Balder HD-1 3 mode XM-L [ 1xAA or 14500 ]
9 posts / 0 new
old4570
Last seen: 1 week 3 days ago
http://budgetlightforum.com/node/11337 Review of pre production version .
Balder was kind enough to send me a new head [ XM-L 3 mode ] to play with .
It was a simple task to remove the retaining ring from the old head and slipping it to the new one !
+Balder HD-1 XM-L 3 mode : +
Whats different is an extra mode , also the light cycles continuously now from High [ always starts in high – this one ] to medium , than low , and back up to high .
To turn on the light , push down the plunger tube [ clicky ] for 2 seconds , to turn it off , it takes about a 3 second push . [ 3 full seconds ]
Most of you know I already like this light , and the 3 mode XM-L just makes it better .
Lets move to some performance figures :
AA batteries :
Rayovac4 = High = 175L – 1.95A … Medium – 93L – 1.00A … Low – 9L – 0.13A
Recyko = High = 170L – 1.91A … Medium – 92L – 0.93A … Low – 9L – 0.12A
Eneloop = High = 176L – 2.04A … Medium – 92L – 1.00A … Low – 8L – 0.12A
BTone = High = 190L – 1.93A … Medium – 96L – 0.90A … Low – 9L – 0.12A
14500 @ 4.16v :
14500 = High – 600+L – 1.5A …. Medium – 320L – 0.76A …. Low – 32L – 0.08A
Results are as measured [ Light output less MM , and current measured separately from light output ]
Im very pleased with the performance , but I must say that I still think it should be AA only , and maybe fitted with a more efficient AA only driver [ But thats just me ] .
On the AA batteries , Im quite pleased , the light is very useful , throws a nice beam that floods well and ???? its just nice . On a pocket flashlight the XM-L emitter throws a beam that belongs on a larger light , and its by no means a thrower , and should such a small light try to be a thrower ?
There are no issues on AA batteries , and in this regard falls into line with other AA lights , only this time the output is much higher [ 126 on previous – now 170+ ] …
The 14500 is a hot potato , and I mean hot : On high , I can not recommend any extended running as I believe the host to simply be to small to handle the thermal output , and even on medium , whilst seriously impressive [ 300+ Lumen ] , did generate quite a bit of warmth which was gradually heating up the head . And lets not forget output sag , on high its somewhat of a serious issue , and on medium , its there , but much slower , weather is rather cold here ATM , and I wonder how it would go if it were 10Deg C warmer ?
Well , on a 14500 , it really does perform : The output is HUGE for such a small light , and if you needed a pocket rocket for showing off , it will do the job .
I really am impressed by the HD-1 XM-L , I found the output on a AA just about perfect , 9L on low is near on perfect for me . I know its not 1L , but I find 1L to be too puny , especially in slightly more challenging conditions [ rough ground , scrub , jungle – conditions that might challenge your life ] , so some extra lumens really help you see the things that need to be seen .
Medium is very nice , around 90L and 1A = decent output with decent run time [ could possibly be improved upon with a AA dedicated driver ] , and High is up there with the best AA lights .
What I like :
3 Modes
Tailstands
XM-L
Good output for size
Well made
Decent clip
Small Size
Faster PWM
Weight
Nice Beam [ more floody ]
No parasitic Drain [ so you can leave your battery in there ]
What I dont like :
14500 [ Should be AA only – but I guess you need to cater to the Hot Rod Crowd ]
A lot of things to like , and very little not to like : Beams tonight ! weather permitting !
Sorry , Raining outside ! But here are some beams
 Always remember , the easiest thing in the world to do , is to expel hot air from your lungs and through some vocal chords ..
The resulting sound may , or may not be worth listening too ….
Edited by: Anonymous (not verified) on 08/23/2012 - 14:00
Suncoaster
Suncoaster's picture
Last seen: 6 days 23 hours ago
Location: Where the girls are green and the grass is pretty.
Thanks.
Nice looking light, like other Balders.
"In the land of the blond the one eyed man is king."
*This message is protected with ROT26 encryption.Old Lumens
Suncoaster
Are all those AAs 1.5 V ?
kreisler
kreisler's picture
Last seen: 6 years 9 months ago
Thanks for the review!!
i think i will get my very first Balder sometime soon Wink
*FMI* i got 4 i/o sh
old4570
Nimh , fully charged , 1.38v to 1.43v
Balder
Last seen: 7 years 8 months ago
Nice Review! Thanks, Matt.
budynabuick
budynabuick's picture
Last seen: 8 years 1 month ago
Another beauty. It’s a ‘tail cap’ shorter then SE-1. WOW! This will be my next light. Do I need it? No. Do I want it? Yes. BTW, Martin. What is the length of the SE-o? Release date?
Keith
Vectrex
Vectrex's picture
Last seen: 3 months 1 day ago
Are we seeing directly on the piston through the cut-outs on the body? If so, I would be worried that the gunk and dust in my pockets would prevent the piston from working in a EDC role.
old4570
Yes , that is the piston ..
Gunk = Pocket Lint ! , Ive been carrying this light quite a bit , and so far , not an issue .
And everyone that see’s it , pretty much wants one .
