thank you, I even found one that might fit.. but after some measurements I decided to bridge the capacitor. Now pulling 2.2A from 2 AA eneloops.. so no more than 1.8A to the emitter. As the device will be QTC controlled -> no problem.
But thanks for the hint with RS components, great site!
Assuming that's a SOT23-6 there in the middle, that looks like a 1206 size to me. If it's an SC80 in the middle though, then it's more likely an 0805. We're talking about parts that cost a penny or two though, so get both if you're not sure. Bourns, Vishay/Dale, Susumu, KOA, Yageo, Panasonic - all good chip resistor brands.
Here, for example, is a quality R100 (100mOhm) 0805 part:
Resist her? I'll try, but I think she has the new flashlights I ordered! :p
Seriously, EBay has all that kind of stuff. I just bought 250 SMD resistors for 4 bucks plus shipping. Of course it's about 247 more than I really needed, lol, but that was still the best deal.
100 milli ohms is a very small resistance, If it is to mod the driver for slightly more amps, why not install a small momentary contact switch using very fine wire to shunt the resistor. I am too busy (lazy) to try this, but I bet the wire to and from the switch would (could) be 0.1 ohm. You would end up, in effect, a Turbo mode. Has anybody tried this?
My suspicion is that all of the current for the emitter flows through the resistor. Very fine wire is not a good plan. In fact, if you want a 'turbo/DD' mode, you want FAT wire and a good switch to yield near zero ohm.
I suspect that it is a "sensing" resistor. Putting all of the emitter current through it would mean that it would need to be about a 1 watt resistor. and it would also make the driver very inefficient. At 3 Amps (P=I*I*R) 3*3*0.1=0.9 watts. That resistor is probably an 1/10 watt or even smaller.
A current "sensing" resistor is a shunt resistor, and yes, all of the current flows through it, and no, it's probably not a 1/10th watt. Assuming it's a 1206 like I suspect, it could easily be a half watt, and they're available in even higher power capacities.
If it's a half watt 1206, then it could handle as much as 1.82 Amps flowing through it before being out of spec.
