Withdrawn
These have a beautiful beam. A perfect combo of throw and flood, more on the flood side. They have a nice spill and put out about 800 lumens on high.
Also available (not pictured) is a smooth reflector. A bit farther throw on this one. You can select the modes you prefer as well.
No beam artifacts. About 700-800 lumens. Brand new
Option 1: 5/30/100/strobe/SOS (w/memory)
Option 2: 5/100/strobe (w/memory)
Option 3: 5/30/100 (w/memory)
Option 4: 5/100 (w/ memory)
U2 and warm also for sale
Hi, may I ask you where are you located!
Hello my9221,
I am in Pittsburgh.
Warm 80cri, neutral and cool now available. Landing price - a nice $28
Nice selection, Did you build them yourself or just reselling?
Hi Alex,
I built these myself and will support them for technical failures for 6 months under only 2 circumstances:
1. It’s the same unit I sent - Each one is uniquely marked on all components.
I know all of you are honest, but I just must say this.
2. It’s not broken due to misuse - Which means crushed, mutilated, burnt, or any other destruction, or taken apart - (I know if it’s been disassembled) - Again, I know none of you would try to pull a fast one, this is merely protocol.
Otherwise, if it fails to perform, it will be repaired at no cost. You would need to cover the shipping, but that’s all.
If it can’t be repaired, you will get a new drop in of the same type.
If you would prefer a 3A driver instead of 2.8A, please let me know. I only have 2 right now, but if they are wanted, I will get more.
A few left still
