Best possible quality, more powerful light the better… and Under £50 and must be smaller/same or slightly bigger than my current TrustFire R5-A3 torch… This will be my pocket torch for everyday use
How do you mean by rechargeable? Do you just mean uses rechargeable cells?
If so do you have a pref on form factor?
If you want more throw something XP-G will be the best. Nitecore EC1 or EagleTac D25 Series are some nice lights.
For lots of lumens XM-L might be the way. I personally like the look of of the Niteye EYE 10 and 15.
Klarus do some nice lights too. All should be available for £50 or so.
Rechargeable batteries i should have said :bigsmile: when i say £50 max i should have also have said as cheap as possible with options going up to no more than £50 …
Ok.
Do you want throw or flood? Max brightness or run time and what sort of modes; moonlight, strobe etc.
Solarforce L2M with a SF XM-L U2 running on one RCR would make a chunky but hugely capable budget light (less than $30).
Nitecore EC1 can be had for £35-38
If you want nice even flood I like the Trustfire Z8. UI is a bit pants and it’s quite a cool white but they are £11 or so inc delivery from Tmart.
I’d still recommend EagleTac’s. I think my D25LC2 was £38-40 and it blows all of my budget lights away as a complete package. You really can tell the quality.
Tbh i dont know much about torches but all i know is i want a torch like the TrustFire R5-A3 i currently have but with better battery life and if possible but not necessary stronger light and no bigger if possible…
Balder SE-1 XML 3C tint .
+1
Also try “xeno e03 v2” Is a good one. I have this and waiting for SE1 when I have some extra $
Thanks for joining, vxlomegav6!
