Search
I have an issue with the search.
Loading, Loading… nothing else.
I have to use the “advanced search” to get the search to work.
Any suggestions?
Hi Infinite,
I just tested the search system, and it appears to be working fine for me.
Quite a few users have found that Adblock software also blocks the Google search results. So if you are running Adblock you might try disabling it.
Another tip: We use two search systems here on BLF. The first one is through Google. The second stage search is at the page you screenshotted. You can search again from there and get different results from our own onboard search engine.
Hey sb56637,
That’s it. I miss the forest for the trees. My Ghostery Extension is blocking all Google Activities….including the “Google Search”….
Thanks.
Sure thing, glad you fixed it.
