Maglite 2D - 3XM-L T6 - TIR optic, 8AA - Build thread - Beam shots in Post#36
44 posts / 0 new
Old-Lumens
Old-Lumens's picture
Last seen: 3 years 3 months ago
I am using a 2D Black Maglite to make a 3up XM-L T6 with a TIR optic. Remember I asked what the 50mm optic I had, was for? Well it isn't XM-L, but it's going to be anyhow.Tongue Out
3up1
I'm using a 2D Incan Mag and I am going to use the 3up star with copper backing it up. I don't have any solid copper rod, so it's 20ga sheet sandwiched into a 3.something mm plate. I still have to clean up the plate later on. This is "WIP", LOL.
3up2
The plate is four pieces soldered together.
3up3
It all sits down on the inner lip in the Mag head. I had to cut down the star to fit the ID of the head.
3up4
The stack up fits good. I will use a glass lens over top of the optic and I'm not sure yet if I will leave the optic frosted or if I will polish it and make it clear. Once it's together I can see how the beam is and decide.
3up5
The aluminum heat sink will be screwed to the upper star and copper plates, so it will all be nice and tight.
3up6
3 - XM-L T6 3C emitters and 3 NANJG drivers, as well as two 4AA holders. I need to bore the body and remake the holders for 4S/2P. I still have lots to do...
Later..........
I've gotten a little more done this evening.
3uptir
The TIR optic was frosted, but I had two, so I polished one. This way I can see which one works the best. Polishing was done with 1000 grit sandpaper and spit. Yes, spit, for a wet sand. Works better than water. Yes, I cleaned it afterwards... On my pants leg.Tongue Out   After that, I used MAAS polish. Came out pretty good.
star1
LEDs on the star. They are glued on with AA.
driver1
Drivers are wired up.
switch1
The switch is a combination of a Maglite housing with a Judco 10 amp switch inside it.  The Mag shell has to be opened up, to fit the Judco and then a shelf has to be made, for it to set on. The photo below shows that. Now that it's in place, the whole thing will be filled up with epoxy, to hold everything nice and tight.
switch12
The bottom side shows the plastic bushing. It is a hard bushing and is a squeeze/press fit, to make a shelf for the Judco to set on.
That's it for tonight, time to get some rest...
 Well, I went ahead and changed the copper heat sink, by adding enough thickness, so I could eliminate the original star. Now it's all copper under the leds.
123q
The copper plate weight 2.6 ounces now and the whole heat sink, copper and aluminum, weighs in at 5 ounces.
213q
The drivers are mounted to the bottom of the aluminum heat sink.
312q
Looks like I got a little wiring to do here...
w123
The switch is ready. I used Epoxy to fill in around the Judco switch. It won't move around at all now.
w123
wq23
The contact for the batteries is copper, but I coated it with solder, since copper tarnishes very fast and you won't be able to clean the contact. Solder will tarnish too, but it's slower.
That's it for now, more to come, getting close now!
Well, I got everything finished up between last night and this morning. It Works!
The battery holder is two of the 4 AA holders put together and modified for 4S/2P, with copper contacts.
b1
b2
b3
b5
tcs1
 Tail cap spring mod with copper braid.
tirf1
tirf2
 Frosted TIR and the beam. I didn't have the right camera out here, so the shots were not in manual. I just did it to show the difference in frosted and clear.
tirc1
tirc2
 Clear TIR and the beam. I didn't have the right camera out here, so the shots were not in manual. I just did it to show the difference in frosted and clear.
Mouseover
mouseover
 The frosted is first, the clear is on mouseover. The clear has a large dead spot, the frosted does not.
I will be doing some beam shots tonight and I will compare the frosted to the clear.
I still have some cosmetic mods to do... mebbe...  but the light works! The master driver is one that E1320 changed the program on, so it's five mode. The battery pack tested to 5.07 volts before I used it.
The amp draw on High was 7.5 amps. It started out at a little over 8 amps on turn on and then settled to 7.5 amps, so it's no mega light for sure. I would imagine it doesn't put out more than 1500 lumens with the frosted TIR and probably about 1600+ lumens with the clear TIR.
It's not a mega light and if you want lumens, then you're better off with a Dry. I just don't want to mislead, I don't care about the lumens, I care about the build and how I did it and that's all.
In 30 seconds, the head was heating up, in 1 minute, the body was heating up, where I had my hand holding the light. In 2 minutes I shut it off. Not too hot to handle, but hotter than I would want to run a light. Obviously the copper heat sink is getting the heat out to the head and body, so it's working as it should. I figure the TIR will be the first thing to melt. The legs of the TIR sit in the copper plate, so the legs will probably warp before anything else does. (If the light is left on high till the batteries run out that is).
Beam shots tonight...
