
KawiBoy1428's picture
Last seen: 6 hours 59 min ago
Excellent! Thumbs Up How much did it tint shift, about 5700k?
KB1428 “Live Life WOT
Flashy Mike
Don’t know, was my first and only V6 1A, didn’t use it before dedoming. Is a bit greenish now, but still ok. I’ll order more of them.
KawiBoy1428
Gas (chemical) or Hot de-dome?
Flashy Mike
Acetone
DB Custom
DB Custom's picture
Tint doesn’t shift as much doing hot de-dome but it still shifts.
Lot of factors, including freshness of gas, ambient temperature and octane rating. Acetone, seems like that can give more shift than gas but again I’m sure there are variables.
Hot de-doming takes less than a minute and doesn’t stink. Haven’t done one in gas in quite a while now.
KawiBoy1428
Flashy Mike wrote:
Acetone
Thanks for the reply FM! Like it better than a XPG-2 regardless… Thumbs Up
CRX
CRX's picture
UltraFire UF-T1 XM-L2 FET10mm Driver & Momentary Switch
