Here are most of the good batteries I took from soon-to-be recycled batteries from work, all dell laptop batteries:
They currently have charges ranging from 4.08v to 4.20v. One particular battery pack had all of them charged to 4.25v so I drained all of them a bit and charged them back up to a more reasonable and longer lasting 4.16v on average with this charger (of course they lose a bit of of that over time.)
Charged w/ my xtar wp2 II (love it!). it’s been fun so far looking at the different brands that come with the different battery packs and their internal construction.
There is some severe weather coming our way, at least I’ll be able to light things up for awhile if need be.
Ah, very cool. If you have a DB you’ve collected that’s one thing, but if there is a certain skill other than just googling the identification, please let me know. I actually started a new thread to be more specific. Thanks!
I am happy w/ my xtar charger at this time. My rule of thumb is not to drain them below 3.6v and if their resting capacity after a charge cannot hold 4v, recycle it. Seems reasonable?
Ah, so my Fandyfire HD2011 (if it ever gets here, damn back order) is said to draw 3.8 - 4.7a so I assume I’m covered. Thanks very much for the info. If I uncover any other battery types during my travels, I’ll certainly let you know.
It pulls 2a on high which was exactly what I wanted for my 30min commute.
The FandyFire HD2011 will be my EDC when it gets here and helmet light as it is floody. I’ll run that on medium during my commute as reports say it pulls 1.8a. We shall see!
Those numbers are based on new batteries. The only way is to check capacity and draw amperage on each used cell. Voltage or the ability to hold voltage has nada to do with either. But one piece of advise is NOT to mix cells from different packs. Generally cells from the same pack are matched but without knowing capacity or condition of used cells a guess at best. This is just friendly knowledge, do as you please.
I have used the red ones in my DRY which draws 4.5 amps on high and they do perfectly fine. Albeit I had tested them on a hobby charger and they all had similar capacity.
Actually, as I understand it the ability to hold voltage does have something to do with it. Old bad cells generally have a higher internal resistance and thus self discharge quicker.
I do agree with you and I think it would be a bad idea to run those cells in series because you did not keep track of which packs they came from and their voltage.
