Review / Measurement: Charger module with TP4056 controller
146 posts / 0 new
verge
According to Cottonpickers, he is using the Linear Technology LTC4054 integrated circuit in his charger.
I googled the websites of the two companies Linear Technology (LTC4054) and TP Micro (TP4056),
http://www.linear.com/product/LTC4054-4.2 and http://www.tpmicro.com/goods.php?id=47 respectively.
The general description stated by the two companies are almost the same except for this part that was stated on Linear Technology’s description;
“When the input supply (wall adapter or USB supply) is removed, the LTC4054 automatically enters a low current state, dropping the battery drain current to less than 2µA. The LTC4054 can be put into shutdown mode, reducing the supply current to 25µA.”
TP Micro’s description states;
“When the input supply (wall adapter or USB supply) is removed, the TP4056 automatically enters a low current state, dropping the battery drain current to less than 2μA. The TP4056 can be put into shutdown mode, reducing the supply current to 55μA. “
The only difference is the 25µA stated by Linear Technology, and 55µA stated by TP Micro.
My question is, will there be significant difference, if ever, in performance with regards to the two chips?
Thr3Evo
Thr3Evo's picture
Last seen: 6 years 9 months ago
My version of implementing these boards:
More pictures here
Overclocker
Last seen: 2 years 1 month ago
would it be possible to mod this board to charge 4.30v li-ions?
HKJ
HKJ's picture
Last seen: 5 min 16 sec ago
You cannot change the 4.20 volt reference in the chip. Technically you could lift the 0 volt pin of the chip to 0.1 volt, but it is not a good solution.
Overclocker
henrik, what is your recommendation for cc/cv charging 4.30v cells? i want something i could leave overnight
HKJ
HKJ's picture
I am not aware of any good solutions for 4.30 volt. You can get a few 4.35 volt chargers.
Some hobby chargers can be used, because you can trim the voltage. In that case you could trim the LiPo setting to 4.30 volt and the LiIo to 4.20 volt.
I wonder if Kreislers dream charger will have that possibility.
furythings
Last seen: 9 months 2 days ago
Has anyone tried the 1.5a versions?
http://www.ebay.co.uk/itm/390683333577
Also if I stuck a 10k variable resistor as the current resistor could I then install one of those cheap led ammeters for checking the current or would that being there mess with the charging?
totilde
totilde's picture
Last seen: 12 months 22 hours ago
Hello. Does anybody know if it exists a module like this, but for charging LiIon in 2S configuration? Or should I use one of these cc/cv modules adjusted to 8.4v and one of these FT protected battery boxes ?
Mooooooo
CRX
CRX's picture
Last seen: 34 min 59 sec ago
I like these charging boards, i wired one of mine to a lipo volt meter and a male usb plug.
Also gave it the resistor mod which was a real pita.
The volt meter may not be totally accurate but gives a good idea of cell charge.
Is there a NIMH charging board like this one?
I’ve searched but could not find anything.
Helios-
Helios-'s picture
Nice mod crx.
Changing the current resistor isn’t hard if you reflow the board on a hotplate or stove. You can keep a eye on the temp with an inexpensive food thermometer. 0805 resistors fit ok on the pads. Needs just a tiny bit of solder paste.
FT 0805 3.9K-62K Resistor Pack
Counterfeit 18650s, 2,<a href=“http://
CRX
CRX's picture
Thanks for the tips.
I haven’t tried reflowing yet but it’s on the agenda, plus i have a gas cooker and no old pots…
What’s the temp range to aim for when reflowing?
Helios-
Helios-'s picture
I aim for as low as will flow my solder. Sn63 Pb37 should flow around 183°C.
Probably better to keep lead solder out of your kitchen if possible. People use a portable electric hot plate / stove or griddle. If you have any, a piece of scrap metal is usable instead of an old pot or pan. Could even try a flatened piece of a soda can aluminum if nothing else is available. Not sure if the heat on such thin aluminum might be uneven on a gas or coil electric burner. Worked ok on a flat top electric burner.
