Hi there. I need some advice from any of you who’ve installed recessed ceiling lights lately. I have six GU10 halogen recessed ceiling lights in my living room, but they’re in the wrong part of the living room (installed by previous owner, who arranged furniture differently). I want to add four more lights, and while I’m at it, I want to replace the halogen bulbs with LED, if practical.
I bought a couple of Philips AmbientLED 200 lumen GU10 bulbs from Home Depot, and I installed one this morning. When it’s on, surrounded by 5 halogen GU10s, everything looks just as bright as before. But looking up at the light, it seems that the LED light is significantly dimmer than the halogens. I will try again tonight with two LED GU10s and no halogens installed, and then quickly switch to two halogens to compare.
The colour temperature is 3000K instead of my normal favourite 2700K, and is much cooler than the halogens, but in partial daylight this morning it was hard to tell if it was acceptable or not.
Two problems: a) the existing fixtures are 3.5” diameter. Standard ones seem to be 4”, 5”, or 6”. I believe the 6 fixtures we have are a cheap 6-pack that you can buy as a set from hardware stores. I don’t think they’re meant to take standard trims/baffles. This might be okay though if we were to add four more fixtures of similar type and size, perhaps 4” ones.
b) the bulbs are not for closed fixtures. I didn’t know what kind of fixtures we had, but once I popped off a trim plate, I saw that ours are closed. Maybe all insulated ceiling type fixtures are closed, I don’t know.
So, in summary:
- I should not use these bulbs because of the overheating concern (although after 2 mins on max, the bulb I installed was fairly cool)
- they’re the only GU10 bulbs I’ve seen that may have acceptable dimensions and output (and I’m not sure if they actually do have acceptable output)
- other GU10 bulbs may come out tomorrow, that have higher output, warmer colour temperature, and are designed for closed fixtures, but it could also be 3 yrs from now.
- there is limited bulb selection of the GU10 type
- when we use these lights, they might be on maximum output all the time
- therefore, I should not use LED GU10 bulbs yet
I’m going to add four fixtures, and I want all 10 of them to be the same or almost the same, so I’ll probably switch to standard 5” or 6” enclosures and use BR30 bulbs. There is greater bulb selection in the larger sizes, and the BR shape is supposed to produce a more diffuse light than the PAR shape. Home Depot describes the light from a PAR bulb as “crisp”. For our living room ceiling I prefer diffuse. Dimmable BR30 LED bulbs are at HD, but $40 each and 3000K. I may start with dimmable CFLs if they’re cheap, or just use incans temporarily.
One thing I’m not sure of yet: I don’t know if the LED BR30 bulbs are for closed or open fixtures. I didn’t think of reading the package on those while I was at HD. I would guess that even if they’re for open fixtures, it might be safer to use the bigger bulbs because the fixture itself would be bigger, and would be able to radiate heat better. Also, given the same light output, the bigger bulbs should produce less heat because they have lots of LEDs in them instead of just one (I think) in the GU10s, so they can run at lower currents where their luminous efficacy is higher.
A rough calculation: with our current six halogen fixtures, when they’re on at maximum output, that’s enough light for the living room (although they’re in the wrong places). If each one is 800 lm (not sure if that’s accurate), that’s 4800 lm total. When we have 10 LED lights, I only need each one to be about 480 lm. The BR30 ones at HD are 650 lm, so we wouldn’t need to use them at max output very often, and when they’re dimmed down, they’ll run even cooler.
Yeah so that’s what I’m leaning towards right now: replace everything with 5” or 6” fixtures and use CFL or incan bulbs until LED bulbs are 2700K, designed for closed fixtures, don’t buzz when dimmed, can be dimmed down to 5% or lower, and are $10. What do you guys think?
