Black & Decker Spotlight from Wal-Mart 4AA batteries - Photo Heavy - It's Done!
60 posts / 0 new
Old-Lumens
Old-Lumens's picture
Last seen: 3 years 3 months ago
I've been looking at this little spotlight for a couple weeks now and today I picked one up. I am interested in the 4AA end of it. That's right down my alley.
1
Rated 500 meters, 100 lumens, 10 hours. It has a high and a low. Click it on once, it's high, click it on again, it's low.
It's a small light and that's another reason I like it. I have never favored the big and heavy spotlights. This one is small and light weight.
2
I have not measured the diameter of the lens and reflector. I will do that when I tear it down again, to mod it.
3
Here's the tail cap. It screws off. The inner contact plate is independent of the cap, so it can fit in and the cap can turn without turning the contact plate.
4
5
The batteries are in series.
6
Never heard of these.
1a
First, remove the rubber cap off the lens
1b
Remove two screws that hold the lens on, one on top and one on bottom of the lens holder.
1c
Lens and holder. Yes it is a GLASS lens. I was wrong on the last one...
5 screws to take the body apart.
1d
As you can see, the other reason I wanted to play with this light, is the large aluminum heat sink that it has. That whole housing is heat sink.
12
The trigger and switch.
13
Battery compartment.
Photos of the driver board
d1
d2
d3
Any idea what that screw adjusts? Voltage or more like Amperage?? Anyone?
Photos of the heat sink and LED
z1
Is that maybe an XP-C emitter in there? Sure is small.
z2
z3
z4
I did a test of the amp draw
a1
HIGH - That is awfully high for this emitter. 1.5a max? No wonder it's blue when I turn it on.
a2
LOW
a3
I did this test several times and repositioned my leads each time, in case I did not have them held on tight. The readings came out the same after 20 times of high and 20 times of low, so I think they are close to correct.
I did not do voltage. I will when I tear it back down again. Yes, I put it all back together, to do beam shots tonight.
I played with it in Wal-Mart and I played with it in the garage. It has a very TIGHT beam. It is going to throw well. I just haven't decided for sure yet, but I happen to have a Nichia from Craig, that I really want to put into this light.
 EDIT: The lens measured 54.7mm and the overall OD of the reflector is 60mm, but the lens sits down into the reflector, so the usable diameter is 53mm. I still didn’t measure the depth.
The LED voltage measured 3.34vdc under load. High setting on LED.
That's all for now.........  Beam shots tonight, well after midnight.
08-09-2012
 Well, it's complete. I used a Nichia 219 and made a copper plug for the heat sink. I am using the board as it is, since the Nichia will take 2000ma anyhow and I'm putting out around 1800ma, it should be fine.
Here's the photos:
h1
Not pretty. but functional
h2
d1
I replaced the wires with teflon wire for everything except that stupid litle red led. It's all tucked away better than stock.
re1
I found thermal grease in the bottom of the reflector and I also found several spots inside the reflector. Of course, you can never wash a reflector. They always seem to look worse afterwards, so I stippled it with clear. I do not like spotlights with a tiny spot and no spill. I have no use for them, so I'm not worried about having a bigger spot and a little spill, which is what I have now.
It works, it's done, beam shots tonight for comparison.
My PayPal address: oldlumens (insert the @ sign here) gmail.com
My YouTube Flashlight Video Channel
The BLF Modding Links Thread
http://imageshack.com/a/img922/1374/jQ2wdL.jpg
Edited by: Anonymous (not verified) on 08/23/2012 - 16:15
jacktheclipper
jacktheclipper's picture
Last seen: 5 hours 47 min ago
Cool
Tecmo
Tecmo's picture
Last seen: 4 months 1 week ago
If it’s an xpc nothing else will throw that tight Sad
garrybunk
garrybunk's picture
Last seen: 2 days 6 hours ago
Looking forward to it O-L!  This light really looks like a nice modder!  Fairly easy to get into and tear apart!  Thanks B&D!
-Garry
My Bike Lights Thread, Optics (TIR) Comparison Beamshots, Diffusion Techniques
, MTBR’s Lights & Night Riding Forum
NOTE: Now hosting my photos from my Google account. Post up if you can’t see them. Older photos hosted on Photobucket or Flickr may disappear (PM me if you want access to them).
fishinfool
fishinfool's picture
Last seen: 8 months 4 days ago
I'll have to go and check it out at Walmart later.
Don wrote:
"But as I said long ago, you are more likely to be killed by a dead fish dropped by a seagull in the Sahara Desert than by a lithium ion
JohnnyMac
JohnnyMac's picture
Last seen: 2 years 4 months ago
Looks interesting, O-L! I always passed that one buy because the reflector looks so small compared to the other ones. I’m afraid I’d want to use an XM-L in it and it wouldn’t work too well with one. XR-E R2 at 2A should be great with it though. That XP-C has to go! :bigsmile:
kramer5150
kramer5150's picture
Last seen: 1 month 4 weeks ago
They should have given the LED star a bigger platform to sit flat onto/against. Looks like its sitting up on a pedestal. Other than that, it looks like a nice mod host. Trippy looking driver board. Looks more like an audio amplifier circuit than a DC-DC board, 10Volt caps? Not sure about that trim-pot, and what it does. Did you try turning it? Might not be a bad idea to give it a try since the LED is turning blue from the 1.5A. That is a lot of current for an XPC. You could probably mount an XML-T6/U2 star in there and almost double the lumen output.
reiko1078
Last seen: 7 years 6 months ago
ive had one of those lights before. it was pretty bright without anything done to it. left it in the kayak for 8 months or so until it finally gave in to the salt water
Old-Lumens
1.5a, it was more like 1.8a.
I am going to find out what that trim pot does, when I take it back apart, after doing beam shots. Once I get the star off, I will see if it’s marked.
I think an XM-L would turn it into a floody light, but I noticed on another light with a Nichia 219, that it seemed to do pretty good in a thrower type of reflector. I really think I will try the Nichia in it. I’m just not loving mega lumens, like I used to. It’s amazing just how few lumens it takes, in a well focused light. My multi emitter builds are over and other than the SST-90 aspheric I had already planned, I will stick to XM-l, Nichia and maybe an XT-E.
Anyhow, when I get home, I will see how it does at 100 yards, that’s about as far as I can get at home.
kramer5150
Yeah the 219 has a very similar dispersion to the XPG… both work well in large dish throw reflectors (IMHO). Curious… Who is selling the 219 on a star? Its a great emitter.
At 1.5-1.8A that XPC on a little pedestal doesn’t stand a chance, outside of short bursts only. Depending on the thermal design of that host 1.8A might even be a bit much for a 219 or XPG with long enough ON cycles.
Looking forward to your mods OL.
nitro
nitro's picture
Last seen: 2 years 2 months ago
Very nice it looks just like my Stanley spotlight but mine does not have a 4aa holder Sad
Old-Lumens
kramer5150 wrote:
Curious... Who is selling the 219 on a star? Its a great emitter. At 1.5-1.8A that XPC on a little pedestal doesn't stand a chance, outside of short bursts only. Depending on the thermal design of that host 1.8A might even be a bit much for a 219 or XPG with long enough ON cycles. Looking forward to your mods OL.
Illumination Supply
agenthex
agenthex's picture
Last seen: 6 years 4 months ago
What’s the reflector size on this?
The input power is ~10W on this. Kinda crazy for a xp-c but not bad for an xm-l. 20mm star, too.
Reading this makes you smarter: http://lesswrong.com/
Old-Lumens
I don’t have it apart again, but right now rough measurement, 58mm lens Sits in a rubber ring), 60mm reflector. Don’t know depth yet.
Old-Lumens
Beam Shots
Inside the garage, with the normal lights on
za
All shots from here on, were done with ISO 200, F:2.7, Daylight White Balance.
Inside the garage 1 second shutter
zx
Inside the garage 2 seconds shutter
zs
Side of the house, standard 1 second shutter
zq
Side of the house 1 second shutter
zw
Side of the house standard 2 seconds shutter
zc
Side of the house 2 second shutter
zd
Pond at 80-100 yards standard - 2 seconds shutter
qa
Pond 2 seconds shutter
qw
and here's one at 1 second shutter
qs
Here's High and Low at 1 second shutter
xc
cv
That's about the best I can do with beam shots. Hopefully it will tell something. It is a very tight beam and much brighter than I thought. For me, it's too tight. I don't have use for, nor care for a tight spot, so hopefully the Nichia will give out a larger spot.
agenthex
agenthex's picture
The nichia 219 will provide several times larger spot (and supposedly very nice color). However, be careful as 8W assuming ~80% efficiency is still above rated input of the emitter.
Old-Lumens
I’m interested to see if the amperage is adjustable with the trim pot on the board. I will be testing that tomorrow. Depending on that, I might either use that board, or use a 7135 board.
OH, the lens measured 54.7mm and the overall OD of the reflector is 60mm, but the lens sits down into the reflector, so the usable diameter is 53mm. I still didn’t measure the depth.
Old-Lumens
xp
Close up of star
hs1
Pad on heat sink, that star touches against. I'm thinking of milling (dremel), it down and just make a copper one, the same thickness, but fills the whole bottom diameter. Not sure yet, but that's my inclination right now.
I tested the board trim pot and it is for the LOW setting. The HIGH setting is non adjustable and still reads 1.8+A, so I guess it will have to go and be replaced with a 7135 driver. If I knew electronics, I could probably just change out one of the resistors, but that's way beyond me.
kramer5150
Was thinking about it further, you could probably improve the thermal contact and heat performance with a little dremel work.
Cut the 3x screws that attach the star to the reflector. I would leave the screws in the reflector and just dremel off the philips heads. Use a damp sponge to keep the metal cool as your dremel does its thing. You don’t want to melt and deform the reflector plastic. Use whats left of the screws to center position the LED in the reflector. That will create a flat heatsink-star plane. Next grind down the rectangular pedestal on the cast heatsink, go slow and make sure its a flat surface. Next grind down the 3 posts on the reflector, little by little until you get the LED star to sit flat against the heatsink. You might have to shorten the 3x remaining screws by the height of the removed heatsink pedestal. A little dab of AS-5 or heatsink grease and youre good to go. If you did this you would have the same thermal design as the home depot Defiant.
