Test / Review: Samsung ICR18650-28A 2800mAh (Purple)
7 posts / 0 new
HKJ
HKJ's picture
Last seen: 39 min 24 sec ago
DSC_0041
Official specifications:
  • Place of origin : Samsung in Korea
  • Capacity: 2800mAh
  • Ultra-high capacity and premium built quality
  • Unprotected
Samsung%20ICR18650-28A%202800mAh%20(Purple)%204.3V-info
This battery is not the usual 4.2 volt charging, but needs 4.3 volt charging, i.e. a special charger must be used (Some hobby chargers can be adjusted for it).
DSC_0040
DSC_0042 DSC_0043
DSC_0044
DSC_0045
DSC_0046
Samsung%20ICR18650-28A%202800mAh%20(Purple)%204.3V-Capacity
The cell has a higher voltage than most other batteries.
Samsung%20ICR18650-28A%202800mAh%20(Purple)%204.3V-CapacityTimeHours
Samsung%20ICR18650-28A%202800mAh%20(Purple)%204.3V-Energy
Samsung%20ICR18650-28A%202800mAh%20(Purple)%204.3V-PowerLoadTime
Samsung%20ICR18650-28A%202800mAh%20(Purple)%204.3V-TripCurrent
Samsung%20ICR18650-28A%202800mAh%20(Purple)%204.3V-Charge
Test with 4.2 volt charging
It is possible and perfectly safe to use this battery with 4.2 volt, but it will have less capacity.
Samsung%20ICR18650-28A%202800mAh%20(Purple)-info
When only charging to 4.2 volt the battery looses about 220mAh in capacity.
Samsung%20ICR18650-28A%202800mAh%20(Purple)-Capacity
Samsung%20ICR18650-28A%202800mAh%20(Purple)-CapacityTimeHours
Samsung%20ICR18650-28A%202800mAh%20(Purple)-Energy
Samsung%20ICR18650-28A%202800mAh%20(Purple)-PowerLoadTime
Samsung%20ICR18650-28A%202800mAh%20(Purple)-TripCurrent
Samsung%20ICR18650-28A%202800mAh%20(Purple)-Charge
Conclusion
That is a good cell, but the requirement for a special charger to get the full benefit of the battery, does reduce the usefulness of it. Using it with a 4.2 volt charger negates any benefit of the higher voltage and capacity.
Notes and links
Edited by: sb56637 on 08/26/2014 - 17:45
f42
Last seen: 3 years 9 months ago
Thanks for the review, where did you get it from?
Nationalism is an infantile disease. It is the measles of mankind.
Albert Einstein
HKJ
HKJ's picture
In the info box check the "Supplier" line. Wink
f42
Oh good Smile I recently ordered it from Manafont too.
Albert Einstein
texaspyro
Last seen: 9 months 1 day ago
Charging to only 4.2V could extend their lifetime several times over… Car makers get their very long battery lifetimes by limiting the max charge/discharge depths (like to 80%/20%)
Ledsmoke
Ledsmoke's picture
Last seen: 11 months 3 weeks ago
Thank you very much for this review. I recently pulled some 2600 mAh brethren of this variety from a laptop battery and have noticed that they perform flawlessly in high current flashlight use. It is encouraging, to say the least, then to come online and see the battery review work-aholic par excellence confirm that Wink TY for another well composed and thorough review HKJ. It is much appreciated.
~ Ledsmoke ~
Dutch humor:
[quote=djozz]
 I do not think that the BLF-community ben
sb56637
sb56637's picture
Last seen: 6 hours 26 min ago
Thanks very much for the review! Frontpage’d and Sticky’d.
