Pre flash problem on L2P and Intl Outdoor Drop-in
18 posts / 0 new
Woody
Woody's picture
Last seen: 1 day 8 hours ago
I wonder if anyone can help. I have a Intl Outdoor P60 (neutral) drop-in – 2.5A, in a 2012 Solarforce L2P host. I just noticed than when I switch through modes (forward clicky) I get a pre-flash on low.
Also, the low is very low – I’m pretty certain it isn’t the 5% or 3% advertised, but that’s fine. I would just like to get rid of the pre-flash, which is beginning to irritate me. Any thoughts?
scaru
scaru's picture
Last seen: 3 years 2 months ago
What do you mean by "pre-flash"? I'm guessing you're talking about it flashing on high and then going to low?
Woody
Woody's picture
Yes – I get a higher brightness going from mid to low – very short high “flash” before going into low mode.
scaru
scaru's picture
Then you need to replace the driver.
Woody
Woody's picture
Damn! Only just bought it a month or so ago, and haven’t really used it at all until last weekend. Ah well, I’ll have to live with it I guess.
I was hoping it might be the switch.
Thanks scaru.
Oldienea
Oldienea's picture
Last seen: 4 years 9 months ago
I have a Yezl zoomie that does exactly the same thing. It doesn’t bother me to much. I will not change the driver unless it goes poof.
noboneshotdog
Last seen: 1 day 16 hours ago
Hey Woody, probably an unrelated question, but did you find it difficult to screw the head tightly to the body with that dropin? I had to cut a curl off my large spring in order to get my head to fit the body without a gap. Havnt had any problems as of yet. Just curious.
Thier ain’t no bones in a hot dog. F. York
Woody
Woody's picture
Don’t remember having problems. I did get a new reflector for it from Hank, after problems with ringiness, and the new one doesn’t have the little washer at the bottom, which apparently isn’t a problem. I’ll have a better look.
edit>> No, it fits fine – screws all the way (and wrapped with some tin-foil).
noboneshotdog
Oh, good! Just wondering ij anyone else had that little quirk. The other thing I found W mine (3 amp) is when it gets hot it wont change modes till it cools. I cant say Im the happiest w this drop in but it is pretty decent.
Woody
Woody's picture
Yeah, I think it’s had a few changes since it was first highly recommended here.
Steve_the_Chief
Steve_the_Chief's picture
Last seen: 10 months 2 weeks ago
Woody, my IO dropin does exactly the same thing. I was also surprised by the low low mode, I guess it's about 1 lumen.
Don't know if it's intended to be that way, but at least I can tell you that yours isn't the only one of that kind.
texas shooter
Last seen: 12 hours 34 min ago
I’ve bought several of these dropins for lights I’ve been building. One of them also has a low so low its just enough to read a book and keep that night vision. It’s a 2.5 amp NW model, it reads 0.02 amps on low. Most of the 3.0-2.5 amps models I get 0.06-0.08 amps on low.
stevetexas
Last seen: 6 years 5 months ago
before you replace the driver. Poor cells can cause erratic performance.
My IO dropin works perfectly, it is from the 1st batch though.
noboneshotdog
Do you guys 3amp dropins not switch modes when too hot as well?
scaru
scaru's picture
Yep, as I understand it the reason is the heat causes the LED to be less efficient and then it won't light up on the lower modes.
whokilledJR
Shotdog, P60 hosts handle heat poorly, have you done anything to improve heatsinking? If you haven’t using soda can strips is effective:
http://www.candlepowerforums.com/vb/showthread.php?230854-Improving-heat...
One of mine also had some problems mode changing, and it was due to having too much pressure from the battery to driver, as you mentioned you can’t get the head fully screwed down? I had the same issue, however by using the above method you can lose the outer retaining brass spring which is what is causing that problem. Mine have worked fine since.
old4570
Last seen: 2 months 1 day ago
Dont worry about it !
One of my drop ins does that , its still alive , and its been over a year .. [ maybe 2 or more actually – lost track of time a bit ] Anyhow , if it should die , plenty of replacement drivers to chose from ..
 Always remember , the easiest thing in the world to do , is to expel hot air from your lungs and through some vocal chords ..
The resulting sound may , or may not be worth listening too ….
Woody
Woody's picture
I’m sure the battery is OK – tried it with Keeppower & Eagletac 3100mAh cells. It’s no big deal – the lower low is a reasonable trade off. I’m certainly not going to swap drivers unless it dies (not least because I don’t have the skill (yet).
