Supbeam K40: A Quick Pictorial
61 posts / 0 new
MosesM
MosesM's picture
Last seen: 4 weeks 4 hours ago
Hey guys, thought I’d share some photos of what I just got a couple of days ago: the Supbeam K40!
I think there’s quite a lot of excitement around this light, which I got directly from the manufacturer.
Manufacturer specs:
Cree XM-L U2 LEDs with lifespan 20yrs of runtimes
Max 1147lumens output (3× 18650)
Output (select by magnetic ring):
Level 1 : 0.5lm(2000hrs)
Level 2 : 21lm(140hrs)
Level 3 : 146lm(22hrs)
Level 4 : 366lm(9hrs)
Level 5 : 620lm(5hrs)
Level 6 : 1147lm(2hrs)
Standby : 65uA
Strobe : 1147lm (4hrs)
Working voltage 4v – 13v
Max Runtime 2000hrs
Max beam 700meters
Peak beam intensity 75000cd
Aircraft grade aluminum body structure
Premium Type III hard anodized anti-abrasive finish
Ultra-clear tempered glass lens with anti-reflective coating
Momentary forward click tactical switch
Strobe mode for tactical and emergency use
Smooth reflector for max light output
Highly focus beam for maximum distance
Tactical knurling for firm grip
Streamlined body design
Mechanical reversed polarity protected design
Intelligent high efficient circuit for max performance and runtime
Intelligent temperature controlled light output for safety
Impact resistant 1.2meters
Waterproof : IPX-8 Standard (2meters)
Size 2017mm x 79mm
Weight 453g
Here’s the case it came in. I thought the brand name was hilarious. Still is Big Smile
The light came with a nylon holster, lanyard, spare o-rings and a tailcap boot, an instruction manual, and a fantastic warranty card Wink
Unsurprisingly, the threads and o-rings came pretty dry.
Nicely centered emitter.
The lens is AR coated and is approximately 3.5mm thick.
The 3 × 18650 battery carrier is wired in serial and should not have any problems fitting longer protected cells.
From what little I can see, I believe the emitter does sit on a copper MCPCB. EDIT: Just took it apart, it is a copper MCPCB, with just the right amount of thermal paste underneath (not epoxy). I’ll post more pics of the takedown another day.
The reflector measures approximately 69mm wide and 52mm deep, so it’s definitely not as deep as the TN31’s (64mm according to turboBB’s review).
DISASSEMBLY UPDATE:
The driver is easily accessible after unscrewing the three screws on the driver side of the head.
Here’s the topside of the driver:
Under/battery side:
Mode changes are definitely magnetically controlled, as evident by the eight small chips (Hall effect/magnetic sensors I’m assuming) in a semi-circle on the outer edge of the driver. The control ring’s magnet was strong enough to drag a small screw around inside…that was fun for a while :bigsmile:
This is the driver side of head sans the driver. Note the clean machining.
Here’s the emitter on a copper MCPCB Party This was one of the biggest deal-makers for me…I have a copper fetish.
All that copper makes me warm and fuzzy inside… Love
To quickly summarize, is it a TN31 clone? No, but pretty darn close. Will it throw as well as a TN31? No, but pretty darn far.
For the money, I’d say it’s an absolutely great value for what you’re getting.
I apologize for the lack of beamshots, I need to get a better camera Sad
PS. I didn’t want to derail Jake25’s thread since I didn’t purchase this light from him, I got it directly from the manufacturer instead. Also, Jake mentioned that the ones he’s bringing in will be driven higher on the max level, so what you’re getting from him might be different. YMMV.
UPDATE 24 July 2013: Someone asked me to measure the emitter-side reflector opening to see whether there was enough of the “flat space” to bore out for an SST-90. The answer is a definite yes, the diameter of the “flat space” at its widest is 22.7mm, and the reflector opening is 8.9mm.
Edited by: MosesM on 07/24/2013 - 12:16
jacktheclipper
jacktheclipper's picture
Last seen: 2 days 16 hours ago
Cool
scaru
scaru's picture
Last seen: 2 years 2 months ago
Thanks. Big Smile Makes me want Jakes light even more. How much did you pay?
MosesM
MosesM's picture
US$90 including shipping via DHL to Singapore.
Overclocker
LOL funny name. just lacks an “A” for supabeam!!!
Jake25
There’s a reason why I had to change the name :~
Yes my version will be driven at 3.5A and I confirmed with them that theirs is driven at 3.0A
Nice review Mose, you should show a picture of how thick the AR lens is, unless I missed it. That sucker is THICK!
Overclocker
waiting for the pics Smile
Bwolcott
Bwolcott's picture
Last seen: 2 days 10 hours ago
I got mine as well from Jake though and it looks more like the tn30 but with a single emitter
Youtube channel asilaydying1984
BanglaBob
Last seen: 2 days 17 hours ago
[/quote]
US$90 including shipping via DHL to Singapore.[/quote]
Whoa there, MosesM… You’ve whet my appetite at the worst possible time. I promised myself no ordering new stuff for at least 2 months Silly
D’yer think they’ll not print the name for an extra 5 bucks??
Lights out! That's when things get interesting...
bose301s
bose301s's picture
Last seen: 8 months 1 week ago
Or get a better version of it from a US dealer who posts on this site regularly for $18 more.
MosesM
MosesM's picture
First post updated with some takedown pics!
Woody
Woody's picture
Last seen: 21 hours 5 min ago
Nice work MoseM. Looks like a well made piece of kit.
@Bose – oddly enough for Europeans getting stuff from China is often less hassle (customs seems to take more of an interest in transatlantic parcels).
@BanglaBob – I tend to agree – the SupBeam name is horrible.
