Looking good
The triple XHP 70 looks great.
Sounds good!
Edit: just saw where that was posted in the OP, I completely missed that to begin with.
Yep, this one I’ll follow closely with great interest!
Whats the longer light with the rectangular double button switch?
It is HaikeLite’s longer light with the rectangular double button switch.
This is another XHP70 prototype sample from HaikeLite The light showed in pictures is a prototype sample, Some details are not so perfect. We will update new final sample pictures next week. Specifications: (info From the prototype, not the final version) —Emitter: CREE XHP70 N4 CW CRI75 or N2 NW CRI80 —Aluminum Alloy body with HAIII Anodize black surface Finish —Battery: 4× 18650 High Drain Battery: 4x High Drain >10A Flat Top 18650 ( Recommend standard flat-top Samsung/LG/Sanyo 18650 ) —…
Nice looking prototype, but IMO it needs a higher turbo, at least 10,000lm. Doesn’t matter if it drops down in one minute. Also I would like to see deeper reflectors so it’s not limited to a pure flooder…
RobertB:Whats the longer light with the rectangular double button switch?
How did I miss that other thread :person_facepalming: Thanks for posting it for me
I think you need to have your light different than all others…… And that’s to not have hidden turbo. You should change your ui so that turbo can be memorized also. So that turbo can turbo can turn on with a single click.
You can keep double click to turbo.
This would really differ you from all other high output lights out there!
10 000lm for such a small-size light is too hot. It gets really hot in 1-2 minutes.
Deeper reflector will increase the size, 130mm is very handy.
Got your points. One-click to turbo seems like a good idea.
The flashlight drivers are already in stock, So UI can not be changed in this batch. High mode-2000+lumens is a nice daily-use mode.
will34:Nice looking prototype, but IMO it needs a higher turbo, at least 10,000lm. Doesn’t matter if it drops down in one minute. Also I would like to see deeper reflectors so it’s not limited to a pure flooder…
I myself prefer the pure flood as it is more useful for me. I would rather be able to see a large area immediately in front of me than a small area several hundred yards away.
blueb8llz:I think you need to have your light different than all others…… And that’s to not have hidden turbo. You should change your ui so that turbo can be memorized also. So that turbo can turbo can turn on with a single click.
This would really differ you from all other high output lights out there!Got your points. One-click to turbo seems like a good idea.
Please let us know when and if your company does decide to have one click turbo.
HaikeLite Official: blueb8llz:I think you need to have your light different than all others…… And that’s to not have hidden turbo. You should change your ui so that turbo can be memorized also. So that turbo can turbo can turn on with a single click.
How many people want one-click-turbo?
Maybe a vote?
Well i personally agree with all the choices you made. Small, 4x18650, ultra bright, shortcut to moonlight and turbo.
Why do you need to be able to one click to turbo? Just double click?
For normal uses 2000 lumens is what you would need. I wouldnt want to be flashed with 8000 lumens accidently.
I prefer double clicks for turbo so you dont accidentally put on turbo in bed
double click turbo!
I prefer double click turbo as well. I’m only interested in single click turbo (or maximum) if that light output can be maintained continuously without stepping down/light getting too hot to handle.
Double click for turbo too
zeremefico:Wow, price range?
Would be very reasonable . Some guy in forum will do test review first.
I’d be your Guinea Pig. Wow ! Any hosts going to be available?
