New Convoy C8 – Clearly better
This new driver already has 8 chips correct? I don’t think Simon offers chip stacking services, it takes a lot of time and patience…
I certainly think that a stock 12*7135 version would sell well. Approx 100k lux in a stock C8 would be impressive!
That works well on e-switch lights, but not so well on lights where the switch actually cuts power. Every time you touch the switch, it physically removes power then reboots the driver, so inputting multi-press button sequences is rather awkward.
For e-switch lights, I normally do the double-click-for-turbo thing, with a single click to turn off or simply holding the button to adjust brightness. But the hardware in this C8 can’t do that.
Anyway, I agree about the C8 not being an EDC. I’ve tried to carry one, but it’s a bit too large for that. I do sometimes carry a Kronos X6 though, when I expect to need something throwy. It’s just small enough to fit in my purse if I take out my sunglasses case (daytime, carry sunglasses… nighttime, carry a compact thrower :stuck_out_tongue_winking_eye: )
No. Those are the stars that were going to be used in the new C8 until a week ago.
They’re good copper stars I’m sure, but I asked Simon if he could source good DTP copper stars in time for the release of the clear C8. He did. :slight_smile:
As far as I know the DTP boards are not available for sale outside the new C8 yet but knowing Simon it’s quite likely that they will be available soon.
You answered all my possible questions.
Thanks
This is the funniest thing I’ve heard all day! Thank you for sharing your special Angry Place. :smiley: :+1:
Indeed. Not sure it’ll be feasible to stack chips at the factory though, since it’s a pain to do.
BTW, the numbers I posted earlier with 1000 lumens and 50 kcd lux… those were entirely made up. I don’t have a new C8 yet to actually measure. My XinTD C8 V4 (XM-L2) gets ~900 lm and ~33 kcd lux. I’m guessing the Convoy C8 (XP-L HI) will have similar lumens but significantly more lux.
With 5 extra 350mA 7135 chips to an XM-L2 U4 1A it does 4.53A for 1456 lumens in Turbo.
This means that on group 1 it does…
2.07 Lumens
28.64
198.32
661.71
1455.9
Or on level 4 it does…
27.26 Lumens
375.02
1407.6
Or on level 7 it does…
2.24 Lumens
27.53
190.79
693.45
Variations show the cell changing voltage levels during these tests. :wink:
Wow I go a day without being on here and get back to find a 220 post thread about this new version. I don’t own any Convoy lights yet but this right here is just the ticket. I love the upgrades and the UI. If this UI is incorporated into all of the lights I’m going to have to find new funding for my light budget.
I was thinking the same thing. It would be one of the first, and one of the best drivers and lights of that type. I am sure a lot of people will upgrade the driver in some way.
I’ve seen around 65k lux mentioned for a stock 8*7135 Convoy C8 HI in reviews. So theoretically 12*7135 would result in almost 100k.
That’s probably wishful thinking.
Amping up a fat XM-L2 will definitely improve lumens output, but it doesn’t make the beam narrower for more throw or higher lux. Sure, the lux numbers will go up some, but not like that. Drop in an XP-G2 and lux jumps. De-dome it and it nearly doubles again. But 147-150Kcd is fairly tough to get even in a C8. To go over that requires a Buck driver and 2 cells with the de-domed XP-G2. :wink:
EDITED ………
Yay !! yippie !! whee…
Like…… here’s a free Porsche motor …
Good thing RMM is studying to be an attorney …I don’t think it took him this long to figure out what open source meant . :stuck_out_tongue:
I’ve always hated the 2 group driver …whoever thought that a driver that flashes made sense ….clearly wasn’t
Interesting, thanks. It looks like the actual lumen output on that is 0.14, 1.96, 13.6, 45, 100% instead of 0.1/1/10/35/100.
When I get a sample, I’m planning to test again and maybe send Simon an update with re-adjusted levels. The ones I used initially had weird response curves on the 7135 chips, but it was consistent across multiple drivers. So it’ll be interesting to see if the production units match the devel boards or if they’re closer to your results.
Worst case scenario, the first batch might be a little bit brighter than spec. Not exactly a terrible thing for a flashlight. :slight_smile:
Remember the added 5 chips, it bumps the curve. :wink:
Just ask him. No point leaving a specific price number here in a thread people will be reading for years. Stuff changes over time.
And if you ask nicely and are buying other things, and it’s a convenient time, and the sun’s shining over there, your luck may vary.
Can we get a smiley emoticon made with his jaw hanging slack in amazement? (aimed at Boaz)
For us it’s a hobby but for him it’s a business. As such he has every right to charge what he wants and we have every right not to buy.
Speculating on what a fair mark-up is, whatever that means to each of us, is just that.
To avoid translation issues, please let me explain.
When someone puts their money into a business, it’s all about making money to support their family and themselves. Doing favors for the customer can be a good way to do business, of course, and isn’t that what Simon is already doing? Going far and away over the top to bring us clear anodizing, AR Coated lenses, clear button and/or a contrasting black button, and even being open to an updated/upgraded modern firmware, taking a chance on his very clientelle to make this happen? All these changes without a doubt run into expense to implement, on the speculation that it will become profitable for having taken the chance. Right? And still, his lights are bargain priced with high quality easily surpassing all but the most determined of the competition, again, right? Even while developing new models to further appease our hungry appetites? (stay tuned, he IS working on options, as JDub has clearly explained)
Pretty obvious he’s given us his ear, put his monies to work on our requests, and now once again it is our turn… make it pay.
FWIW, I feel no entitlement to compensation for making the new driver code. I’m merely happy to help someone I like, someone who has been consistently good to BLF.
And it was a fun project. I approach lights strictly as an enjoyable hobby, and don’t want it to become “work”.
Just putting that out there, in case it’s relevant.
… though I was admittedly a little grumpy about having to include SOS mode. Silly survivalists. :stuck_out_tongue_winking_eye:
