Liitokala Lii - 500?
Did you order the Lii-500? How do you like it? I have an Nitecore D2 which works fine for charging, but I also want to measure the true capacity of my various batteries, purchased and pulled. So I ordered a Lii-500 yesterday. I bought it from Fast Tech. I had something else I wanted to buy from them so even though it was a couple of dollars more than from others I put in the order. Now I’m wearing down a variety of batteries so I can discharge and charge and measure the capacity.
I haven’t received yet.It is now in the Postage office,and I think I get it tomorrow.
Hope it works as well for you as it has for me. A few important things to temember:
1) + toward display (down)
2) 26650s only fit in slots 1 and 4
3) it can be a bit tricky removing 18650 cells
I have a vc4 and lii-500 and prefer the lii.
I also have the VC4 but I want more 1A slots.
Thank you for the hints. :slight_smile:
temember? I thought I wrote ‘remember’. Aargh… I HATE typos!
Is there a copy/fake of this lii 500 chargers ?
I found one with price of 13$ only.
Perhaps that one comes without power supply. Some sellers do that. Read the fine print carefully.
Wondered about that one myself.
Package List: L0871EU
1 * Battery charger
1 * Power adapter (EU)
1 * Car charger cable
1 * Manual(English & Chinese)
I use this trick to remove the 18650s.I turn the charger upside down,and press the moving metals next to the negative pole ,down.Voila,you have the battery down on your table.
Edit.
Because I saw that the charger got hot,during the discharging -charging cycle of the fast test,I put a 12cm/220V fan below the charger,and there was not any high temperature.
Αξεσουάρ Ψύξης Μικροηλεκτρονικών CY 201 AC FAN SUNON 120X120X38MM 220V SUNON. CosmoMarket.gr .
Where is this deal?
It is in Greece,but I now found one shop in Slovakia as well.SUNON in stock | SOS electronic .
Edit.
You have to know,that there is not a cable ready for this fan,so you have to buy one and fix it.
I ask seller is charger original and genuine Liito Kala not some copy/replica of it, and he confirmed that is original, so I order one for 13$, and we will see when it arrive.
Can you share the order link with us?
I pick up a last one, it is not available more :cry:
Do get back here with detailed pictures! Thanks!
Could you at least tell us where it was?
Is the Liitokala Lii-500 on Aliexpress for $20 likely to be genuine?
I got the Liitokala Lii - 500 from GearBest, so far works great and appears genuine-
That is where I got mine to and my experience has been the same as yours ‘aL1’. :+1:
