I recently received the SmallSun C10 zoomie and after a quick play araund with it I realized what to me is its bigges plus: Despite its rather big head it is unobtrusive in a pocket. It is short and with no sharp edges to speak of. I tried carrying it in my working pants for half a day and found that it lacked 2 things that I've come to like in a work light.
BIIIG flood. Didn't happen with original setup. XR-E with a zoom lens that did not come close to the led. No sir.
No clip. I can remedy that myself but that did not happen tonight.
So tonight after tucking in the kid and the missus I went to my little workshop. Got out the hacksaw and cut off the lowest part of the zooming head. Cut right behind the second "cooling fin" and smoothed it out with a file.
Now the lens stops about 1 cm from the lens. Not perfect but I did not want to risk that the head got totally wobbly in throw mode. Open up the flood to about double size. Guess my flashlight is now a x1 to x4000 zoomie ;-)
But now the flood was not bright enough! Doh!!
So I opened the light and quickly soldered in a T6 XML on a copper start that I got from DX. Just took the time to sand the star backside completely flat before I installed it thats all.
Now the flood was even wider which is nice - but even on high it was not what I wanted. So apart the light went again.
Out with the original driver and in with a Nanjg 105C board from DX. Made it 3 mode and the plopped that sucker in there.
NOW WE ARE TALKING!
The flood is so bright and wide it will light up a 20*30 meter lawn so you can tell where a leaf fell on it even at the edges. I tried putting the light down and walking away from it until I could not see the small date numbers on my Casio watch. That was at roughly 30 meters.
I was able to read some fine print on another flashlight that I carry at approximately 20 meters.
I went to the edge of my lot and tested the throw and it threw a lot better that I had thought it would with an XML so I got out the meter and took some measurements to satisfy my curiosity...
Here I have to admit that I forgot the measurements in between the lowest and highest. I'll have to re-do those tomorrow when (if) I have time again.
EDIT: I just put a fresh Panasonic 3,1Ah batteri in it before taking these measurements and I can see that the values I wrote earlier have to go.
Measurements:
Low: Flood: 27 candela @ 1 meter
Throw: 1 Kcd @ 1 meter
Med: Flood: 140 candela @ 1 meter
Throw: 7100 candela @ 1 meter
High: Flood: 520 candela @ 1 meter
Throw: 28,9 Kcd @ 1 meter
Thats all for now but I hope to have time for some pictures in the morning :-)
TY 4 reading :-)
