Can i mod my incandescent surefire G2 with this bulb?
8 posts / 0 new
brendan
Last seen: 8 years 11 months ago
how2
Last seen: 5 years 2 months ago
Yes I think you can as it takes a P60 drop-in.
But get a second opinion.Is the surefire G2 plastic?
If so this Drop-in would produce too much heat and be no good for the Surefire G2.
Match
Match's picture
Last seen: 3 years 10 months ago
Disassemble your flashlight and take a look at the bulb assembly.  If it looks like the one on ebay it should work fine, as long as your flashlight body isn't plastic like How2 stated.
And welcome to BLF!
brendan
Thanks guys! It is plastic so unfortunately won't work.
Match
Match's picture
FYI, you can get a complete Solarforce body sans drop-in for as little as $7.99.  Throw that drop-in in there along with a good 18650 and you're set for <$30.
Btw, Manafont has the new xml drop-ins cheaper...
brendan
Thanks very much match... what i was trying to do was repurpose 2 incandescent surefires with LED drop-ins for the least cost... any idea what I would have to drop down to so as to not generate too much heat for the plastic bodies?
how2
If you run it on medium or low then not that much heat is produced, then your better geting XRE Q5 5 mode Drop-in or XPG R5 5 mode drop-in.
I have both and they work well with 1x 18650 battery or 2x RCR123
Nautic
Nautic's picture
I have a Surefire G2 (plastic) which runs fine on a R5.
Cheap quality is good - Expensive crap isn´t
