That makes me want to cry inside… in my special Angry Place.
All my emitters are on Al MCPCBs, and I really want them on copper now. Feel like back when ceedees came out and I had to rebuy all my fave albums that I already had on vinyl…
That works well on e-switch lights, but not so well on lights where the switch actually cuts power. Every time you touch the switch, it physically removes power then reboots the driver, so inputting multi-press button sequences is rather awkward.
For e-switch lights, I normally do the double-click-for-turbo thing, with a single click to turn off or simply holding the button to adjust brightness. But the hardware in this C8 can’t do that.
Anyway, I agree about the C8 not being an EDC. I’ve tried to carry one, but it’s a bit too large for that. I do sometimes carry a Kronos X6 though, when I expect to need something throwy. It’s just small enough to fit in my purse if I take out my sunglasses case (daytime, carry sunglasses… nighttime, carry a compact thrower )
No. Those are the stars that were going to be used in the new C8 until a week ago.
They’re good copper stars I’m sure, but I asked Simon if he could source good DTP copper stars in time for the release of the clear C8. He did.
As far as I know the DTP boards are not available for sale outside the new C8 yet but knowing Simon it’s quite likely that they will be available soon.
Indeed. Not sure it’ll be feasible to stack chips at the factory though, since it’s a pain to do.
BTW, the numbers I posted earlier with 1000 lumens and 50 kcd lux… those were entirely made up. I don’t have a new C8 yet to actually measure. My XinTD C8 V4 (XM-L2) gets ~900 lm and ~33 kcd lux. I’m guessing the Convoy C8 (XP-L HI) will have similar lumens but significantly more lux.
Wow I go a day without being on here and get back to find a 220 post thread about this new version. I don’t own any Convoy lights yet but this right here is just the ticket. I love the upgrades and the UI. If this UI is incorporated into all of the lights I’m going to have to find new funding for my light budget.
I was thinking the same thing. It would be one of the first, and one of the best drivers and lights of that type. I am sure a lot of people will upgrade the driver in some way.
Amping up a fat XM-L2 will definitely improve lumens output, but it doesn’t make the beam narrower for more throw or higher lux. Sure, the lux numbers will go up some, but not like that. Drop in an XP-G2 and lux jumps. De-dome it and it nearly doubles again. But 147-150Kcd is fairly tough to get even in a C8. To go over that requires a Buck driver and 2 cells with the de-domed XP-G2.
Interesting, thanks. It looks like the actual lumen output on that is 0.14, 1.96, 13.6, 45, 100% instead of 0.1/1/10/35/100.
When I get a sample, I’m planning to test again and maybe send Simon an update with re-adjusted levels. The ones I used initially had weird response curves on the 7135 chips, but it was consistent across multiple drivers. So it’ll be interesting to see if the production units match the devel boards or if they’re closer to your results.
Worst case scenario, the first batch might be a little bit brighter than spec. Not exactly a terrible thing for a flashlight.
Just ask him. No point leaving a specific price number here in a thread people will be reading for years. Stuff changes over time.
And if you ask nicely and are buying other things, and it’s a convenient time, and the sun’s shining over there, your luck may vary.
