Maglite 6D
18 posts / 0 new
jb1
Last seen: 3 years 9 months ago
Maglite 6D
I have an old Maglite 6D cell flashlight. Are there any conversions that I could do to make it worth using or is it just a small baseball bat?
old4570
Last seen: 4 months 1 week ago
I put a 8.4v driver in mine and made it XP-G R4   , still runs D-Cells ..  Accident'ly put in a 3 mode driver [ Hi-lo-strobe ] , will put it a 5 mode one day [ have it in stock ]
 Always remember , the easiest thing in the world to do , is to expel hot air from your lungs and through some vocal chords ..
The resulting sound may , or may not be worth listening too ….
jb1
old4570, are these parts that can be easily changed out by someone that's never changed out flashlight guts before? If so, where would one purchase an 8.4v driver for Maglite 6D, XP-G R4 and a 5 mode driver?
Match
Match's picture
Last seen: 4 years 2 months ago
In that case, one of the easiest, and brightest upgrades you could do would be to drop in a Fusion 36 module from ebay.  It's $25, and as easy as swapping out the bulb.
-remove bezel
-remove reflector
-unscrew light bulb holder and replace the little retaining ring
-drop in fusion36 module
-reinstal bezel
-Serve, and enjoy!
I've got one on an old 3D maglite.  It's a very nice floody beam, yet somehow manages to have a decent hotspot.
You're only other option is to send it to me so I can try a 5x XML maglite build (I've been looking for a 6cell....)Tongue out
jb1
-remove bezel
-remove reflector
-reinstal bezel
-Serve, and enjoy!
match, that LED head looks nice & easy. BUT, let's talk about this 5x XML build. Cool  I also have a 5D cell "Legend" gathering dust as well. I'm not sure if that one is Maglite or if, in fact, Legend is a brand. They look very similar FWIW. Edit again - it appears that it's a Brinkmann Legend 5D cell flashlight.
old4570
I moded mine to run D cells [ DRY or Alkaline ]
Its low current draw , and drives the XP-G emitter more than hard enough ..
Also turns it into a serious thrower ...  If you like that sort of thing .
http://www.dealextreme.com/p/3v-8-4v-5w-cree-5-mode-memory-circuit-board-for-flashlights-16-7mm-6-3mm-26108   Driver ... 5 mode .
Then you will need a heatsink to glue the emitter to ...
You want a XP-G on a 10mm board [ no larger than 12mm ]
Wiring is easy enough ..
You need to pull out the switch / battery plug assembly in the maglite ..
Pull off the rubber switch boot .. then you need the correct Allen key to loosen the locking screw .
Might be easier to head over to CPF and check out the mod section , quite a few DIY guides there .
You need to do some cutting / soldering and gluing .. And you need the right glue and parts ..
Do some research over at CPF and you will see its more about buying the right parts and then doing a assembly job .
jb1
old4570 - thank you for links and info. I'll go do some reading over there. I'll holler back if/when I have some questions. Your knowledge is greatly appreciated!
fishinfool
fishinfool's picture
Last seen: 11 months 2 weeks ago
Great idea Match!  jb1 sends it to you, then you mod it into a 5x XML Super Maglite and after that all you have to do is send it to me so I can test it out.
It's a dirty job (5x XML Super Maglite Tester) but somebody has to do it.:bigsmile:
Don wrote:
"But as I said long ago, you are more likely to be killed by a dead fish dropped by a seagull in the Sahara Desert than by a lithium ion
FlashPilot
FlashPilot's picture
Last seen: 1 hour 30 min ago
I have a 3 x XML mag and its actually to bright most of the time. I never thought Id say that about any flashlight. One thing about the D mag - if built with an appropriate heat sink, the host has a lot of mass and surface area so it takes a long time to heat up and transfers heat well.
edc
edc's picture
Last seen: 4 years 8 months ago
The fusion 36 drop ins are good. I stuck mine in a 3d mag with two 14500's and bolt for a blank battery. Its a serious light now
http://i1193.photobucket.com/albums
Match
Match's picture
FlashPilot wrote:
I have a 3 x XML mag and its actually too bright most of the time...
Blasphemy!
okwchin
okwchin's picture
Last seen: 16 min 23 sec ago
Too bright is only a problem to eyes adjusted to night time. However my SST-50 18watt light I thought was too bright when I started using it, now its just Meh, want more lumens!! (Or maybe its just blindness setting in, (seriously though, it prob is))
"like everyone else - I’m looking for my next “last” flashlight" -  ohnonothimagain
jb1
Supernova = too bright
3XM-L = not too bright
Laughing
moniac
Last seen: 8 years 2 months ago
Boaz
Boaz's picture
Last seen: 4 days 7 hours ago
He's a moniac moniac .....flash dance ....
scruffy dog
Last seen: 5 years 1 month ago
Hi Moniac
welcome to BLF thanks for sharing nice mod
Match
Match's picture
LMAO!  You just aged yourself with that 80's movie reference.
fishinfool
He's a moniac moniac on the dance floor.  Hey now, that was a pretty good 80's movie.:8)
Aloha and welcome to BLF moniac!
