Hello, I just received a pair of protected NCR18650a today from HKequipment. They came at around 3.6v each and I charged them. I put one into a flashlight and started switching modes. Everything seemed fine until I tried switching to high. The light would switch to high for a split second and then the light will go off. I could switch back to med and low just fine. The only mode I seem to be having problems with is high. I tried both batteries and the same thing happened and also with three different lights.
The list of lights for those wondering:
-XinTD c8
-Solarforce L2p w/ low voltage XP-G drop-in from Solarforce
-Solarforce L2m w/ Ultrafire XML drop-in from Manafont
I have been using Xtar 2600mah batteries and they worked with all three lights without a problem. I am hoping that someone can tell me what my problem is. Thanks for reading.
Well, the cells are clear-wrapped and it looks pretty easy to slip a pair of scissors underneath the negative end of it. I’m not sure what you mean by the second part though.
there should be a doughnut / ring insulator around the +nub. I think its there as a double layer insulator to better isolate the +B from the -B.
Use caution when doing this. Theres a metal ribbon wire that runs down from +B to the B end of the cell to power the circuit board. If you slice through the heat-shrink while cutting the metal ribbon wire you will short + to.
Sanyo cells for example have a blue ring insulator.
AW IMR black
Samsung ICR is white
Panasonic CGR is white
Alright, so I took off the PCB and everything works now. However, There’s still small remnants of the metal ribbon that are stuck on both the positive and negative ends of the cell. I was wondering whether or not this will pose any problems in the future if I just leave them on (can’t seem to get them off).
