Non-scientific test on my old Ultrafire 18650's
Since I am now slowly building up a small stock of Panasonic 3100mAh protected cells plus a couple of Xtar 2600’s , I decided to try to check (test) my old grey Ultrafire 2400mAh protected cells … Recently I had one Ultrafire just die … No volts and no response to trying to reset the protection (just in case it had popped) … Another failed on my home-made discharge test … These have been safely disposed of.
That left me with four grey protected Ultrafires to check … These were topped up and then discharged (in turn) with a bulb that draws 0.91 Amps … So it is not a high load … I monitor this all the time with my old Avo model 8 and check on occasions with my digital meter for more accuracy.
As soon as the load was applied , the cells dropped to at best 3.87V (cell 4) and then 3.82V (cell 2) , 3,75 (cells 1 & 3) … I discharged whilst monitoring the on load voltages for 75 minutes till the cell on load voltages reached 3.52 (cell 3) , 3.45V (cell 4) , 3.25V (cell 2) and 3.05 (cell 3).
On disconnecting the load , the volts immediately went up and eventually settled after a couple of hours to round about 3.8V … I then charged them all using my cheap charger boards and after charging , the cells were rested till the next day and measured … Cell 1 was 4.12V , cell 2 was 4.12V , cell 3 was 4.10V and cell 4 was 4.16V.
I am thinking of retiring the cells when they get below the 4.10V point … I’m not certain how much life there is still left in these cells , but since I am slowly building up a stock of the Panasonics I don’t mind retiring the Ultrafires … Cell 4 (4.16V rested) is now in my Skyline 1 and the two cells that are 4.12V (rested) are now in my Maglite 2D that is fitted with a Fusion 36 but will probably be replaced when my stock of new cells improves … I have cell 3 left as a dubious spare with its rested voltage of 4.10V.
I realise that my test is not very technical , but it does give me some idea of the cells performance.
In another few months , I will have enough new cells to retire all the old Ultrafires if necessary.
I am repeating the test on my two old (blue) Ultrafire unprotected cells … I don’t think they will be keepers as they didn’t hold up too well on my discharge test towards the end … The bulb was not as bright as with the other protected cells … They are on charge at the moment and I will know more in an hour or two … Not looking good though ! … I think they will be retired.
Well , one of the unprotected Ultrafires struggled to charge fully and in the end , I took them both off charge … Probably could have left the other on a bit longer … Rested , the struggler is 3.87V , so it will be retired … The other might go a bit higher , but it still only reads 4.07V relaxed … I guess I’ll probably retire that one as well.
Perhaps it really is time to change over entirely to the Panasonics … I better get another two just in case.
During all the discharges and charges , none of the cells heated up … They were barely warm.
Well , the 4.07V one is now 3.98V … That’s also retired now.
Good job I’m getting some new cells.
Good news (about the new cells).
Where are you getting your Protected panasonic 3100’s from?
Had two from here and am waiting for another two … Takes two or three weeks to the UK … When the next two finally arrive , I will send for another two … Then I will maybe eventually get another two … That will be enough for the time being ’cos I already bought two Xtar 2600mAh protected cells … If I decide to run my Maglite 2D (fitted with the Fusion showerhead) on six AA Eneloops (instead of two 18650’s) then I will probably buy two less 18650’s … Decisions , decisions.
http://www.ebay.co.uk/itm/270860995573?ssPageName=STRK:MEWNX:IT&\_trksid=p3984.m1497.l2649
