Sorry, I finally renamed it from bistro-mini to biscotti. It should be there, but it’s under bistro/biscotti instead of bistro/mini.
K, see it. thanx!
Edit: Just got biscotti compiled/linked - prog mem is 1022 bytes .
This is a direct link to the bistro tripledown in ATMEL Studio V7, complete solution/project: https://drive.google.com tripledown AS7.zip
Note: it hasn't been run or tested, just compiled/linked!
This is a direct link to the biscotti in ATMEL Studio V7, complete solution/project: https://drive.google.com biscotti AS7.zip
Every time I try to get into the repository code it gives me a 404 error?
This works for me: https://code.launchpad.net/~toykeeper/flashlight-firmware/trunk
But "browse the code" is broken. Looks like it's down, inaccessible right now.
Yeah, same thing I am experiencing. I was trying to grab the battcheck hex for the tiny25 so I could calibrate the Avenger drivers for the 22k R1. I tried flashing the one I have but get nothing, the driver works fine with bistro.
You mean bistro-tripledown?
Yeah, bistro-tripledown works fine but the battcheck.hex I have does nothing. I am going to try reflashing it and another driver just to be sure.
Ohhh - battcheck probably expects output pins to be in the normal positions, not like on a triple. This is probably why? Let me check if I have the source local.
Or written for a 13A?
Yeah, I am pretty sure it was written for the 13a but I thought there was a tiny25 version of it as I remember using it on an older tripledown with the same pinout as my TA drivers. I didn’t think to keep track of that file though so not sure where it is now.
I got the source for battcheck.c. It uses pin #6 for LED output, so that would be the 7135 bank. It does have support for both 13A and 25/45/85, but it's done at compile time.
Here's the full source:
* This firmware simply helps calibrate values for voltage readings.
* It is not intended to be used as an actual flashlight.
* It will read the voltage, then read out the raw value as a series of
* blinks. It will provide up to three groups of blinks, representing the
* hundreds digit, the tens digit, then the ones. So, for a raw value of 183,
* it would blink once, pause, blink eight times, pause, then blink three times.
* It will then wait longer and re-read the voltage, then repeat.
* NANJG 105C Diagram
* -| |- VCC
* Star 4 -| |- Voltage ADC
* Star 3 -| |- PWM
* GND -| |- Star 2
* CPU speed is 4.8Mhz without the 8x divider when low fuse is 0x75
* define F_CPU 4800000 CPU: 4.8MHz PWM: 9.4kHz ####### use low fuse: 0x75 #######
* /8 PWM: 1.176kHz ####### use low fuse: 0x65 #######
* define F_CPU 9600000 CPU: 9.6MHz PWM: 19kHz ####### use low fuse: 0x7a #######
* /8 PWM: 2.4kHz ####### use low fuse: 0x6a #######
* Above PWM speeds are for phase-correct PWM. This program uses Fast-PWM,
* which when the CPU is 4.8MHz will be 18.75 kHz
* FUSES
* I use these fuse settings
* Low: 0x75
* High: 0xff
* STARS (not used)
// set some hardware-specific values...
// (while configuring this firmware, skip this section)
#if (ATTINY == 13)
#define F_CPU 4800000UL
#define EEPLEN 64
#define DELAY_TWEAK 950
#elif (ATTINY == 25)
#define F_CPU 8000000UL
#define EEPLEN 128
#define DELAY_TWEAK 2000
#else
Hey, you need to define ATTINY.
#endif
* Settings to modify per driver
#define OWN_DELAY // Should we use the built-in delay or our own?
#define BLINK_PWM 10
#ifdef OWN_DELAY
#include <util/delay_basic.h>
// Having own _delay_ms() saves some bytes AND adds possibility to use variables as input
static void _delay_ms(uint16_t n)
while(n-- > 0)
_delay_loop_2(DELAY_TWEAK);
#else
#include <util/delay.h>
#endif
#include <avr/pgmspace.h>
#include <avr/interrupt.h>
#include <avr/wdt.h>
#include <avr/eeprom.h>
#include <avr/sleep.h>
#define STAR2_PIN PB0
#define STAR3_PIN PB4
#define STAR4_PIN PB3
#define PWM_PIN PB1
#define VOLTAGE_PIN PB2
#define ADC_CHANNEL 0x01 // MUX 01 corresponds with PB2
#define ADC_DIDR ADC1D // Digital input disable bit corresponding with PB2
#define ADC_PRSCL 0x06 // clk/64
#define PWM_LVL OCR0B // OCR0B is the output compare register for PB1
inline void ADC_on() {
#if (ATTINY == 13)
ADMUX = (1 << REFS0) | (1 << ADLAR) | ADC_CHANNEL; // 1.1v reference, left-adjust, ADC1/PB2
ADMUX = (1 << REFS1) | (1 << ADLAR) | ADC_CHANNEL; // 1.1v reference, left-adjust, ADC1/PB2
#endif
DIDR0 |= (1 << ADC_DIDR); // disable digital input on ADC pin to reduce power consumption
ADCSRA = (1 << ADEN ) | (1 << ADSC ) | ADC_PRSCL; // enable, start, prescale
inline void ADC_off() {
ADCSRA &= ~(1<<7); //ADC off
uint8_t get_voltage() {
// Start conversion
ADCSRA |= (1 << ADSC);
// Wait for completion
while (ADCSRA & (1 << ADSC));
// See if voltage is lower than what we were looking for
return ADCH;
void noblink() {
PWM_LVL = (BLINK_PWM>>2);
_delay_ms(5);
PWM_LVL = 0;
_delay_ms(200);
void blink() {
PWM_LVL = BLINK_PWM;
_delay_ms(100);
PWM_LVL = 0;
_delay_ms(200);
int main(void)
// Set PWM pin to output
DDRB = (1 << PWM_PIN);
// Set timer to do PWM for correct output pin and set prescaler timing
TCCR0A = 0x21; // phase corrected PWM is 0x21 for PB1, fast-PWM is 0x23
TCCR0B = 0x01; // pre-scaler for timer (1 => 1, 2 => 8, 3 => 64...)
