Review: Ozark Trail 200L - 4AA Light from Wal-Mart
25 posts / 0 new
Old-Lumens
Old-Lumens's picture
Last seen: 2 years 1 month ago
Ozark Trail 200L
Reviewer's Overall Rating: ★★★☆☆
1
Summary:
Battery: Alkaline - Four AA
Switch: Side Switch - Pushbutton
Modes: On/Off
LED Type: Cree XB-D
Lens: Plastic
Tailstands: Yes
Price Payed: Gift - Costs about $19.00 In WalMart
Pros:
  • Aluminum Body is manufactured well. Smooth finish, Nice Ano. Sized well for hand held. Side Switch. Threads are smooth as silk.
Cons:
  • XB-D led is underpowered. Plastic lens. Plastic reflector. No heat sink. No Modes.
Features / Value: ★★☆☆
 Basic Flashlight. It turns on and turns off. No special features in this light. It's over priced compared to other lights with multiple modes.
Design / Build Quality: ★★★☆☆
The design on the outside is great. The body is appealing visually and manufactured well. The threads are as smooth as I have ever seen on a flashlight. The ano is good, but I imagine it's type II. The plastic reflector and plastic lens are probably better for an outdoors light, but I would prefer an aluminum reflector. The interior battery holder/switch assembly is innovative and well done. Where the light completely fails is the XB-D led with absolutely no heat sink at all.
11
2
3
4
5
6
7
8
The pictures should give you an idea of this light. It is not made to be improved upon. No heat sink, an XB-D and no way to mod it, makes it a no go for me.
Battery Life: ?????
I have no idea of the battery life. The Mfg states 3hrs 45min run time. With 6 AA Alkalines, I would think it might last a half hour to 45 minutes before it went dim.
Light Output: ★★☆☆
MFg states 200 Lumens. I would say that is fairly close. MFg states throw of 169m, but I can tell you it's throw dies out after 50 yards. Any farther than that, it can illuminate, but not well to distinguish anything clearly. It is a Thrower for sure. It has a very small spot and little spill. It throws a tight beam. The problem is the under powered XB-D can't put out enough to be an effective thrower.
Summary: ★★★☆☆
It seems like the designers took a lot of time to make a nice looking light and the outside body is sleek. The threads are just smooth as can be and the design of the battery holder/switch is neat. It seems like someone else came in and designed the led, reflector and tin plate heat sink. It ruins the light for me, as it is screams cheap and amateur. With the fact that it can't be modded, it's worthless to me, but in looking at it as a non-flashoholic, it's probably a step up from a maglite, since it is brighter than a mag and it is good looking.
1111
ISO100, F:2.7, Daylight WB, Shutter 1 second. Both the above and below shots.
2222
3333
Shutter Speed 1/15 second, to show the spot diameter better.
My PayPal address: oldlumens (insert the @ sign here) gmail.com
My YouTube Flashlight Video Channel
The BLF Modding Links Thread
http://imageshack.com/a/img922/1374/jQ2wdL.jpg
Edited by: sb56637 on 09/02/2017 - 11:43
T.H.Cone
T.H.Cone's picture
Last seen: 1 week 6 days ago
Thanks O-L.
fidem, prae caeteris omnibus praeter honestatem
Don't be confused, my Username has been changed from "Cone" to "T.H.Cone".  I'm still the same clown.
jacktheclipper
jacktheclipper's picture
Last seen: 1 day 22 hours ago
Thanks for taking one for the team .
BetweenRides
BetweenRides's picture
Thanks for the review, O-L. You saved me from spending $19. Laughing
garrybunk
garrybunk's picture
Last seen: 19 hours 50 min ago
Oh C'mon O-L!  You're giving up on modding it that easy?  That's not the Old-Lumens I know!  Thanks for the review though.
-Garry
My Bike Lights Thread, Optics (TIR) Comparison Beamshots, Diffusion Techniques
NOTE: Moving my photos from PhotoBucket to Flickr. PM me or post in the thread if you can’t see my images and need me to fix or send a gallery link. PhotoBucket images should remain visible until November 2018.
Old-Lumens
It was sent to me, by another member. The idea was to possibly mod it, but the way it's set up, I just don't see that it's worth it to mod. It's a shame, because my first thoughts, when looking at the light, were how nice it looked and how darned smooth the threads were. If they had just taken it one step further and left a little room for a heat sink or made a heat sink, it would be a great light to mod.
KuRUpTD
Last seen: 6 years 1 month ago
Thanks for the review.
Old-Lumens
Added beam shots in the review.
H-Man
It looks like you could make space for a heatsink in there. If the driver is single layer PCB, if the traces above the switch are that wide the whole way, you could cut the driver in half and solder it back together as a multi PCB driver to make some room for a heatsink. I have a razor saw (.011” thick blade) that could cut between that switch and the SMT components easily.
I do horrible things to electronics in an effort to get them to do what I want.
apt323
apt323's picture
Last seen: 1 month 1 week ago
+1 thanks for the review though.
texaspyro
What, no Nichia 219 in its future? Crying
alexasthoma
Last seen: 6 years 2 months ago
sb56637
sb56637's picture
Last seen: 7 hours 1 min ago
Thanks very much for the review! Frontpage’d and Sticky’d.
