I love my Pelican 1920 but it takes 2 AAAs. It seems almost wide enough to take AAs so it got me thinking. Is there a AA penlight that is not much thicker than the 1920? AAs would provide the extra runtime or same runtime with more lumins.
I wonder why so many lights are wider than they really need to be.
It’s for pocket carry so it should have a straight tube or as close as possible. Basically I am looking for a AA version of my Pelican 1920 that could still be used the same but with maybe only a tiny increase in width. Length is not really an issue but width is because it would ride clipped to the front pocket like a knife. I carry my knife clipped on the right side and my penlight on my left. These are work edcs and I use them 20-40 times a day along with my Leatherman.
I was interested in the Eagletac but the UI and modes overwhelmed me. My needs are for a forward momentary clicky that is easy to use with gloves on. It gets pulled from the pocket to check things many times a day and most of the time I just need a quick peak at something. If I have to cycle through modes or fully depress the clicky, It is not worth the trouble of switching from a light that is working well already. One mode is great, two modes could be ok but only if it worked like a single mode until I needed a dimmer mode.
Looks great but I need a forward clicky or at least a reverse clicky. A twist light that requires two hands is worthless to me. If that light can me in just a simple single mode with forward clicky with the mode being 80-120 lumins, it would be perfect. With 2 AAs it would have a sufficient runtime putting out around 100 lumens for me to work all day without having to change batteries.