// Turn features on or off as needed
ADC_on();
ACSR |= (1<<7); //AC off
// blink once on receiving power
PWM_LVL = 255;
_delay_ms(5);
PWM_LVL = 0;
uint16_t voltage;
uint8_t i;
voltage = get_voltage();
while(1) {
PWM_LVL = 0;
// get an average of several readings
voltage = 0;
for (i=0; i<8; i++) {
voltage += get_voltage();
_delay_ms(50);
voltage = voltage >> 3;
// hundreds
while (voltage >= 100) {
voltage -= 100;
blink();
_delay_ms(1000);
// tens
if (voltage < 10) {
noblink();
while (voltage >= 10) {
voltage -= 10;
blink();
_delay_ms(1000);
// ones
if (voltage <= 0) {
noblink();
while (voltage > 0) {
voltage -= 1;
blink();
_delay_ms(1000);
// ... and wait a bit for next time
_delay_ms(3000);
Then the one I have should be compiled for the 25 as that is all I have ever used. Odd, I will try it on another driver and see what happens. I generally flash in Linux, maybe my flash command was off as I did it in windows this time, I need to make a batch file for windows flashing to keep everything straight.
Browse the code is now working!
Great, got the 25 version and now it works fine. Not a lot of difference from the 19.1k but enough to need a change.
Ok, just got the voltage calibration for a 22k R1 resistor completed on a Texas Avenger driver. Initial calibration was set with my DPS3012 power supply and I tested it with various batteries at several voltages and everything lined up in the working driver great. So here is the updated 22k R1 calibration file if anyone is interested:
Also here is my latest working revision of Bistro Tripledown, not 100% I am done tweaking it yet but it is pretty close to the end goal I am personally looking for. So far I have found no bugs or issues with it.
I changed the mode groups around some to better fit with the triple channel setup, I also added a 10th mode and removed the fancy flasher in order to allow for a single 7135 and all 7135’s only mode, which I find useful in some lights where the FET is simply not needed. Not sure what other changes there are other then that, kinda forgot at this point lol.
Texas-Avenger-Bistro-Tripledown
Actually I need to edit the C file to add a line for the new 22k calibration file so people can simply comment out one to select what they are using.
Is this calibrated for the otc as well. Or just voltage. Thanks for your work!
The OTC should be the same and appears to work perfectly in my drivers. It is the same 1uf cap that the original calibration was setup for, so I saw no reason to redo it.
The quality of the cap will play a much larger role. For example I find I had to replace all the OTC caps from the A6/X6 drivers as they don’t work right once hot but work fine when replaced with X7R 10% caps.
So the overall answer is yes, it is calibrated for a 1uf OTC cap, just not by me.
Ok, I was looking at an easy way for people to select the 22k calibration by a simple “comment option” but since it appears the calibration file is used in a few places this is not appearing to be the best method.
So what is the best way to allow people to select between 19.1K and 22k? Simply move the The Avenger drivers to the 22k and rename the calibration file accordingly?
Oops, that’s rare. I wonder what happened…
*goes to read the internal chat log*
Huh. Well, that’s fascinating and kind of funny, but unfortunately I can’t really share the details. The short version is: a cascading power outage which took out a bunch of core resources and took a few hours to fix. Probably the longest outage in the company’s history.
Kinda glad it was all fixed before I woke up.
Keep a copy of “tk-calibration.h” for each different set of values you want, and … copy the relevant one over the main one before compiling. Or change the include line so it says #include “texas-ace-22k-calibration.h”
or whatever. The point of putting it in its own file is to make it easy to manage calibrations and firmwares independently.
Usually I just save the calibration data under battcheck/readings/ and re-generate the header values on demand. Or for specific items, I copy the .c file to my-light.c and copy the calibration to my-light-calibration.h in the same directory, and change the include line. That way I can more easily come back a year later to tweak something small and know that nothing else has changed.
or whatever. The point of putting it in its own file is to make it easy to manage calibrations and firmwares independently.Usually I just save the calibration data under battcheck/readings/ and re-generate the header values on demand. Or for specific items, I copy the .c file to my-light.c and copy the calibration to my-light-calibration.h in the same directory, and change the include line. That way I can more easily come back a year later to tweak something small and know that nothing else has changed.
Yeah, thats how I am doing it now. I was hoping to allow an easy way for people that don’t know as much to select which R1 they are using without having to worry about 2 files of the same name floating around with different calibrations.
It is not a big deal, I just like things to be as straight forwards and stupid proof as possible for new people that have never done these kind of things before.
