HaikeLite XHP70 Thrower Prototype Sneak Preview
319 posts / 0 new
HaikeLite Official
HaikeLite Official's picture
Last seen: 3 weeks 4 days ago
This is another XHP70 prototype sample from HaikeLite
The light showed in pictures is a prototype sample, Some details are not so perfect. We will update new final sample pictures next week.
Specifications: (info From the prototype, not the final version)
—Emitter: CREE XHP70 N4 CW CRI75 or N2 NW CRI80
—Aluminum Alloy body with HAIII Anodize black surface Finish
—Battery: 4× 18650 High Drain Battery: 4x High Drain >10A Flat Top 18650 ( Recommend standard flat-top Samsung/LG/Sanyo 18650 )
—Anti-reverse Protection
—Double Electric side switch ; One for ON/OFF , One for mode-changing
—Deep and Big Aluminium light-OP Reflector
—Ultra clear Double-sided AR coated toughened Glass lens (99% light transimision)
—Double O rings; IPX8 Waterproof(test passed );
—With standard Tripod hole
—Max Brightness: 5000 Lumens
—Shot distance: 750 meters
—Max Runtime: 98 days on moonlight mode
—Current Regulation; Without Visable PWM
—Brightness Level: Low Low 50lumens; Low 450 Lumens ; Middle 1000 Lumens ; High 2000 Lumens; Turbo 5000lumen
—Timed Themal regulation Step down
Mode memory in above levels Double click Turbo—5000lumens (quick access to turbo at any status) Hidden moonlight-0.2 lumens ; ; Hidden Stroble – Hidden SOS
Size: 173mm length x 86mm Head x 55mm body
NetWeight:810 Gram
UI:
Switch 1:
Single Click-on ; Single Click-off ;
Quick Acess Turbo (Double click switch 1 in any status to acess; easy to access)
Long-press to Strobe; Long-press again to SOS; Single click to previous memorized mode
Switch 2:
Low Low-Low-Mid -High-Turbo (single click to change modes ; with last mode memory)
Hidden Moonlight 0.2 lumens (fast double click switch 2 to acess moonlight, Single click to previous memorized mode)
Memory modes: Low Low-Low-Mid -High-Turbo + OFF
Lockout function: Click+hold switch 2 to lockout the light; Repeat to unlock. Tailcap-lockout also available
Power indicator:
50%~100% Blue LED ON
50%~9% Blue LED flash twice every 10 seconds
9%~Turn off Red LED flash twice every 10 seconds
Internal parts:
72mm inner wide x 68mm deep Reflector (make it a super thrower)
35mm Haike Copper DTP Emitter board
18 gauge thick copper+silver wires
8mm thick internal emitter-sitting disk
Double Silver-plating copper-alloy springs
Some beam shot (Please ignore the red-color switch led on the proto; final products are with Blue color switch)
MT07 CW VS Car High-beam (MT07 much brighter and much much longer distance )
A iron tower (400m-500m away)
MT07 light up the tower
More pics updating
Thanks to all Smile
The other HaikeLite
HaikeLite MT03 Flooder
HaikeLite MT03 Triple XHP70 (flooder): http://budgetlightforum.com/node/49235
HaikeLite Official--all rights reserved
www.haikelite.top
Skype: haikelite@yeah.net
Edited by: HaikeLite Official on 11/07/2016 - 20:05
nofearek9
nofearek9's picture
Last seen: 2 weeks 2 days ago
XHP35 HI for a thrower,any reflector pics?
KawiBoy1428
KawiBoy1428's picture
Last seen: 2 hours 10 min ago
Both! Very nice, can you make a smooth reflector for it too as an option or an added purchase? Is the 2S2P a battery carrier or battery tube set-up?
KB1428 “Live Life WOT
HaikeLite Official
Not a problem, but smooth reflector has a xhp70 dark-cross. Do you mind that?
Thanks
www.haikelite.top
HaikeLite Official
Will post some photos of the reflector on Monday.
Thanks
www.haikelite.top
KawiBoy1428
Thanks
Nope I do not mind, I can deal with it! But if you make XHP35 go with smooth reflector and a 4S set up 2.5amps with a Buck driver or push for a little more with a linear driver!!
Edited.
tech
Last seen: 3 days 10 hours ago
What a nice light – I would prefer to have a choice when buying the product- but if you’d to make an engineering decision I would go for the XHP70. the cross is not that visible in the review lights I had, especially in the forest/woods/outdoors. White-wall hunters will see it though.
HaikeLite Official
not battery carrier.. i need to post a photo to explain.
www.haikelite.top
KawiBoy1428
Cool, post away!!
