Nope I’m out at 100 buck
I’ve just bought a Nitecore EA45S for $40 including shipping, so I can’t see myself buying this light. Shame as it looks nice. I wonder what the regulation is like?
Say what?!? $100 !?
Ah yeah there it is (the monkey is coming out of the sleeve for us Dutchies )
“From 99 for only 49”
Sigh one just got to love Simon who puts a fair price on his lights and that is it.
But OT with another Dutch saying “the soup is not eaten as hot as it is being served”
The price is more inline with Crelant’s XPL-HI version of the 4 AA
If I were purchasing this light, I’m of the opinion that $49 is a tad on the premium side. I guess Thorfire is aligning it’s prices with manufacturers like Nitecore and Olight.
I really like 4AA lights… love my EA41.
Hope this comes into the 30 dollar range. I’d definitely pick one up…
There just aren’t enough budget 4xaa lights out there. Hopefully this settles down to $35 eventually.
I think it is quite reasonable if, and only if, the regulation is good. The current reviews are pretty sketchy being at the “Wow, this is good” level.
Mine is now using 4 alkaline AA cells. They were dirt cheap, €0.65 for 8
Awaiting the Eneloops.
I use it a few times a day for no longer then 5 minutes and first day a bit more, even during the day to see if and how it worked.
So it is used for about 2 hours now and I do not see it get dimmer, the trees at 50 meters are nicely lit and the owl screaming his/hers lungs out at night still chooses another tree much further away when I shine on him/her
Will do actual run test with rechargeable cells as soon as they are in
BUT 1 with the Q8 we work with Thorfire and 2 they send it for free, giving two strikes in terms of objectivity so only if I also would have commercial interests I would be a worse person to “review” it then I am now.
Beat me to it lightx. Also, the Amazon price is down to $45. It’s still not yet listed on the thorfire direct site. I might need to pick up some eneloops.
It was a bit premium at 42.99, but decided to buy. It seemed like the best option in its segment, AA powered high output lights(all 4*AA). No complaints except a very misaligned emitter, worse than I ever saw in a $5 light. Overall this makes me rate it one out of five at that price despite otherwise functioning flawlessly. Embarrassing as any AA light I buy is not for my own personal use.
I don’t know if the code is still active but there was 20% coupon code which had brought the price on Amazon to $32.
1/2 Power NiMH
18 140 355 1055
Why not check the brightness using freshly charged NiMH? I guess either way it shows that the output is still great with depleted batteries.
This light can be bought as ThorFire or Sofirn on AliExpress for around 23 Dollars.
You don’t even get half a DQG ‘fat tiny’ for that.
I think it’s an interesting light for those who don’t want to go Li-Ion.
EDIT II: Well, I have done a few run time tests. To jump to the bottom line here, without a lot of fancy graphs or numbers to clog up this post: Here is the deal: I am disappointed in the result. The issue is not really this light, but the engineering limits of 4x NiMH. It is just yesterdays technology, and there is no getting around that. Watching this light run for 4 hours on NiMH reminds me of the old Incandescent Streamlight Days, in other words, it starts out dim and just gets dimmer in a linear progression to Zero.
Hmmm… WalkIntoTheLight did long runtime tests and his results show that the output is nearly flat and ~11 hours on Medium.
This is a review of the Thorfire TK4A flashlight. It is a 1100 lumen high-output light that takes 4xAA batteries, uses a Cree XP-L LED, has a single-button electronic switch interface, and has 5 output levels + a hidden strobe. The light was provided by Banggood for review purposes. You can find the light on their site here: ThorFire TK4A on Banggood Update: there is a discount code for this light: TFTK4A which drops the price to $29.99. There is also a brief video review of the light I put …
I only did a runtime test for 45 minutes starting from Turbo but the <15 minutes on Medium were flat.
The Thorfire TK4A is Thorfire's 4xAA flashlight. The TK4A is a small canister style light which utilizes a domed Cree XP-L in a throwy polished reflector. Output is speced at a max of 1100 lumens (I measured ~1200 lumens!) I'm a huge fan of any flashlight that can deliver high power from common AA batteries as I own literally dozens of Eneloops and use them in everything. I find NiMH batteries extremely convenient since I can store a couple dozen of them at full charge. I had the opportunity…
This light does have timed stepdowns from Turbo and High though.
Here is my TK4. Definitely more compact than Thrunite TN4.
Tint is 5500K which is quite acceptable, considering price I paid.
Modes are changin little bit slowly. Glass looks strange, like it is plastic.
Anyway, perfect flashlight for my car glove compartment.
Oh, I see I was mentioned in this thread. To clarify my results, I stick by my observation that this light is well-regulated (at least on medium, which is the only mode that can run without any step-downs). However, I do not have an integrating sphere, and my light-meter results are probably only accurate to about 5% or 10. So, it is quite possible that the light output might drop by as much as 10 over the entire run-time. IMO, that is negligible, and wouldn’t even be noticeable to a user. (My graphs are drawn with Excel and no curve-fitting, so that’s why they look so flat. I find curve-fitting the graphs may look better, but show inaccurate results in some areas.)
I did not do long run-time tests with alkaline batteries, so I’m not sure how it performs with those. I suspect, not very well.
If I compare this light to another 4xAA light, such as the Crelant 4VA, there is a large and noticeable drop in output from the Crelant over its run-time. IMO, the Crelant V4A is an example of a light that does not have regulated output. It has much higher lux than the Thorfire, but only when the batteries have good charge. I use both lights, but I find the Thorfire to be a better general-purpose light.
Just to add info.
The holster was awful and I throw it way.
In user manual is written that this light has 3 minutes step down in turbo and 30 minutes in high mode.
Did someone tested weather Nitecore diffuser NDF40 and traffic wand NTW4D will fit to TK4A?
I have the Sofirn (SF11) version of this light. I actually have 2. My original came with issues. It would turn on, or off, switch modes, all kinds of erratic behavior. Sofirn sent a replacement within 2 days that works great. Really like this little light.
I got the bad one apart. The bezel was lightly glued, but broke loose by hand. It has a pressed in shelf for the MPCB. It pulled out with minimal effort with a pair of forceps, after de-soldering the leads. The driver is held with 1 screw. I actually damaged the case taking the switch cover off, thinking it needed to come out first, before pulling the shelf. I didn’t want to damage the switch. It was not needed. I was hoping the issue was constant pressure on the switch (compared to the working light), but no joy. I haven’t had time to try and isolate the problem.
Here are a couple of terrible cell pics.
EDIT: I didn’t realize this review was done almost a year ago.
