Great review! Looks like a pretty neat powerbank all in all.
Too bad it doesn’t have type-C output (I need that for fast charging my nexus 6p), otherwise I think it ticks all the boxes that the best power banks come with right now. The DC Input is an added bonus, 2 hours charging is insane for a power bank! The lowest I’ve heard of is around 4-5 hours for power banks charged by Quick charge 2.0/3.0.
A word of warning: the installation is super-tight. I had NKON do the welding but the cells weren’t properly in line so I had to remove the cell sleeves in order for them to fit at all! The nickel strips need to be well aligned and correct length too.
Mine is with the new Plus series hardware revison: higher precision current sampling, new QC controller FP6601Q, new soft buttons, QC port now rated for 5A (lower resistance), new ceramic capacitors & inductors. FW is now updatable through USB - you still need STLink though.
I also got another today and it’s the new version. But the charging is not working. One of the components has snapped off from the pcb. Kind of a tight spot, but I’ll see if I can fix it with a short piece of wire by first removing it altogether.
Nkon asked me 10€ for the welding and it took 6 days before my order was shipped. I just wrote them that I was happy with the welding but I had trouble because the pack was not really flat and glued too - maybe now they will do a better one for you
The install was tricky because the battery pack assembled by Nkon wasn’t properly done. The first problem was the batteries weren’t glued on a flat surface same as member swaan experienced, second problem was the battery tabs were off centre and they were shorting with the aluminium casing. With some dremel work and lots of krapton tape to avoid shorting everything was installed correctly.
My UI is in English, version 2.03.Some flaws/differences I noticed vs the unit maukka reviewed:
-LVP limited to 2.70V
-The resistance meter is hidden in the calibration submenu and still displaying double the true resistance, as mentioned above.
-Compass function doesn’t work, barometer over reads even when calibrated.
-Automatic charge current detection doesn’t work as consistently as I’d like, with the same QC2.0 charger it would choose 12V 1.5/1.75/2.0A randomly, but if I set it to manual it will always draw 2A.
It doesn’t seem to draw past 2A at any QC voltage, whereas the older yzxstudio 7 will draw up to 2.4A 12V or until the battery charge current hits the 4.56A limit.
Hopefully all these bugs or flaws can be fixed with future FW updates, but so far I’m happy with the construction and performance.
I was expecting Mario Bros power on logo, but got Contra instead. Not bad I guess?
Where did you order?
Which model did you buy?
How long was the shipping time from china to your country?
How much did you pay in $ for the Powerbank/shipping/customs?
