Balder recently released a new flashlight series the HD series. Their first model for this new lineup is the HD-1. This light is one of the smallest AA/14500 lights on the market with an XM-L emitter! The light features a unique cut-out body design, pocket clip, and a piston switch. These have already been shipped and should arrive by 8/15 and will ship out right away!
Features:
1. Hollow-out design!
2. Strong metal clip.
3. small size and light weight, very portable!
4. Multi positional lanyard holes.
5. Stable Stainless Steel Piston Switch.
6. Reverse polarity protection
7.Fully-regulated circuit, Broad input voltage (1.0V - 4.2V) and battery compatibility (i.e. alkaline, NiMH, 14500) .
8. Precision Aluminum reflector (Orange Peel) .
9. Simple operation. High-Medium-Low. No SOS and strobe modes.
10. Mil-Spec Type III Hard Anodized finish.
11. Made from Aluminum alloy, really strong.
12. Water proof to IPX-8 standard…
Specs:
1. Dimension: Head diameter 19mm, Tail diameter 19mm, length 84mm
2. Cree XM-L U2 Cool White or XM-L T6 Neutral White
3. Lumen and runtime:
Single AA:
Maximum output of 156 lumens for 1 hour
Medium output of 80 lumens for 2 hours
Minimum output of 10 lumens for 20 hours
Single 14500:
Maximum output of 448 lumens for 30 minutes
Medium output of 235 lumens for 50 minutes
Minimum output of 15 lumens for 10 hours
4. Material: Aircraft Aluminum Alloy T6061
5. Weight: 40g (without battery)
6. Water proof to IPX-8 standard
7. Battery: single 14500 or AA
8. Accessories: O-rings, user’s manual, pocket clip
Pictures:
To Check out more pictures, pricing info and to order, please click the logo below!
That’s a whopping $1 more for fast shipping from a reliable local seller! Regardless if you think the price is too high, it’s still competitive with the shops overseas.
Also, the rest of the Balder lights are being offered at prices LOWER than the popular Chinese shops. For instance, they have the BD-4 priced at $85 plus shipping. That’s about $20 lower. I still think it’s much too expensive, however, the point is market price is still competitive. It’s hard for a USA resident to justify buying overseas with these deals on Balder products.
No mode memory. The switch is not a forward or reverse clicky. It’s a bit unique… its a piston switch.
Yea I try to keep prices pretty competitive for US customers. If you were to buy a light from overseas like this it would usually take about 3 weeks, then if there are any warranty issues you have to mail it back (and there would probably be a 50% chance it would be lost in the mail). So its always worth that extra buck or two to buy local.
Bump just got more Neutral White HD-1’s in stock, but U2 CW will be about a week out… All the units I have in stock now are the new version with improved 14500 compatibility and an easier to press piston switch.