HaikeLite Official
Thanks tech
I agree with you. Spare SMO reflector will be available.
Dark-cross of XHP70 can only be seen when you are close it to a white wall. When using it outdoors, the dark-cross can barely been seen. We did a light-OP finish to the reflector in order to save some lumen-loss.
www.haikelite.top
zeremefico
zeremefico's picture
Last seen: 6 hours 46 min ago
I imagine they use a battery solution like jetbeam T6. More easy compared with battery holder but a 4s configuration would be better for 12v leds (xhp35).
Anyway nice approach Smile
₪₪₪₪ ΟΥΔΕΝ ΚΡΥΠΤΟΝ ΥΠΟ ΤΟΝ ΗΛΙΟ ₪₪₪₪
My YouTube channel
Flashlights & edc gear
K40M F16
KawiBoy1428
Yes liking it a lot, 8mm thick emitter shelf, bypassed copper alloy springs, 40mm DTP emitter board, whats not to like!! Thumbs Up 18awg leads for the XHP70 would be better, IMHO but at 6 amps 20awg will do, unless you plan on pumping it up a bit more?
nofearek9
nofearek9's picture
yes the specs are amazing ,if you need reviewers we are here Smile
giorgoskok
giorgoskok's picture
Last seen: 1 month 1 week ago
With xhp35 hi will have better throw i think.
I sent a pm with a question also Haikelite .
KawiBoy1428
Use a premium thermal paste/grease, make the mcpcb pocket tight to hold centering the LED and screw down the emitter board for better thermal transfer, and also not to allow the board to twist and possibly cut the LED leads, would be a couple other suggestions…if your not doing this already?
KawiBoy1428
Like to see pictures of the base of the reflector too..
G0OSE
G0OSE's picture
Last seen: 2 days 5 hours ago
Nice, will keep an eye on this.
Pok
Pok's picture
Last seen: 11 months 1 week ago
“8mm thick internal emitter-sitting disk”
Why not integrate head design?
hIKARInoob
hIKARInoob's picture
Last seen: 3 months 5 days ago
Having an option for XHP35 and XHP70 would be nice. It looks really good…
keengeorge
Last seen: 1 year 2 weeks ago
Watching with great interest. smile
For an XHP70 thrower, would prefer an option to be supplied with both smooth & OP reflectors.
HaikeLite Official
The head is integrated. I mean the emitter shelf is 8mm thick for better heat sinking.
Sorry for bad english
www.haikelite.top
Barkuti
Barkuti's picture
Last seen: 1 hour 45 min ago
Exaggerated lumen numbers those seem, Yoda says. According to the Cree documentation, a 2S2P N4 bin XHP70 emitter would be beaming ≈2300lm at 85°C.
5000-5500 lumens at 6'5A?
That is with the emitter riding on the Hulksink, in an integrating sphere collecting ALL of the output…
Sorry!
Cheers Party
P.S.: only low-CRI Crappy White and N00b White? Sheesh! Big Smile
The Light Innocent I am
Deleting a post and redoing it causes the forum thread answer notifications to become invalid. Thus, if you need to change your just published post, edit it. Thanks.
Please avoid quoting lenghty posts, namely with nested quotes. Trim the quote down to the essential. Helps with forum neatness and legibility. Thanks.
Wrathbringer27
Wrathbringer27's picture
Last seen: 2 days 2 hours ago
Will get one if reviews are positive and worth the price!
Words can be broken,
so can bones.
hIKARInoob
I wonder what it’s like to hold this light. It looks like it’s head heavy, so you have to grip it in front of the buttons where the cooling fins start to keep it balanced. Is it comfortable to hold in such manner for a long period of time…
HaikeLite Official
Thanks for point that. In fact The body is much heavier than the head with the 4×18650 batteries installed. The balance is comfortable to hold.
www.haikelite.top
Tac Gunner
Tac Gunner's picture
Last seen: 8 months 3 weeks ago
Like the looks of this light as well. Will the led be mounted to on copper DTP star? I think a smooth reflector xhp35 hi would make a great thrower.
KawiBoy1428
I like the heavy block vertical (Fins) heat sink(s) at and below the emitter shelf, having a integral shelf, this should do well to dissipate a substantial amount of heat! Hopefully the inner cavity walls are thick too!
giorgoskok
From the OP i suppose so :
Quote:
40mm Haike Copper DTP Emitter board
hIKARInoob
Man this thing looks thick and juicy…. me like very much so far…
maukka
maukka's picture
Last seen: 6 hours 10 min ago
The UI looks similar to the Olights with two switch improvements, which is great. Can’t wait to see what this thing can do.
pilotdog68
pilotdog68's picture
I’ll PM my address to you