Rufusbduck
Rufusbduck's picture
Last seen: 1 year 3 months ago
Thanks for reviewing this light Justin. From the nice pictures it looks like Hman might have a point. There seems to be room around the reflector for a properly sized copper cap(1” or 1 1/4”) a shorter, smaller piece of pipe with the space between filled with shot/solder. Think “inverted” heat sink. If the battery holder can be modded or replace to 3s2p then the driver might be bipassed to a 105C. If not there are 5-mode 2-cell drivers that should work with the 6-8.4V of 6 nimh cells. If you really like the host, a way can be found to mod it but the cost will likely go up with a new lens, reflector, and copper. I’ll mod anything if it’s free but might not buy this if it’s too much of a pain.
Scott
Old-Lumens
H-Man wrote:
It looks like you could make space for a heatsink in there. If the driver is single layer PCB, if the traces above the switch are that wide the whole way, you could cut the driver in half and solder it back together as a multi PCB driver to make some room for a heatsink. I have a razor saw (.011" thick blade) that could cut between that switch and the SMT components easily.
I believe you could make it two part and shove one part inside the hollow. To me it's just not worth the effort, when there are so many lights out there that lend themselves to modding.
LEDAdd1ct
Was going to recommend this to a colleague.
But no heatsink?
Big thumbs down.
comfychair
comfychair's picture
Last seen: 2 years 8 months ago
For a light that's used for normal flashlight type runtimes, a heatsink that just adds a big dumb mass inside to store up heat is pretty useless. What matters is if it can shed the heat as fast as it generates it - which this light is capable of, with some tweaks, without filling the insides full of copper.
The flimsy aluminum plate needs to be swapped for a 1/8" copper plate, and whatever star of your choice bonded on top. The heat transfer on this light is decent, for two reasons. One, the plate under the star is clamped down tight between the head and battery tube, which is a whole lot better thermal path than anything P60 based. And two, the outer surface of the body, where that heat will ultimately have to jump the gap to the air (or your hand), is probably double the surface area of a typical 1x18650 light. Is it now pointless to play with P60/18650 lights, too?
The only potential issue I see is possibly the driver board, though I would probably take the easy way out and bypass it altogether with a jumper wire. Oh, that and the $20 price tag... but if you already have one (I do, haven't cut it up yet), why not? (and then you can stick the leftover XB-D in a Mag Solitaire or something!) Tongue Out
blueboo
Last seen: 5 years 2 months ago
But no heatsink?
Big thumbs down.
Online source for LED Lights including led strips, Home & Kitchen Lighting, Commercial Lighting & Flexible LED S
mikekoz
Last seen: 4 years 6 months ago
I disagree with most of this review. Heat sink or no heat sink, this has been one of the best budget lights I have ever purchased. I have used it almost daily around the house for the past year or so I have had it, and it has worked flawlessly. 200 lumens is a good amount of output for just general use and it has never got hot at all while I was using it. I even did a runtime test on it a while back and the light just got lukewarm during the 4-5 hours it was on. I use NIMH cells in in exclusively. The one test I did was with Energizer Recharge 2300 mAh cells and it ran for about 3 hours before any noticable reduction in brightness. I kept another light near me that was also rated at 200 lumens to compare while I was testing. Ozark Trail just released several new models at my local Walmart also, including a 500 lumen 2 mode version which I picked up. It is even better than this light, but I will save that for another thread!! ;p).
garrybunk
garrybunk's picture
Welcome to BLF.  Thanks for your input.
-Garry
sedstar
when i bought this? the 200 ozarks were going on the clearance rack (with hardly any markdown, but thats another thing) and were being replaced with the 250s… which is what i got, the 250
exact same light, everything pro or con about the 00, applies to this 250. Maybe just the same 200 light, with a 250 graphic on it, lol… (i dont have a meter, or the 200 version to do so much as a side by side)
for the AVERAGE consumer? i’m gonna say its a decent light for the average consumer. I also own the 500 ozark trail… which is a xml light.
With enough black coffee and cigarettes? all things are possible…
I am currently still shipping… REAL GENUINE CREE xp-g emitters, the classic… brace yourself? as low as 20 cents apiece!! Check out the SALES THREAD, everyone is happy… then PM me
SALES THREAD:
http://budgetlightforum.com/node/52528
if you are into reloading? this is my site… I inherited the remains of what was once arguably the best reloading site on the internet… its the “BLF” of reloading sites…
http://reloadbench.freeforums.net/
if you think night vision would be cool? It IS… this site i am a member of, and its basically the “BLF” of home made scratch-built digital night vision. They are at the leading forefront of advanced DIY for digital night vision, and thats gun mounted or handheld… builds rival and exceed commercial offerings…
http://nightvisionforumuk.com/
zerodish
Last seen: 4 days 21 hours ago
I bought the 6 cell model and I’m unable to unscrew the top of the light. Rechargable batteries are very tight and it’s only a matter of time before I damage the threads beating them out.
ImA4Wheelr
Last seen: 2 days 23 hours ago
Been wondering about that light for while now. Thanks for the review O-L.
mikekoz
The 250 lumen model, unlike the 200, is a dual mode light. It has a high and low, as well as the 500 lumen model.
sbslider
sbslider's picture
Last seen: 5 hours 55 min ago
trying to figure out why a nothing special review like this is a sticky????
PocketSammich wrote: I don’t need this, but I want it. Please sign me up.
