XENO S3A (CW, NW, WW) Now Shipping (Canada)
More Information Here: https://budgetlightforum.com/t/-/8689
Available now at HIDCanada.com.
Specifications
1/.Emitter
-CREE High-Power LED,XM-L series. 3-Color Temperature optional:
XM-L 1B U2,Color Temperature 5000~8300K,CoolWhite,MaxOutput 300lms
XM-L 3C T6,Color Temperature 4750~5000K,NeutralWhite,MaxOutput 280lms
XM-L 7B T4,Color Temperature 2600~3700K,WarmWhite,MaxOutput 245lms
2/.Output(OTF)& Burning Time*(CW version):
6-Stage(3+3) Variable Output
Normal:
High(1000mA/OTF300lms/2.5hrs)
Low(350mA/OTF120lms/8hrs)
Ultra Low(20mA/OTF20lms/100hrs)
Hidden:
Strobe(1000mA/OTF300lms/10hrs)
LB(350mA/OTF120lms/34hrs)
SOS(350mA/OTF120lms/20hrs)
Shipping from most places. Questions?
Fits protected cells no problem (AW/XTAR/TrustFire).
Features:
1/. Built in XENO HDD Engine-Linear LED driver with hidden functional output:
6-Stage(3+3) Variable Output: Normal(high, low, ultra low) + Hidden(strobe, LB,SOS)
Humanized UI (User Interface) for shift variable output:
Turn on the light, half-press the switch cap less than 3 times into the hidden functional output
Single press for next output
Turn off the light more than 3 seconds, the output reset to normal high output next time
Max Output: 300lms@1000mA(OTF, full high level)
Max Burning Time:100 hours@20mA(Ultra-Low level)
Max Burning Time with 18650*1-Strobe:10hrs; LB:34hrs; SOS:20hrs
Linear LED driver, Not PWM mode.
Non-Flickering and Absolutely Noiseless even at Ultra-Low level.
With Ultra-Low output, more than 100 hrs burning time.
XENO unique Quiet RSL™ technology.
XENO unique GFC(Gamble Free Concept) impact-resistant technology.
Rated Input:DC3.0~6V;
Battery:Use 18650*1 Li-ion rechargeable battery or CR123A*2
Built-in battery inverted-load protection.
Built-in battery overdischarge protection.
2/. XENO unique clip: BCS-Maybe the most reliable encircled pocket clip in the world
XENO unique 3600 encircled pocket clip: a highly reliable engineering design.
Pocket Clip with 3D designing, high powered & flexibility enhanced.
Detachable: can be disassembled for clip maintenance.
Allows the user to quickly access the flashlight from the belt.
Made by high quality spring steel; qualified by 96 hours Salt Spray Test.
3/. XENO STT3-XENO unique stainless steel tail plug
The micro reverse click switch with XENO self-compress contact structures.
Stainless strike bezel: windows/glass break, self-defence.
Easy-press circular-arc breach
Support tail-standing ability.
4/. Integral Design of head and body:
Greatly improve the ability of Illumination, Waterproof and Dust-proof.
Prevent accident loosen the head-cap while change the battery.
5/. Reflector:XENO precision aluminum long-throw reflector, OP.
6/. Lens: Ultra clear lens with Anti-Reflection coatings on both sides.High quality toughened mineral-glass, precision polish the edge for impact-resistant.
7/. Switch: The reverse click switch.
8/. Water proof:IPX-7; 1m dunk-resistance.
9/. XENO GFC impact-resistant system:
Double Spring between anode “+” and cathode “-” of the battery for shock proof.
Both spring are 24K-Gold-Electroplated.
HDD LED driver with XENO GFC impact-resistant technology
Shock isolation constructions for LED driver
