Is running NiMh to empty bad for the battery?
7 posts / 0 new
ezarc
Last seen: 7 months 1 day ago
Im not sure if its it has anything to do with it but I ran 4 eneloops until they were totaly depleted. The LED was basicly moonlight mode and I could stare directly into it and just see a faint glow.
Usually I wouldn’t run them til they are empty but I was doing a “runtime” test and fell asleep so when i woke up it was off but I turned it on again it just had the faint glow like I mentioned before.
I cycled them a few times and they are all close to 100mAh less than what they were last time I measured them and they have had nearly no use apart from that.
And if it is bad for them to run them to dead empty, then I guess remotes and clocks and Wii remotes and other things that use a very small amout of power that will run them til there is nothing left are also bad to use them in?
Anyway just wondering if I did any damage to the batteies or if maybe they just need to be put through the break in mode again. So is it something I should avoid or is it ok to run them empty regurally?
sb56637
sb56637's picture
Last seen: 1 hour 14 min ago
I asked a similar question a long time ago:
http://budgetlightforum.com/node/183#comment-2643
Sounds like it’s not good for a NiMH cell to run it down to 0, although unlike Li-Ion, at least it’s not dangerous to do so.
ezarc
Thanks sb56637, just the info I was looking for.
On another note, I asked in another thread over a week ago and didnt get any reply… According to this review of the Ti, a 1.5v alkaline will give 60 lumens for 1 hour and a 1.2v eneloop will give 31 lumens for 2 hours. Is this something to do with the driver in the Ti or is that typical of 1.2v batteries in other lights?
I wish I had 2 identical lights to compare side by side.
neverfeltbetter
Last seen: 3 years 8 months ago
I like this website when it comes to proper usage of NiMH cells:
It’s a german website but the translation seems fine.
click
sb56637
sb56637's picture
I’ve noticed that in most of my lights, an Alkaline produces slightly brighter output at first, but it starts to slope off. A NiMH produces slightly dimmer output (but not really significant) for a much flatter output curve. But the Alkaline will produce at least some light for a longer period of time than the NiMH.
NightCrawl
Last seen: 3 years 11 months ago
I think my mom did the ultimate hardcore test on two Sanyo NiMH cells. They were missing for like two years and were found in a lighting device.. both read 0.5V! I cycled them two weeks on the lowest setting of my BC700 and they regained a capacity of ~2200mAh (claimed capacity is 2600, I have two others that were treated nicely and gave me ~2500mAh)..
I guess you just cant ruin those cells.
garrybunk
garrybunk's picture
Last seen: 1 day 23 hours ago
Hmm. . . so you don't want to admit your mom is a flashaholic and you were born into it?  Hmm. . . I have a couch over here that I'd like you to lay down on and tell me all about it.  Smile
-Garry
My Bike Lights Thread, Optics (TIR) Comparison Beamshots, Diffusion Techniques
NOTE: Moving my photos from PhotoBucket to Flickr. PM me or post in the thread if you can’t see my images and need me to fix or send a gallery link. PhotoBucket images should remain visible until November 2018.