~ edit ~
Guess you don’t really need solder paste at all for this. You could pre-tin the new smd resistor with any solder. Then reflow the board, remove original resistor & place the new resistor while its hot with tweezers.
Helios-
Helios-'s picture
Recommend buying from Chip_Partner, ICs_Processors or RMM (usa BLF seller).
I just noticed there are now some boards on ebay with a different chip, marked “TP4056” but lack the stylized TP logo. Seems to be the cheapest $1 boards on ebay. Have to love chinese companies. Flat Stare
I would guess these chips (without TP logo) are likely Tapower “tp4056” chips. Pavithra_uk reports that he has one & it seems to behave different.
Original tp4056 NanJing Top Power chip. Datasheet
The chip that HKJ tested. Also pictures that others posted have all shown this chip.
I’ve bought from Chip_Partner and ICs_Processors for $1.54. Always received original tp4056 Top Power chips. RMM now has them for $1.42. Once brought a cheaper board elsewhere & got an unmarked chip. Was not cc/cv at all. I did get a refund tho.
vēer
vēer's picture
I didnt re-read the whole thread, so excuse me if this has been adressed already :D!
The question is – should the battery be connected to charger prior to plugging charger into electricity or not?
Im asking this because in both of of my TP4056 boards if I instert battery after they have been plugged into electricity then it will show it as fully charged(red led on) even though the battery is well below 4.20V.
When I put multimeters probes to test voltage then the blue LED will light up indicating that it has started charging the battery.
When I connect battery first and only then plug chargers into electricity, then it will seem to charge fine, however, not always, at least on one of the boards it might as well display battery as charged even after multiple attempts unplugging and plugging back into electricity outlet.
I suspect that Ive messed them up during soldering+accidental polarity swap while checking magnets might have ruined them :D!
sixty545
Last seen: 5 days 8 hours ago
It is good policy to power up the charger before attaching a battery to it. This is a must for my iCharger to avoid damaging the charger (according to an email from the German representative of the iCharger where he warns against the risk). Therefore I also do that with my TP4056 charger.
Likewise, the battery should be removed before turning off the charger.
HKJ
HKJ's picture
The TP4056 is supposed to work both ways.
In my test I usual connect the battery before I power the charger, because it is easier for me.
Helios-
Helios-'s picture
Vēer, do your boards have Top Power chips with the TP logo?
vēer
vēer's picture
Sure thing, the logo is there.
vēer
vēer's picture
I think I wont be using any of them, seem to be unreliable in this case Sad
Bright_Mike
Last seen: 3 months 4 days ago
Thanks for all the great info. I have bought several and some are labeled mini USB in the auction. some micro, so you might watch for that.
Also found this:
http://www.ebay.com/itm/TP4056-5V-1A-Lithium-Battery-Charging-Board-Char...
Much larger
Also can these be used with the solar panels labeled 6V300ma? How?
Helios-
Helios-'s picture
Those boards aren’t actually much larger, just longer & a bit narrower.
But I can’t see the TP logo on that one. Doesn’t look like the original tp4056 NanJing Top Power chip that HKJ tested. See post #43.
Instead the markings look like they might be 4056ES A1319N. Some kind of symbol or logo seems to be before A1319N. It could be yet another clone chip. Unless you can test it and chart its charge profile I would just stick to the original chip (stylized TP logo) that HKJ tested.
The datasheet for the NanJing Top Power chip claims a max input voltage of 8 volts so 6v should be fine.
Just connect positive from the solar panel to IN+ (next to the usb jack) on the tp4065 board, solar panel negative to IN-. Do not use the usb jack if the solar panel is connected. You could use a couple 6V300ma solar panels to charge faster. Check with a multimeter that the solar panel are actually providing enough voltage & current.
Bright_Mike
Has more components in addition to the 4056 chip, and costs a bit more. Wondering what the diiference is.
The board cuts the power at 5.5V but I don’t know what that solar panel delivers. Wonder if I could cover part of the board , if V too high, or does that cut A?
Helios-
Helios-'s picture
At 5.5V the tp4056 board did reduce charging current in HKJ’s tests but that was a tp4056 board being supplied with 5.5V @ more current then your 300mA solar panel. Probably over 1000mA.
