Red Maglite 2AA Mod - build with lots of photos - as always ;-)
My wife told me to go out in the garage and I might get lucky. She was right! It was a nice cool rainy day today and I spent the day modding this 2AA Maglite..... What? WaddythinkIwasgonnado?
I did this mag without having to drill or bore out the head. I wanted to do one that didn't take that much work. I used a TIR optic from CNQG and a Nichia 219 led on an XP-G star. No driver, just direct drive with the alkaline AA batteries that came in the package.
red1
This is what we start with. Just a plain Incan 2AA light.
red2
I removed the guts from the body and removed the anodizing on top. This light will turn on, by tightening the head down till the pill touches this ring.
red3
This is the optic from CNQG. It's their generic version.
red4
It does not quite fit the head (too small), so I made a plastic locating ring. I took a plastic washer from Lowe's and sanded down the outside a little. Then I opened up the inside with my dremel, so that I had this locating ring. The TIR fits snug and is held in place well.
redp1
Top of the heat sink is a 5/8" copper round. Now 5/8 is a hair too big to fall into the head, so I just file the edge till it fits in. This fits right down till it hits the inside step where the threads start.
redp2
The rest of the heat sink is short piece of 1/2" copper pipe filled with copper shot and solder.
redp3
I used the dremel to cut out a little step in the bottom of the heat sink. I need to have a spacer down to the top of the batteries and you will see in a minute how it goes in.
sp1
I need to maintain the original stack up and I made a plastic spacer that is the same length as the original plastic contact plate.
sp2
Notched where it goes to the heat sink so the wires aren't in the way.
sp3
This is how it fits on. The spacer is glues to the heat sink with Arctic Alumina Adhesive.
pill1
The positive wire runs up through the heat sink & spacer and the wire is soldered to this copper contact. That's what the battery positive comes in contact with, when this sticks down into the body tube.
pill2
Also, you might notice that there is a sleeve around the 1/2" copper pipe section. The pipe is .570" and the opening at the threads is .620something, so I used a strip of .020" sheet, to take up some of the space.
red7
Wired and in place. The negative is bare wire and I just ran some solder on it, so it would run into the hole in the heat sink. Easiest way and it works.
red8
Here's how the other end looks. The center will be positive to the battery and the outer will be negative and will be what touches against the top of the body tube, where I cleaned off the ano. I used Arctic Ceramique where the heat sink sits down in the threads. It fills the gaps (if you push it into the threads well) and will help with heat transfer.
beam
It works! I will do a couple beam shots tonight.
It only takes just a hair of a turn from on to off. It's nice and bright with two alkalines. It can be run with two NiMHs, but it will be a hair dimmer. Just a nice smooth beam and a fairly simple scratch mod.
Good work…I like the way you think/work things out.
Would be nice resource to the build notes if you can add volts and tailcap amp draw for both fresh alkys and freshly charged NIMHs.
Where two batteries are used, I think the actual amp draw would be doubled for comparison to typical 1 cell draw, so you might want to post actual and then watts drawn.
That may be what was being asked in terms of meter readings over on the sale thread, rather than lux.
Putting two AA Alkalines together effectively doubles the voltage: less some loss because of internal cell resistance. Voltage further reduces as draw (amperage) increases. I understand that a 12V (6 2V cells) car battery might temporarily drop to around 7V when starting.
Check the technical details from battery manufacturer sites! A good AA Alki might be rated at 3,000mAh capacity at a [artificially?] very low 25mA draw. For the old-style 2AA torch with a draw around 500mA the capacity might nearly halve - giving the 3 - 4 hour runtime seen with a 2.2V 0.47A globe. However, the batteries still have a fair capacity left. You should get many hours further use in a small radio that might only draw 5mA.
Fully depleting the batteries in a small portable radio might reduce each individual cells voltage to 0.8V.
With the heavier torch draw a cell limit of 1.1V is indicated. So from a fresh Alki registering 1.6V it might be run down with a heavy draw to around 1.1V, but continue with a low draw down to 0.8 or 0.9V.
As a battery is used up the voltage for an Alki decreases & internal resistance increases. Manufacturers technical notes should highlight this.
EDIT: Apologies GottaZoom - from the sales thread it would appear that you are already aware of the above. :slight_smile:
No need . . I’m sure it will benefit some more than me . . that’s why I love the build threads . . I almost always learn or think of something new from the way others present info to us.
Old-Lumens,
Sorry to wake up an old thread… which particual TIR optic did you use for this build, can you check the SKU number, please?
