Review: Crelant V9CS
61 posts / 0 new
Chicken Drumstick
Crelant V9CS
This is my first review, so please be gentle. And I apologise in advance for it being completely sub-par compared to most of the other reviews.
Anyhow, a while back I ordered a lovely looking Khaki green V9 T6 via eBay. HKEquippment (the seller) contacted me saying they couldn’t supply it and offered me a new V9CS instead. At the time I was disappointed in not getting the cool coloured T6, but I think I can live with it.
Order was dispatched on the 12th and today (24th) this was waiting on my return from work.
Some bold lux and beam distance claims from Crelant for the V9CS:
The flashlight, it’s a lovely grey anodising, currently the only flashlight I own this colour and I really like it.
In the box:
A note on the holster, while it appears well made having the combat grip ring on the flashlight makes it bloody hard work to get the flashlight in or out of the holster.
Very nice stainless steel bezel at both ends and a GITD O-ring behind the glass lens (nice touch Smile )
It’s happy tailstanding with no wobble at all. And stable headstanding, although you can’t tell if it’s on or not.
Some size comparison shots:
From the left
SIPIK SK68 EagleTac D25LC2 Mini Klarus NT20 Solarforce L2M (2012 Edition) Crelant V9CS Small Sun ZY-T13
(And Lucky cat in the background Big Smile )
From the bottom:
Small Sun ZY-T13 Crelant V9CS Solarforce L2M Solarforce 2600 18650 V3
A nicely centred XM-L U2 and SMO reflector:
UI
I have a couple of dual button lights now and I have to say this is my much preferred user interface. The V9CS is slightly different but seems to work well.
The forward tail cap clicky offers up momentary on as well as on/off. Nice positive feel with a firm click.
The side switch is electronic and feels rather different, not bad, just different:
The instructions are pretty lightweight, so I’m trying to figure out all of the modes. If you double click the side switch it gives you instant strobe. I really like this and is exactly how strobe should be; completely hidden, but instantly accessible should you need it.
Another double click offers up SOS.
A single click seems to turn the light off. (more on this in a mo)
Variable control – if you click and hold the side switch for about 3-4 secs the flahslight will start to dim. It will dim all they way to its lowest setting and back up to brightest again. It takes a little getting used to, but works well. And this really isn’t the kind of torch you need/want a moonlight mode on anyhow.
Memory – it does have a memory, if you dim the flashlight and then single click the side button it’ll turn off. Single click again and it’ll turn back on at the previous brightness. Use the tail switch and it’ll reset to MAX. This I like as it’ll be max every time you use it, then if you know you need less light you can tailor it to the situation.
Beam
I’ll add some beamshot later. For now all I can say is it has a very very tight hot spot, quite a narrow spill and is significantly brighter hot spot and spill than my Solarforce L2M with Solorforce XM-L U2 drop in.
The beam is completely artefact free, very bright concentrated hot spot, with a brighter corona then moving out to a nice even spill.
Conclusion
Very high quality feeling and looking machining and anodizing. It’s quite chunky and you’d certainly notice it in your pocket.
Very bright and lovely beam.
Brilliant UI – this alone is worth the money.
Edited by: sb56637 on 08/26/2014 - 17:20
Chicken Drumstick
Some more pics.
Disassembled
It has a handy candle mode, a bit glaring if you look at it directly, but offer great flood light should you need (photography maybe??)
And some beam shots, apologies I need a bigger back garden, but these will have to do until I can go further afield Big Smile
And added to the growing collection…. Smile
Further observations
Using the flashlight late last night I noticed it does make a humming/whining sound. I believe Crelants are known for this trait and the V9CS would seem no exception. It’s not that noticeable unless you have the torch near your head, but it is fairly evident when all else is quiet. Not sure if my DB meter will pick it up, but I’ll try and get a reading on it.
I’m also going to get some weight measurements taken. The V9CS really is a solid chunky feeling light. This is good for construction and I suspect heat dissipation, but it’s noticeable heavier than my p60.
kreisler
kreisler's picture
Last seen: 6 years 5 months ago
Nice review, congrats to it and the new flashlight itself!!
