Flashlight Firmware Repository
What you are trying to do is actually quite simple, just a matter of warping your brain around not having to use the PWM values when setting up the modes, took me a bit to get used to that but once you get it, it is much simpler.
I started to type out how to do it, it is really quite simple, you basically just zero out the single 7135 channel at the 27th ramp table so that the bank of 7135’s can run by themselves. Then setup the mode group.
Instead I will toss together a version that should work for you real quick.
Here are the lines you are interested in when setting up the modes in bistro.
First is the ramp table that converts the raw PWM numbers into “modes”
#define ONE7135 14
#define ALL7135s 27
#define RAMP_7135 3,4,7,11,18,27,40,57,77,103,133,169,211,255,255,255,255,255,255,255,255,255,255,255,255,255,0,255,255,255,255,255,255,255,255,255,255,255,255,0
#define RAMP_7135s 0,0,0,0,0,0,0,0,0,0,0,0,0,0,11,22,35,49,64,82,101,122,144,169,195,224,255,255,255,255,255,255,255,255,255,255,255,255,255,0
#define RAMP_FET 0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,9,24,39,55,73,91,111,132,154,177,202,228,255
Notice that I zeroed out the one7135 channel at the 27th ramp in order to allow the bank of 7135’s to run without the single 7135 engaged. Simply return that zero to a 255 to re-enable it.
Here is where the mode groups are setup. I have this firmware set by defualt to use mode group 3 and enable moon mode. Moon mode in this firmware is 3 PWM as that is the 1st ramp table value. So that takes care of your first mode.
The code for the mode groups, the bolded group is the default one and the one that should be close to what you are looking for:
Now I am not totally sure how many mA a 7 as the first mode will draw but you can simply adjust it up or down until you get the brightness you are looking for. I am guessing it will be around 50ma since that correlates to a 40pwm in the ramp table.
You should be able to adjust from there pretty easily.
Here is the code for the above setup: PD68-Tripledown
While you are in here TK, quick question. I have some 105C drivers laying around that I want to use up. I would like to put the A6 firmware on them, is it as simple as simply zeroing out the 7135 channel in the modes section and putting my desired modes all in the FET section? I don’t see any reason it wouldn’t but I have not messed with the A6 firmware yet.
Well let’s give it a shot.
So the ramp tables are essentially what I am used to seeing as far as PWM values for each channel? Then in the progmem section , those numbers (1-40) just correspond with a place along the ramp? So using your example code you posted here, a ‘20’ in progmem would equal 255/82/0 ?
Can I make the tables smaller (like 10 or 15 levels) so it’s easier to keep track of?
Yep, that is exactly it!
You can make the ramp size smaller, I think all you need to do is change the Ramp_Size and then remake the ramps for each channel with the correct number of modes.
Ok, I can work with that. So the extra levels in the ramp table are just that, extras, so it gives smoother ramp downs for Temp and LVP? But If I wanted to, I could actually run it with a ramp size of 4? The firmware automatically adjusts for the ramp size I define? And likewise, I see I can reduce the number of mode groups if needed.
Correct, if you want to super basic you can do that. I personally like the mode I use to be basic but I leave all the extras in the firmware so that down the road if something changes I can simply select another mode group later rather than having to reflash.
Texas_ace: how do you set the default options in this tripledown firmware? Like you mentioned, moon or no moon, or what mode group is defaulted right after flashing.
It is in the “// Config option variables” section. Just above the mode groups.
Pretty self-explanatory really, just keep in mind that in this section the mode groups start at 0. So if you want mode group 3, you need to enter 2 in that field.
Basically all of these settings can be adjust later from the config menu, so this is just where you setup the default options for the first use.
so in the boot options does mode 0 = mode 1, or does mode 0 = muggle mode?
0 = 1
I think that muggle mode would = the number of mode groups you are using –1. So in my case 9, although I have not tested it to know for sure.
Thanks! I don’t know how I missed that…
Please, help a newbie :slight_smile:
I’m trying to compile biscotti firmware, but I get the file size of 1026 bytes (100.2%).
I use build.sh from ./bin:
What am I doing wrong?
(When I’m trying to compile bistro firmware, I get file identical to original bistro.hex from repository…)
I got 1022 bytes when built in Amtel Studio 7, but looks like you got the optimize for size (-Os) setting set... Might be some other setting, or compiler/tool version maybe.
So, what command do I use to flash to a 25? Fuses and such?
Depends what's recommend by the firmware - thinkn we've been pretty consistent to list the exact fuse values in the comment section at the beginning of the code. I got 25... BAT files posted on my shared google drive. My psw25 firmware uses this BAT file:
avrdude -p t25 -c usbasp -Ulfuse:w:0xe2:m -Uhfuse:w:0xdf:m -Uefuse:w:0xff:m
Hmm well, even that simple statement was a bit over my head.
I think I know what I need to do to bistro, I just need the line to paste in avrdude to make it flash. Is that the line I need?
K, according to TK's header in bistro.c:
* I use these fuse settings on attiny25
* Low: 0xd2
* High: 0xde
* Ext: 0xff
So, you would want to use the following AVRDude command:
avrdude -p t25 -c usbasp -Ulfuse:w:0xd2:m -Uhfuse:w:0xde:m -Uefuse:w:0xff:m
Just paste the above line into a .BAT file, call it SetBistroFuses.bat, and you got a decent setup.
Little details on this, maybe helps:
  • all parameters start with a "-"
  • lfuse = low byte fuse, hfuse=hi byte fuse, efuse=extended fuse
  • 0x is hex notation, so fuse values are specified in hex
  • "-p" I believe is for processor, "-c" is probably for connection
  • this is a great tool for understanding fuse values: http://www.engbedded.com/fusecalc. We all use it. Given the d2/de/ff values, just plug them in, and the tool will tell you what the settings mean
To dnld bistro, this is what I use in a BAT file:
rem 25bistro - downloads bisstro (Tiny25 power switch UI configurable)
rem
avrdude -p attiny25 -c usbasp -u -Uflash:w:\Tiny254585Projects\bistro\bistro\Release\bistro.hex:a
So this is what I use currently
I just paste that in command prompt terminal.
Sooooo I can use this?
Yea, you can combine them like that - should be fine. I've been splitting them out, because it's not necessary to re-do fuses usually, but I may dnld new firmware dozen or more times in a day/eve.