EDIT You might have a lose fitting lens after doing this. It looks like the reflector presses firmly against the glass. With the removed heatsink pedestal, you’ll be shortening the overall height of the LED+reflector stack by the thickness of the removed metal.
A mod like that might be just enough to alleviate the angry blue-ness from the XPC (if you wanted to keep it in there).
Sounds like an excellent mod. The Nichia 219 is a good one.
Does anyone sell the 219 with a cooler color temp?…. around 5000K?
Awesome mod… I might give this one a try too. I’ve got enough spare eneloops just laying around, and I have a spare XML-T6 in 1A tint. That would be an EASY drag and drop mod to double the lumen output., if you skip the dremel work.
feilox
Last seen: 4 months 6 days ago
I don’t know anything, but want to ask if you gonna put a Cree XM-L LED on that thing?
Don wrote:
It sounds like the XM LEDs won’t really be suitable for flashlight use. Pity…
kramer5150
I’m willing to bet this light was designed and manufactured by the same folks that did the Stanley fat max. I am seeing a lot of similarities between the two.
-It looks like they spent similar efforts in the thermal design.
-The trigger lock mechanism is identical
-Lite-trend is also the supplier for the stanley XML star
-Nearly identical hand-grip shape
-Trigger switch design is identical
-Identical use of a thin O-ring gasket around the lens
-Reflector shape and design is nearly identical, just scaled down in size
-The circuit board looks to be comparable quality, and overall complexity too.
Curious is it possible to turn that trim-pot around and get more than 1.8A… turn the LO into a HI for an XML?
Whats the little red LED for? Does this light have a charge port, or 12V cigarette lighter cable?
Great dissection O-L and good luck with the 219 mod… I expect greatness, thats a GREAT led.
Old-Lumens
The red light just turns on, when the light is on.
I am sure, like many other things, there’s only so many places that actually manufacture and they do it for many companies and either change the labels, or the colors, etc. It’s done all the time and has been for a long time.
nitro
nitro's picture
Thats how I made my heatsink ect…..
http://budgetlightforum.com/node/11062#node-11062
Old-Lumens
Nope, not an XM-L. Heat is the factor here. Sure there is a heatsink, but it’s cheap cast aluminum EDIT: (Or Die Cast Metal, which would be useless for heat transfer), so it won’t transfer heat very well. Also it’s very thin and has no real mass. The heatsink can take heat from the LED, but after that, there’s no where to go. The outer shell is rubber and plastic (both are insulators), so the heat will be trapped. I will keep it as a lower amp LED, than an XM-L driven at 2.8A to 3A. A Nichia 219 at about 1.4A should be fine. Again, I’m not going for mega lumens, there’s other things than just that, like high CRI LEDs, that give a more natural illumination.
kramer5150
Hey OL sorry for the rapid-fire, scatter brained comments and questioning (thats just how my mind works some times).
I would think carefully about a driver swap to 7135s… they can generate a lot of heat in lights like this that keep Vin > Vf for a good percentage of the discharge. 7135 heat generation can be as much as any plane-jane RLC circuit, or FET with current sense resistors.
I think you should load up some eneloops and run it on HI for 10-15 minutes. If that OEM driver circuit remains moderately warm to the touch… stick with it. I have found 7135 drivers can get painfully hot to the touch the longer Vin remains greater than Vf.
Old-Lumens
I would think carefully about a driver swap to 7135s… they can generate a lot of heat in lights like this that keep Vin > Vf for a good percentage of the discharge. 7135 heat generation can be as much as any plance-jane RLC circuit, or FET with current sense resistors.
I know, that is a concern for those 7135 boards. There is room in the board area, for a separate heat sink for the board, once the original board is gone, it leaves quite a bit of space for that.
I may try to send this board to another member and see if it can be changed to 1.4A, I just don’t want to put a large die in it like an XM-L and I don’t want to push a small die to 1.8+A, with a poor heat sink that is enclosed in a plastic insulator. As far as modifying this board myself, no way! As bad as I shake, I would have it looking like a figure eight demo derby track in a few seconds, LOL.
Old-Lumens
So, any of you electronics gurus out there feel like tackling this board and change the High setting to 1.5A, or recommend a different board that would take from 6v to 4.5v input (4AA Alkalines or NiMHs) and output 3v-3.2v @1500ma??
Anyone?
b1
b2
kramer5150
Hm no takers?… Could you turn that POT up to ~1.4A and use that as the lights main setting? So you’d have a main setting and a short burst “turbo”.
arenat
Last seen: 9 months 5 hours ago
R150 is the sense resistor . The easy way is changing it to an R220 or .22 ohm axial resistor not hard to find and measure the current , if too low adding an 1 ohm in parallel to convert it at R180 …with 2,2 ohm go to R200…
Old-Lumens
Nope, it only ranges from 350ma to about 500ma.
Old-Lumens
That’s fine, but not with my hands, LOL. That’s why I was asking if anyone with the knowledge and skills wanted to tackle it.
