Good priced thrower at Manafont!
24 posts / 0 new
Budgeteer
Budgeteer's picture
Last seen: 6 years 9 months ago
Many are familiar with this one already. This time decently priced.
http://www.manafont.com/product_info.php/trustfire-usa168-q5-3mode-memor...
Also the head is not glued to the body and no silly resistor switch! Hurray!
Just screams for a r2 or XM-L transplant if stock form isn't good enough.
kragmutt wrote:
They're gonna send you a green redcat with a black LED.
Edited by: Budgeteer on 02/12/2011 - 13:06
Hrvoje
Last seen: 1 hour 5 min ago
Good price. Looks like the reflector screws into the body.
Don
Don's picture
Last seen: 3 years 2 months ago
That looks very much like the HS-801/802 reflector to me. So hopefully the same performance.
The numbers from my light tests are always to be found here.
https://spreadsheets.google.com/ccc?key=0ApkFM37n_QnRdDU5MDNzOURjYllmZHI...
Budgeteer
Budgeteer's picture
It looks like my HS-801. Very good one (reflector).
old4570
Last seen: 4 months 1 week ago
I tried a XM-L in my HS-802 and no joy .. Horrible beam ...
 Always remember , the easiest thing in the world to do , is to expel hot air from your lungs and through some vocal chords ..
The resulting sound may , or may not be worth listening too ….
Don
Don's picture
I managed to glue the emitter on mine quite a long way off centre. Visually centring it on the protector does not centre it on the reflector. The time to discover this is not after the mixture of epoxy and heatsink goo has hardened - thought 1 was using 1 hour work time stuff, turns out it was 5 minute stuff.
Unscrewing the head half a turn or so loses light but cleans up the beam a lot. There are plenty of threads to play with.
When I underexpose it enough, you can see that the LEd is off centre - but it started with a huge black hole in the middle of the beam.
Hotspot
Piers
I can't quite figure out how that fits together, does the reflector screw into the head?
Don
Don's picture
The reflector sits in the head, some pics may help.
Disassembled
The parts
reflector in
And is held in place by the lens and bezel
Head reassembled
The pill screws into the battery tube
Two bits
The head and body tub were glued together originally.
okwchin
okwchin's picture
Last seen: 15 min 44 sec ago
Glued... Thus why the marks on the parts... damn
"like everyone else - I’m looking for my next “last” flashlight" -  ohnonothimagain
Piers
Ahh I hadn't realised it was that light Silly
The reflector looked threaded in the Manafont photo, I guess it's just uneven tooling then.
Hrvoje
After a closer look, I would say it's not the threads but cooling fins, otherwise it would be impossible to assemble the head.
Boaz
Boaz's picture
Last seen: 4 days 7 hours ago
Don ...did you put this in the freezer ?
Before you started cranking away with the vise grips ??  ouch ..
 have you tried the freezer trick ?
Don
Don's picture
Yes - did no good at all - that glue was incredibly tough.
It's my first step for data recovery from dying hard drives. Works most of the time for long enough to get the data off.
Budgeteer
Budgeteer's picture
Very true. I practice that method alot. Saved alot of customers that way. I deep freeze them to about 35-40 degrees under zero (celsius). Peltier freezing them was unsucessfull most of the time and messy.
Andi
Andi's picture
Found a XM-L version on "bestinone": Brinyte C5 XML
unfortunately a one-mode, so driver should be chanched.
Budgeteer
Budgeteer's picture
Good find! Also a good price. I mode is preferred for me for such a flashlight but in case of a XM-L a lower mode would be handy to some.
krikstas
Last seen: 6 months 4 weeks ago
krikstas
I am in love with MRV Embarassed so maybe I should try Brynite C7
Andi
Andi's picture
But the "C5" / "uf900" / "hs-802" (all the same) has a 6,5cm deep reflector and should be a VERY good thrower.
I will get THIS ONE next 2-3 weeks, i´m curious about it Smile
fishinfool
fishinfool's picture
Last seen: 11 months 2 weeks ago
Looks cool.  Let us know how it turns out.
Don wrote:
"But as I said long ago, you are more likely to be killed by a dead fish dropped by a seagull in the Sahara Desert than by a lithium ion
Huge
Huge's picture
Last seen: 8 years 6 months ago
To the same 1A current flow output, XM_L linghts are having strong floodlight, choose it or not depends on what i use it for,strong floodlight should be the top choice for outdoor!
Flashlight may bring me a sunshine~
Andi
Andi's picture
I got mine....very fast delivery!
But wrong driver Sad
@high = 1,41A
now i must buy a new driver and chanche it!
p.s. the reflector is really impressive and hotspot is very concentrated.
edit: head is not glued and driver is: NANJG 101-AK-1A
but, in that case, the offer from bestinone + mode driver is cheaper Wink
Budgeteer
Budgeteer's picture
Sorry to hear that. It was probably rushed in production i bet in the factory looked like:
Dear workers... today we do a batch of XM-L equipped HS-802's
XM-L?
Yes...
Which driver? Should i put the one i use for all Cree Q3 or Q5?
Ummm... i guess
Ok
Good
Ahm... boss?
Yes?
What brand?
Umm... slap Brinyte on it.
Ok boss.
Andi
Andi's picture
LOL
yes, the flashlight has 5 modes how advertised, they nowhere write anything about mA Wink
Only put a XM-L in and done. ^^
