Spot on, Toykeeper and thank you. The tail cap reads 1.13A (3x7135 instead of 4). I will just solder off the last AMC chip and keep this light as it is. Your software is just too amazing!
Will have a look whether I will adapt it for multi-channel drivers as 3x 7135 is bright enough for my simple EDC lights.
I have a wight PZL driver (wight’s version of the Moonlight Special) and I use a lightly-modded version of blf-a6/cypreus2 on it. I like having more blinkies instead of runtime config options. The interface is more or less as shown in this diagram:
You would need to recalculate the ramp and calibrate the voltage and maybe recalibrate the OTC values too, and it’s possible the two power channels might be swapped… but otherwise it should work.
Mine is in a 8x7135 light with a triple 219B in a one-of-a-kind compact brass 1x18650 host Dale made as a challenge. It only makes 800 lumens, but it’s 800 really nice lumens.
Thanks. So basically manufacturer of Nanjg 105c/105d could easily and for pretty much the same cost produce a version with independent control of 7135 chips? Perhaps this is the route Convoy should take? Considering these drivers are produced specifically for Convoy, as J-Dub74 said?
Compared to pretty much any other brand, all of Convoy’s prices are promo prices. Simon doesn’t mess around with inflated prices so he can offer “deals” on special occasions; he keeps his prices low by default. He doesn’t skimp on parts or quality either; ever since he got into lights he has consistently made top-notch items. Many of BLF’s biggest projects have attempted to deliver Convoy-level quality but most have fallen short. It’s kind of amazing he doesn’t charge more.
Can this new firmware be flashed to existing stock Convoy lights (S2+, M1, C8)? Does it matter if the light was purchased with default 3+5 mode group or some other mode group?
That was basically the whole point of this firmware. Convoy’s driver hardware isn’t changing significantly. So, the ‘new’ drivers are essentially the ‘existing’ drivers with the new firmware flashed to the MCU. Other minor changes include a different color PCB, apparently.
Yes, it is possible. Just flashed another AK47 with it and it works.
The original “default” attiny13 software (3+5) can not be saved/downloaded though, at least not with avrdude on my orangepi.
Yes but, I just want new body with plain old driver and regular price. I know you put significant effort to make all this interesting firmwares and I am sure many people will like them, I thank you You in their name but in my case I will just erase it and burn some of firmwares that I like and use and thats why I am not that fond of idea paying additional fee for “improoved” driver that I would reprogram upon arrival. So, it would be nice to have cheaper option with regular Nanjg 105C/Driver, it can even be blank if they ask me.
I don’t want to stir pots here, I appreciate everyone’s good work, yours and Simons but with this price Convoy is this close -> II to Crelant prices and If you ask me, Crelant has noticable better anodisation, machining, SS elements on tailcaps, SS clip, e-button and tail switch (allows interesting firmware functionalities), driver can be moded also or for $2 I can use Nanjg105 and burn firmware to my needs…
Some may say, buy host only but that option is always least cost efectiv, host + emitter used in stock light + driver used in stock C8 (old fw) costs more than complitely by Simon assembled flashlight with identical components…
On product page it says something like ” don’t keep it in config mode too long, it will wear down memory ”
What does Simon mean by this?
Discount? Come on a lot of work went into this. Just wait for it to show on the bigger sites BG/GB/FT and there is a promo or special deal and points store credit to be used
This small price bump for
New anodization
AR glass
And new firmware
Be happy!
