residence due to a rapidly oncoming natural disaster. They hand you a sheet of paper with certain particulars outlined on what to expect. It’s in the dead of night and because of more important priorities such as treasured family and pets you only have enough time to grab but one flashlight along with one extra-set of batteries, one battery charger, and one accessory of your choosing.
You’ve been told that you will not be able to return for an indefinite period and that you will be relocated with many others to a remote location that will be set up with tents, some trailers, and which will have at best intermittent electrical power. You are also told that you may be required to relocate from that position as required, that there will be limited supplies other than bare essentials, and that it may be relocated by foot. This event occurs in the middle of summer.
(Yes, you must evacuate the mother-in-law before you grab the Nitecore TM11 so no substitution shenanigans allowed.)
Which flashlight would it be and why?
Here’s what I would grab if it happened tonight………
Flashlight: Maglite, LED in 3-cell D
One set of Batteries*: http://www.dealextreme.com/p/gp-rechargeable-9000mah-1-2v-nimh-d-battery-white-green-2-piece-pack-147069?item=4
(Or any other Ni-MH battery that beats this. I gotta get new ones from somewhere.)
One flashlight Accessory*: http://www.dealextreme.com/p/soshine-2xaa-to-d-size-cell-battery-converter-case-2-pack-7031
One Battery Charger: http://www.harborfreight.com/portable-household-battery-solar-charger-68690.html
Since the HF description is sorely lacking here’s a U-tube…….
Btw, the U-tube doesn’t show that there’s a cover for the back that snaps in place over the batteries being charged. It’s a very compact and IMO pretty well put together unit for what it costs.
*Web site quantity packs of 2 (x) 2 in order to fill 3-Cell flashlight.
Now as to the ‘Why’: 3-Cell LED D Maglite. Very common. Can run on 1.2v NiMH, fairly common in D. But also runs on alkalines or even zinc heavy-duty in a pinch. NiMh-rechargeable. 3-Cell D Maglite is stoutly built, and is long and heavy enough for defensive use. Decent run time. Focusable flood to spot. Tough as nails and yet inexpensive.
