New Sky Ray King Driver?
26 posts / 0 new
rjorge
rjorge's picture
Last seen: 1 year 9 months ago
Hello all,
Just received my Black Sky Ray King from Ric along with 4 Keeppower 3400mah 18650 batteries. I took it apart to take a look at the driver and this is what I found:
It looks different than what I have seen ppl posting on here. The batteries are currently charging, but I did check the modes which are LOW, HIGH, OFF and hold for STROBE.
scaru
scaru's picture
Last seen: 2 years 10 months ago
Yeah, that is a simplified driver that IIRC is DD on high and may need new wires for max current (10 amps).
DrJones
DrJones's picture
Last seen: 3 years 5 months ago
Yes, that’s a direct drive driver with PWM for modes. I don’t like these.
Where can one get a NW King with the old driver?
rjorge
rjorge's picture
I will attempt to check the current draws and see how this simplified version compares to the other version going around.
Btw, the driver is held down by a threaded ring and the two red thinner wires go to the e-switch.
gords1001
gords1001's picture
Last seen: 1 year 3 months ago
Looks like its seenvson serious heat during soldering but the blobs still look like dry joints to me, might just be due to camera flash though.
Pavithra_uk
Pavithra_uk's picture
Last seen: 5 months 6 days ago
This driver Driect drive 100% mode and other modes uses PWM
Maximum current depend on battery conditions.
Pavithra_uk
Is this what Ric said "improved build quality" ??
feilox
Last seen: 3 months 1 day ago
Do you have the old sky ray king? So this direct drive driver is bad?
Don wrote:
It sounds like the XM LEDs won’t really be suitable for flashlight use. Pity…
texaspyro
It’s potentially horrible… there appears to be no way for it balance the currents to each LED… and I seriously doubt that they matched the LEDs for Vf and I over the operating temperature range.
DrJones
DrJones's picture
Can you post a picture from the bottom side of the driver, please?
Jell
Last seen: 3 years 3 months ago
I have the same question.. Which one is new and which one is old?
texas shooter
Last seen: 2 hours 39 min ago
The head with the 4 set of three holes in the outer ring appears the newest model.
DrJones
DrJones's picture
Yes,
upper image: old buck driver,
lower image: new direct drive driver
Thanks for the images! Smile
metalhammer
Last seen: 6 years 10 months ago
Hi Guys,
I just got a new Sky Ray King ‘black’ from Ric and it seems to use the old good driver Wink
… anyway one of the LED doesn’t power on so I’d like to give a look at the wiring just in case something got loose.
I’ll appreciate your help in disassembling the driver circuit since I’ve no clue where to start from !
lionheart_2281
lionheart_2281's picture
Last seen: 3 hours 28 min ago
metalhammer wrote:
Hi Guys,
Good to hear RIC is sending out faulty flashlights…
adyscarborough
adyscarborough's picture
Last seen: 5 years 4 months ago
hmmmm, i have one of these on the way. wonder which driver ill get?!
metalhammer
Fingers crossed then, hopefully the driver should be the good one … and everthing should work as expected.
adyscarborough
was yours out of the second so called higher quality batch just out a couple weeks ago??
Lumitoid
First post here, long time C*F member. Can you hold the Sky Ray King in your hand on high for extended time? Is there a way I can be sure to get the old style driver when I order? and last what brand batterys are best to use. Thanks
adyscarborough
1. i think 20 mins or so and it will be getting quite hot….
2. i have one coming this week and im keen to know which driver i will get :~
3. im going to be using xtar 18700 2600mah batteries in it, any quality cells should do id say as long as they are all same make and mah.
dorpmuller
dorpmuller's picture
Last seen: 2 years 3 months ago
That’s that damned lead free solder… f*****g greenies thanked for that. First thing I do is fix the joints with real solder.
Rich
"I am the flashlight king! I can light anything!"
Jell
Just PM Ric from CNQG.
I think the sanyo 2600s works great in the SRK, or u may get some protected ncr18650b, the intl outdoor’s version is a good one.
WarHawk-AVG
WarHawk-AVG's picture
Last seen: 2 weeks 6 days ago
Just stumbled across this...
http://wallbuys.com/Product/3-7-4-2V-3-Mode-CREE-T6-Driver-for-SkyRay-Ki...
But it says max rated 800mA...not sure if I like that
comfychair
comfychair's picture
They are not 800mA, it's the same driver used in the real SRKs and does around 2.4A per channel.
WarHawk-AVG
Nice so that stupid neutered driver I got in my SRK for $30.99, this will "perk" it back up...or burn it out
Serp
Serp's picture
Last seen: 3 weeks 1 hour ago
Hello (English through http://translate.google.com/ LOL
I turned on the LEDs in parallel.
Cut the track to the chips AMC7136.
changed to a new microcontroller tyni13
with a new firmware.
added a voltage divider 20k-5.1k
<_> – Long press – on/off
< . > – Short press – level up (moon – 2 – 3 mode)
< . . > – level down (Hi- 3 – 2 mode)
<_ _=""> – moon mode
<_ _=""> – Hi mode
<_ .=""> – ramping (for the 2 mode)
<. . . > – batery (1 flash – low, 5 flash – ok)
firmware
