Hey all,
Figured seen as I was going to start posting around here I’d just show an old project I did and posted about over on CPF. I’m sure 99% of folks frequent both forums so this may be nothing new. No harm in showing it again anyway! Hopefully some one sees it for the first time and gets a kick out of it
It’s a 3D mag running a pcb-components.de ‘Senser Extreme’ Boost Driver modified to provide 3.05A to 7 series connected XM-L-U2 emitters. This setup is controlled by the stock switch and ‘Nano Dim V2’ dimmer module (another pcb-component.de product) connected to a 10Kohm pot. The whole rig is powered by a custom built battery pack that utilizes parts taken from a special battery adapter, some PVC tubing and a 2000mAh LiPo 3S battery pack capable of up to 25C discharge. Given this the driver steps 11.1V up to nearly 25V it pulls over 8A from the pack…still yet to do any measurements though. The lens is borofloat because of the heat which you can clearly feel holding the front 15cm from your hand. The optics are a Cree 7 point 12 degree optic.
The pot cover was custom machined but the most important part however is the 100% pure copper heat-sink (which was also custom machined). I designed the heat-sink to fill the entire head of the stock maglite and it fit like a glove. The 4 screw points help with keeping pressure in the head.
Everything is connected with high temp silicone wire. There’s barely any room to move inside the body and head the tolerances are that tight. Anyway….more pics. Sorry if they are a bit small. I had so much I wanted to show but needed to keep the pic sizes and number down.
I had to modify the driver to output 3A….I was pretty nervous doing this as it’s a $50+ driver. I had to mount that 0.1ohm resistor on top of one that was already under the inductor (which had to be removed to get to it). The only issue with this driver is that no matter what brightness I have set before switching it on, it flashes at full power very quickly (not even half a second) before settling to the pre-set level. It’s not too bad, but I have hurt my eyes more than once now…and scared the poo out of a few people I forgot to tell:
Modifying the mag tube, making a collar for the pot (hand filed) and installing BVH’s cover:
Modifying the stock switch, installing and wiring the PWM board and installing the whole lot into the mag tube (No idea why but I put grip tape below the PWM board for some reason):
The heat sink, drilling and taping the mag head for the screws, and test fitting:
Wiring and installing it all up (thermal paste is holding the driver in place), the LiPo pack:
Beam shots. XM-L @ 2.8A left, my mag on the right:
Same as above:
The video below was shot on an iPhone 4S, and the patio light was on. Stock LED MagLite first, then a modified 2.8A single XM-L on low before turning that up high. You can tell when mine turns on It throws damn far as well but only because of pure grunt, so in the yard shot it looks almost like 100% flood. It’s not. The iPhone auto balances it’s metering as soon as mine turns on, so it tones down the difference considerably. Go to 1 minute in to see my light turn on.
Because I can’t get the ‘insert video’ code working you’ll have to click this link
I put a lot of time and money into this project so for it to turn out better than I hoped for is very rewarding.
Thanks for looking!
- Matt