At lower currents it shouldn’t heat up as much (it gets rid of extra voltage as heat) & shouldn’t need to reduce its charge current.
The 2 extra components are just jumpers. Marked “R1” and “R5” in white text on the board. Marked “0” on the components. They are jumpers / zero ohm resistors.
There is one thing this board does provide that the other one doesn’t. It has a point to connect to the TEMP pin. Requires extra components to actually use that though. NTC thermistor & a proper resistor to set the temperature cut off.
Bright_Mike
Thank you for the all the information. Would be interesting to set one up to shut off at a certain temperature.
Thought about it, It makes a lot more sense to start out with a couple solar panels and see how it goes. I might start with 2, if I get 250 ma or more, maybe just connect one. If I get less than that, maybe 2 in parallel to double it. I could leave it outside, I suppose, as long as I shaded the board & battery.
How much amperage could I run through this? Saw 1200 ma in the data sheet, although it might be hard to keep cool at that, especially over 5 V.
WarHawk-AVG
WarHawk-AVG's picture
~ edit ~
Actually when I reflow mine (I have a hotair rework station) I just snag the old RProg resistor off with a pair of needle nose tweezers, then lay the replacement resistor on the pads, there is enough residual solder for it to stick and bond no problem.
Also gotta be careful with some of the square TP4056 boards [longer rectangle ones seems 0805 standard], the RProg resistor is a 0603, the 0805’s will fit but you have to be a bit more careful on placement
This is the board I changed for fellow board member woolfam, not the most beautiful solder job, but I tested and they too were pushing a clean .53A and .48A respectively with a 222 resistor on RProg
Changed the 122 [1.2K resistor = 1A] to a 222 [2.2K resistor = 500mA~] Tested, was pushing .53A to a 3.6vdc battery out of the USB module into a repaired Xtar MC1 slider housing
I can confirm at 1A charge the TP4056 gets VERY hot, burned my finger when I put it on it to see how it was doing, at 500mA…warm but not leave a mark on my finger.
WarHawk-AVG
The MCP73831 can do 4.20V, 4.35V, 4.40V, 4.50V depending on the chip version (4.20vdc is MCP7383X-*2* 4.35vdc is MCP7383X-*3*)
http://pdf1.alldatasheet.com/datasheet-pdf/view/195329/MICROCHIP/MCP7383...
And I have a DIY board on OSHPark too Wink
https://oshpark.com/shared_projects/NclO046F
mouser
http://www.mouser.com/ProductDetail/Microchip-Technology/MCP73831T-3ACI-...
Digikey
http://www.digikey.com/product-detail/en/MCP73831T-3ACI%2FOT/MCP73831T-3...
Helios-
Helios-'s picture
WarHawk, I see two different “4056” chips. Love how china makes clones of clones. Flat Stare Might want to check the current a few times throughout a charge cycle. Check that the current tapers off at the end & appears to do some kind of cc/cv. Also that it terminates well without trickle charging.
I had an unmarked 4056 clone that was trash. No attempt at cc/cv. Over 4.27v.
Perhaps these “4056” clones should get a separate thread since they are not the chip HKJ tested.
Overclocker
mouser
Digikey
thanks for the links! yep i’ve checked out that chip already. no 4.30v option
Bright_Mike
My solar cell arrived yesterday. Got 7 V and 350 ma with direct sun& haze seems to be charging now!!!
I soldered leads to the board and solar cell then attached the wires with alligator clips. Should make it easy to put it back in mini USB 5V.
My board has no logo. Seems to work OK but cuts off around 4.10 V usually.
A US penny will fit on the back without touching any connections for heatsink. I just alligator clipped it. Didn’t seem to need it though. Didn’t sand. Only got up to 550 ma or so on mini usb. Assuming i measured it right, 850ma listed usb oem phone charger.
A friend told me solar runs off IR, which gets blocked by haze. So I might have to keep an eye on V. However I think the board may be controlling V.
WarHawk-AVG
