A few things here, first an LED has a much longer life that 50k hours actually, 50k hours is the rating of when the LED will drop to 70% of its original output. LEDs don't bun out, they just get dimmer over time. Also, 50k hours is a very long time, if your flashlight was on 24x7 it would be 5.7 years. 12 hours a day puts you over a decade, by then LEDs will have advanced so far that what you have now will seem archaic, you will probably already have replaced your light 2 or 3 times over with new technology before 50k hours passes.
Thanks for the breakdown into really reasonable and practical life example.
Maybe I had been too engrossed into specs. CREE must have some sort of test equipment for running the lights to speed up their life cycle to test the 50k hours.
So it does not matter whether i run it at 20lm or 200lm. The result on lifespan is negligible.
All I can say is this. I own 50+ flashlights. Some of them I use (and abuse) quite often, some others are just standing on a shelf. I fried some of the drivers already, but I didn't manage to kill a led so far.
I think Cree is successful for a reason. They are simply astounding. I believe I'll be buying more of P60 drop in. Knowing that I could change out the faulty LED is reassuring.
The question I'm asking is due to the fact I bought a few non replaceable manufacturer lights. The thought of USD20 shipping fee to and fro manufacturer is haunting me.
UF drop in that bros here highly recommend are only 15 at manafont.
I (think I) read somewhere that the 50k number really refers to when all of the lights will fail and that it tells nothing about when an individual light will fail.
In other words most will fail around the 36k range, the last one will fail by 50k and some can (will) fail well before that.