Still, interesting light – as is Jakes.
Chicago X
Chicago X's picture
Last seen: 5 years 7 months ago
Let's not forget that it's driven harder as well !
http://wardogsmakingithome.org/index.html
War Dogs, Making it Home - Rescue Dogs for Returning Vets
BanglaBob
I would if I could, but shipping costs from the USA is a killer! Something in the region of 50 bucks Sad
Woody
Woody's picture
BanglaBob wrote:
[quote=bose301 Or get a better version of it from a US dealer who posts on this site regularly for $18 more.
I would if I could, but shipping costs from the USA is a killer! Something in the region of 50 bucks :([/quote]
Just had a quote myself – $98 shipped to UK.
dlbelcher
Last seen: 6 years 2 months ago
Where do I get this light for $108?
I want one…
Bwolcott
Bwolcott's picture
Sbflashlights with the coupon code
Overclocker
way too many similarities with thrunite tn31. check out the pix from:
http://budgetlightforum.com/node/9801
and
http://www.forolinternas.com/viewtopic.php?f=5&t=4509
i’m starting to believe that supbeam is the OEM for thrunite. of course both parties probably won’t admit it. and of course supbeam will have to tweak around a bit with the CNC program so that the two won’t look too similar. the internals seem to be fundamentally the same, just tweaked a bit…
Overclocker
is this a K40 or a TN31??? don’t be misled by the color LOL
Overclocker
what about the MCPCB and plastic centering disc?
BTW i just received my K40. quality is excellent, easily at par with fenix, 4sevens, et al. way way way above XXX-fire levels. i would even dare say it’s a bit better than 4sevens…
Woody
Woody's picture
and
I think I agree. Supbeam states their OEM capabilities here . I realise that just because someone on the internet says something doesn’t make it true, but there’s too much of a similarity for it to just be a rip-off. Anyway, I’ve taken the plunge and ordered a Supbeam. Just need a bit of black duct tape to block out the horrible name Wink
Overclocker
here’s another supbeam product, the scorpion LOL
http://www.supbeam.com/p/58/t10-tactical-flashligth-infinite-brightness
view of the tail. someone please tell me this isn’t a Scorpion LOL
i’m convinced now. supbeam is indeed the OEM for a lot of thrunite stuff Glasses
Overclocker
aka the Thrunite T10
http://www.supbeam.com/p/56/120lums-cree-xp-g-led-l10#.UHhYgcVhwpk
http://www.thrunite.com/en/ProductsView.aspx?id=121
Quote:
Specifications: 1:Cree XP-G LED (R5) with lifespan of 50,000 hours 2:Four modes of output: firefly(0.09lumens 147hours) -> Low (30 lumens, 13hrs ) -> High (120 lumens, 1.5hrs) ->Strobe(120lumes,2.5hrs) without memory (Tested with Ni-mh battery with actual capacity 2500mAh) 3:Stable current regulated circuit, stable brightness 4:Uses one 1.5V AA battery (ni-mh, alkaline ). 14500 batteries are not recommeded, because they heat up quickly. 5:20-gram weight (excluding batteries) 6:Made of durable aircraft-grade aluminum 7:Premium Type III hard-anodized anti-abrasive finish 8:Waterproof to IPX-8 Standard 9:Toughened double ultra-clear glass lens 10:Reliable twist switch 11:Candle mode (Capable of standing up securely on a flat surface to serve as a candle) 12Size: 79mm(length)x17.1mm(dia) Mode switch: At tighten station of head.Screw the head(loosen then tighten)to have the output from firefly/low brightness/middle brightness/high brightness and strobe
Quote:
T10 Specifications:
- Cree XP-G LED (R5) with lifespan of 50,000 hours
- Three modes of output:High (115 lumens, 1.5hrs) -> Low (9 lumens, 39hrs ) -> firefly(0.09lumens 147hours) with memory (Tested with Ni-mh battery with actual capacity 2500mAh)
- Stable current regulated circuit, stable brightness
- Uses one 1.5V AA battery (ni-mh, alkaline ). 14500 batteries are not recommeded, because they heat up quickly.
- 17-gram weight (excluding batteries)
- Made of durable aircraft-grade aluminum
- Premium Type III hard-anodized anti-abrasive finish
- Waterproof to IPX-8 Standard
- Toughened double ultra-clear glass lens
- Reliable twist switch
- Candle mode (Capable of standing up securely on a flat surface to serve as a candle)
- Accessories: key ring.
- Size: 81×17mm
even the product descriptions are almost identical Glasses
Overclocker
Woody
Woody's picture
The Supbeam L10 isn’t a million miles away from the Thrunite T10 either. I think the firefly modes in many of their lights is a bit of a giveaway.
eddit>> woops, you are on the case!
dlbelcher
how about a link?
thanks
Bwolcott
Bwolcott's picture
I posted a couple size comparisons in this thread
http://budgetlightforum.com/node/12824
The Supbeam / k3 illumination k40 look like a tn30 reflector and led with a tn31 body and head the only difference I noticed was the tail cap
Bwolcott
Bwolcott's picture
dlbelcher wrote:
how about a link?
thanks
http://www.sbflashlights.com/L3-Illumination-K40-p255.html
coupon code blf10
AlexGT
AlexGT's picture
Last seen: 1 hour 39 min ago
is the reflector of the TN-31 and K40 the same size and depth?
MosesM
MosesM's picture
Nope. The K40’s reflector measures approximately 69mm wide and 52mm deep, so while the diameter is almost the same, it’s not as deep as the TN31’s (64mm according to turboBB’s review).
how2
Last seen: 4 years 2 months ago
Similar light?
L3 Illumination K40
No same as. Specs are almost the same.