My PayPal address: oldlumens (insert the @ sign here) gmail.com
My YouTube Flashlight Video Channel
The BLF Modding Links Thread
http://imageshack.com/a/img922/1374/jQ2wdL.jpg
Edited by: Old-Lumens on 10/18/2012 - 03:13
NightCrawl
Last seen: 4 years 1 week ago
That looks interesting and promising. Wink
jamio
Last seen: 1 year 1 month ago
AA in the title always attract my attention Smile  Seems to be a very nice project Old-Lumens, Mag with 3x neutral white xml's, 8AA in custom built holder, I'm looking forward to how it'll continue!
JohnnyMac
JohnnyMac's picture
Last seen: 2 years 4 months ago
Agreed! Can't wait to see how it performs.
Old-Lumens
Got a little more done, see first post, now it's time to rest...
janko.hrasko
janko.hrasko's picture
Last seen: 1 year 3 months ago
why did you glue the xml stars to that big star anyway? you’ll get more thermal resistance afaik
Slewflash
Slewflash's picture
Last seen: 1 year 8 months ago
So this light is favoured more towards flood?
This looks like a turbocharged TK45! Can’t wait to see it in action OL.
Slewflash
benz
benz's picture
Could you please give a little more detail on how the drivers are wired up?
Old-Lumens
janko.hrasko wrote:
why did you glue the xml stars to that big star anyway? you'll get more thermal resistance afaik
I was lazy. I didn't want to cut another two of those copper rounds (blisters) and I figured I would just use the plate. I know it's better to not use it.
Old-Lumens
http://budgetlightforum.com/node/7272#node-7272
Old-Lumens
Slewflash wrote:
So this light is favoured more towards flood? This looks like a turbocharged TK45! Can't wait to see it in action OL.
Should be floody, but with two optics, one clear and one frosted, at least I can test them both out on the same light and have beam shots of both.
MosesM
MosesM's picture
Old-Lumens wrote:
I was lazy. I didn’t want to cut another two of those copper rounds (blisters) and I figured I would just use the plate. I know it’s better to not use it.
I know it’s probably too late for this suggestion, but I would’ve heated up that triple MCPCB to remove the white solder mask, sanded it down a little, then you’ll have a blank aluminum plate.
Good luck with the build anyway! I always look forward to your builds Smile
Old-Lumens
MosesM wrote:
I know it's probably too late for this suggestion, but I would've heated up that triple MCPCB to remove the white solder mask, sanded it down a little, then you'll have a blank aluminum plate. Good luck with the build anyway! I always look forward to your builds :)
I went ahead and cut two more copper plates and now the T6 led stars are on copper, no aluminum board.
Wink
nofearek9
nofearek9's picture
Last seen: 3 weeks 1 day ago
nice project.
Old-Lumens
More photos added in the first post. The leds are on copper now and it's shaping up well.
JohnnyMac
JohnnyMac's picture
Looking good, Justin! Cool
gords1001
gords1001's picture
Last seen: 1 year 9 months ago
8)
I love your work Justin.
Slim Pickens
Slim Pickens's picture
Last seen: 2 days 55 min ago
Copper, on copper, on copper. That’s hot!
Pavithra_uk
Pavithra_uk's picture
Last seen: 2 days 4 hours ago
nice build Smile
what adhesive you used for mount LED to copper ? Arctic alumina ?
Old-Lumens
Pavithra_uk wrote:
nice build Smile what adhesive you used for mount LED to copper ? Arctic alumina ?
Yes
Rufusbduck
Rufusbduck's picture
Last seen: 1 year 3 weeks ago
Is that a Ledil Rocket or a knock off?
Scott
Old-Lumens
Knock off, as far as I know. They are made well, but they don't look like any current "big name".
Old-Lumens
The light is working. Beam shots tonight. Photos in the first post, show the rest of the build.
scaru
scaru's picture
Looking forward to the for sale thread. Big Smile I don't think you will be melting the TIR optics anytime soon, PILOTPTKs module also has them resting on copper and the body of my light got uncomfortably hot and the TIR optics were fine.
garrybunk
garrybunk's picture
Last seen: 1 week 2 days ago
O-L, beautiful!  However, the mouseover isn't working for me.
-Garry
My Bike Lights Thread, Optics (TIR) Comparison Beamshots, Diffusion Techniques
, MTBR’s Lights & Night Riding Forum
NOTE: Now hosting my photos from my Google account. Post up if you can’t see them. Older photos hosted on Photobucket or Flickr may disappear (PM me if you want access to them).
texaspyro
I would solder the braid on the next loop down on the spring (at the point the top loop ends). You should get a lot more contact area and lower resistance that way… the way it is soldered now you probably only get contact at the bump in the braid.
Old-Lumens
-Garry
It does now.
garrybunk
garrybunk's picture
Yep, works!  Thanks!
-Garry
Slewflash
Slewflash's picture
Beautiful work with the 219s OL. I still use my nichia 2AA maglite everyday because of the tint. Whoever gets this will be one lucky duck!
But i think lumens will be around 800 because these are 219s we are talking about, afterall.
Slewflash
borstar_micke
Last seen: 2 years 5 months ago
Slewflash: In the 6:th picture from the top you see 3 xm-l:s, 16mm I think.
Old-Lumens
Also states that in the title and description. 3 XM-L T6.Wink