Smile
*FMI* i got 4 i/o sh
DON KIDIK
DON KIDIK's picture
Last seen: 7 years 5 months ago
Nice review pal,welldone.Now go get some beam shots,its dark out now,,,,take a canoe,its cats and dogs outside. Been mulling the model over myself.they do a nice job Crelant.
DON…ps,ya cats the double of ours, Molly.Called After my Grandma
jacktheclipper
jacktheclipper's picture
Last seen: 11 hours 10 min ago
Cool
pounder
pounder's picture
Last seen: 3 years 5 months ago
awesome thanks! can you get a quick tailcap reading on high? thanks
adyscarborough
adyscarborough's picture
Last seen: 6 years 2 days ago
Nice review Smile really like the look of that for around 30 quid, thought it was going to be much more expensive!
JohnnyMac
JohnnyMac's picture
Last seen: 2 years 6 months ago
Nice job on the review! That's a fine looking little light.
sb56637
sb56637's picture
Last seen: 6 hours 49 min ago
Great job on your review! You should be proud of it. Frontpage’d and Sticky’d.
SashiX
SashiX's picture
Last seen: 6 years 1 month ago
Nice light Big Smile Thanks for the review Wink
Slewflash
Slewflash's picture
Nice review drumstick Smile
But i think the box lied about the lux
Slewflash
Chicken Drumstick
Sadly not, for some reason my DMM doesn’t seem to work when trying to take a tailcap reading. Going to order a new one next week and I’ll do it then.
Chicken Drumstick
Thank you Smile
Langcjl
Langcjl's picture
Last seen: 2 years 1 month ago
nice review, thanks.
Piers said " ....but who wants enough light, when you have the option for far too much "
flashlight man
Last seen: 6 years 7 months ago
Looking good 8)
MattSPL
Nice review. Thanks Smile
edc
edc's picture
Last seen: 4 years 7 months ago
great work
http://i1193.photobucket.com/albums
TadpolePilot
TadpolePilot's picture
Last seen: 2 years 10 months ago
:bigsmile: Butt on your way too being Great! Crown
"Yell  {"Old, Broken Butt,  Zeide"}&nbs
pounder
pounder's picture
just ordered a neutral off sb flashlights!
fishinfool
fishinfool's picture
Last seen: 10 months 5 days ago
Don wrote:
"But as I said long ago, you are more likely to be killed by a dead fish dropped by a seagull in the Sahara Desert than by a lithium ion
EDCPlus
Last seen: 2 months 6 days ago
Nice pictures and review! Smile
Chicken Drumstick
New DMM ordered today, hopefully I’ll be able to take some tailcap readings soon.
Jinx
Jinx's picture
Last seen: 3 weeks 5 days ago
Great looking torch. Nice review CD, what meter did you get?
Chicken Drumstick
Only a cheapy one for now. Just want something that actually works, I’ll upgrade as and when.
MagPap
Last seen: 9 months 6 days ago
Nice review. Thanks
RAW74
RAW74's picture
You have nothing to apologize for….this was a great review.I really like how the UI of this lite works.By the way, I have acat with the same markings…besides yours,I haven’t seen another like her.I took her in as a local stray many years ago…although she is a bit bigger now(over-fed).Again……great review, thanks!
rikr
rikr's picture
Great review, and nice looking light!!
 New Collection / Old Collection
jorgemac
Great review.
This light has regulated output with 1×18650?
raccoon city
raccoon city's picture
Last seen: 4 hours 40 min ago
You're going to love it here, jorgemac!
Best0270
jorge
macbook
Chicken Drumstick
jorgemac wrote:
Great review.
Honestly I don’t know if it’s regulated or not. The predecessor V9 T6 didn’t seem to be according to a review over on CPF, but that light had a completely different UI, so I don’t know how different the driver might have been.
That said, I haven’t so far noticed any issues or visual dimming due to not being regulated.
pounder
pounder's picture
got my v9cs today
tailcap readings are 1.6 at 4.15v with a panasonic 2250..1.5 with a regular 18650..2 16340 is 1.1a so 2.2 at the emitter at 8.4v…far cry from the 2.5a claimed from crelant..would make sense though because their lux ratings are complete bs also..still really nice light that is sanely driven..it’s bright and will have good runtime..exactly what I wanted..still 2.5a would have been sane also and it could have always been dimmed..my 0.02$
