Ray-O-Vac Industrial Grade flashlight mini review and easy mod.
18 posts / 0 new
lightknot
lightknot's picture
Last seen: 2 weeks 3 days ago
Budget lights: RAY-O-VAC Industrial Grade LED Flashlights. Aluminum titanium bodies, heavy shock absorbing rubber shrouds on the head and tail. The larger, 3C battery 140 lumen, 2 mode version was purchased at Home Depot. The light is OK, (for a budget light) stock, quite a tight thrower, but not up to flashaholic lumen standards. Immediately after purchase a quick disassembly was in order. Head, emitter and reflector were all glued, but with a flexible rubber cement type glue that was possible to break. The the emitter, heat sink, and reflectors were pulled first. Next a standard (P-60 sized) SST-50 drop was wrapped in with several turns of copper foil and pressed (threaded) it into the head. Reassembed, and Voila! A multi purpose, heavy duty, budget flashlight with a mega-bright high and a useful low. Mod took 15 minutes. There are plans to replace the stock emitter with an SST-90 and re-install with the original aluminum heat sink. Easy, fun mod, these bodies come in 2 x AA and 3 x C battery configurations, and they are built like tanks. Specs from the package: 9 meter /30 foot drop test, 140 lumens,38 hours runtime (on high!) with 138m ~(a football field and a half) throw. On low these tanks put out 45 lumens for a whopping 85 hours at 85 meters of throw. They come with three "C" Ray-O-Vac batteries, which were immediately replaced. The light has a "Lifetime Warrantee" and Home Depot is good about returns. $24 for the 2 x C, $15 for the 2 x AA.
Edited by: Anonymous (not verified) on 08/14/2012 - 15:00
garrybunk
garrybunk's picture
Last seen: 8 hours 8 min ago
Hmm . . . do you have any photos to share?  I was just eyeing these up at my local HD the other day.
-Garry
My Bike Lights Thread, Optics (TIR) Comparison Beamshots, Diffusion Techniques
NOTE: Moving my photos from PhotoBucket to Flickr. PM me or post in the thread if you can’t see my images and need me to fix or send a gallery link. PhotoBucket images should remain visible until November 2018.
lightknot
lightknot's picture
No photos were taken of the disassembly / mod. However, it was very easy. And for $25 for a tank like Titanium / aluminum flashlight, a fun, worthwhile mod.
BetweenRides
BetweenRides's picture
Last seen: 1 year 4 months ago
Well how about at least posting a link to the specific light you are talking about?
garrybunk
garrybunk's picture
I believe this is the light, right?
1
-Garry
kreisler
kreisler's picture
Last seen: 5 years 11 months ago
i will get one too. but i dont see any need to mod it. i dont have 15mins.
if i want my 250lm P2A light to be as unbreakable, i could cut my own rubber boots (with holes Wink ) and put it over the head and the tail. will increase the drop impact resistance by 300%.
*FMI* i got 4 i/o sh
lightknot
lightknot's picture
JohnnyMac
JohnnyMac's picture
Last seen: 2 years 1 week ago
I wonder if the 3xAAA version would take a 22650 cell? Might make an interesting mod if it takes a P60 module like the 3C version.
http://www.homedepot.com/webapp/wcs/stores/servlet/ProductDisplay?produc...MERCH=REC-_-product-1-_-202968172-_-202968170-_-N
apt323
apt323's picture
Last seen: 3 hours 21 min ago
Nice info and mod think you for the information in the origional post!
Something has to be done about this! This is BS and not needed here this is the second thread where kreisler has posted something that is not appropriate or relevant to the thread. I hate reading this kind of stuff! THIS IS SPAM!!!
Sorry to the origional poster for my comments!
kreisler
kreisler's picture
take it easy bro life is beautiful. my rights to delete my posts or to erase the contents of my posts have been revoked, ask Sb about it.
apt323
apt323's picture
Hey BRO you take it easy on the meaningless posts and I wont make a comment on them! Thanks BRO!!
feilox
Last seen: 1 week 2 days ago
so what did you mod on it? Pics or it didn’t happen?
Don wrote:
It sounds like the XM LEDs won’t really be suitable for flashlight use. Pity…
kreisler
kreisler's picture
will try to be more considerate
Rusty Joe
Rusty Joe's picture
Last seen: 1 month 4 days ago
lightknot wrote:
Budget lights: RAY-O-VAC Industrial Grade LED Flashlights. Aluminum titanium bodies, heavy shock absorbing rubber shrouds on the head and tail. The larger, 3C battery 140 lumen, 2 mode version was purchased at Home Depot. The light is OK, (for a budget light) stock, quite a tight thrower, but not up to flashaholic lumen standards. Immediately after purchase a quick disassembly was in order. Head, emitter and reflector were all glued, but with a flexible rubber cement type glue that was possible to break. The the emitter, heat sink, and reflectors were pulled first. Next a standard (P-60 sized) SST-50 drop was wrapped in with several turns of copper foil and pressed (threaded) it into the head. Reassembed, and Voila! A multi purpose, heavy duty, budget flashlight with a mega-bright high and a useful low. Mod took 15 minutes. There are plans to replace the stock emitter with an SST-90 and re-install with the original aluminum heat sink. Easy, fun mod, these bodies come in 2 x AA and 3 x C battery configurations, and they are built like tanks. Specs from the package: 9 meter /30 foot drop test, 140 lumens,38 hours runtime (on high!) with 138m ~(a football field and a half) throw. On low these tanks put out 45 lumens for a whopping 85 hours at 85 meters of throw. They come with three “C” Ray-O-Vac batteries, which were immediately replaced. The light has a “Lifetime Warrantee” and Home Depot is good about returns. $24 for the 2 x C, $15 for the 2 x AA.
So what kind of numbers did you get with the SST-50 drop-in? And where did you get the drop-in?
Eat Once a Day - Lose Weight - Feel Great!
www.omad.info
Bort
Bort's picture
Why would you want to delete or erase the content of your posts?
The Journal of Alternative Facts TM
"It is critical that there is a credible academic source for the growing and important discipline of alternative facts. This field of study will just keep winning, and we knew that all the best people would want to be on board. There is a real risk in the world today that people might be getting their information about science from actual scientists"
scaru
scaru's picture
Last seen: 2 years 11 months ago
cause he's Kreisler...
Bort
Bort's picture
scaru wrote:
cause he’s Kreisler…
I was hoping for more then that
scaru
scaru's picture
It something about him not wanting to go off topic and him being OCD. Silly That good enough for ya? Big Smile
