Another Black 1D Mag Mod - Or, hey everybody, I've got a Woodie. It's Finished, beam shots are up
21 posts / 0 new
Old-Lumens
Old-Lumens's picture
Last seen: 3 years 3 months ago
When I said Woodie, where did your mind go? Huh?
Mine went to the old cars with the wood on the sides - A Woodie, not a Woody.
 I forgot the Song for the thread
I'm in this old style phase, where I want to create stuff that reminds me of the old hot rods and old cars of yesteryear. I love wood and I used to refinish old furniture as a hobby. I have wanted to make a Maglite with wood on the body, but it's only been a thought, since I know I don't have a wood lathe to turn one out.
I finally decided to try one with veneer. It's not like making one on a lathe, but it's the closest I will get and it might just be something others will want to try.
wo1
I started with a basic 1D Maglite.
wo2
The tail cap switch will have an abalone button. I think it will go with the wood on the body.
I bought a small piece of Burl Walnut from Joe Woodworker aka veneersupplies.com
wo3
I love the look of Burl, but it's hard to work with, especially when you want to roll it onto something like a flashlight, so I bought some Super Soft 2, which is a veneer softener. I did not buy a veneer knife, as I already was at my spending limit for this light. I probably should have bought one.
This is still a work in progress and I have managed to make a first attempt. So far, it's probably doable, but I have to learn some of the ins and outs of veneer yet. I cut my piece with a straight edge and an exacto knife, but I can see where the veneer knife would be better. I have also soaked it in the softener and tried to roll it onto the light body. Well, that will take some more thought and time. What I finally figured out was that I had to roll it tight enough to place it inside the body and let it form in there, so the two sides of the seam would lay down. If it's formed smaller than the OD you want, it can be opened up a hair and slid on.
wo4
I don't have a lot of photos of the process. You know how you get working on something and don't or can't stop to take photos, but I will develop a process and do a video of it, if anyone is interested... or even if they are not, LOL.
It's not ready to put on yet. Once the wood is soaked with the softener, it takes about 5 days for it to dry back out, so it will be a while till I can finish this mod. I plan on covering the body with epoxy, sliding on the burl and then covering the burl with epoxy and possibly using a plastic wrap to hold it in place, till it hardens. Then I can sand it smooth, give another coat and finish off with a clear coat acrylic.
Time will tell, - later gator.
Progress has been made. The burl is now applied to the light with 2 part epoxy and it will sit another 24 hours till I work on the outside. Sanding and finishing is next.
bon1
zw1
Well, I've managed to do a little more. I coated the outside with Epoxy and after 24 hours, I sanded it all back down to mostly bare wood. Now I have sprayed Polyurethene finish on it. It's Satin Poly and I am trying to do it so that there will be texture to it. Hopefully it will grip a little that way. These are just the first three coats and it's probably going to be a week or longer before it's done. 72 hours till I touch it again and then the same process all over again.
zw2
Here's a couple of teasers of the whole light. I still have plenty to do and wood finish sometimes takes a long time to do it right, or to do it half right, LOL.
zw3
Not much left to show. I used my normal Aluminum heat sink. Direct Drive. A deep reflector and an XM-L U2 1A led.
za1
za2
za3
I can say that this was the most challenging mod I have done. Trying to use wood veneer is harder than it looks. I wasted most of the sheet I had trying to do it. Never again, at least not with Walnut Burl. Probably never again at all, so this might just be a one of a kind.
I will do beam shots tonight.
My PayPal address: oldlumens (insert the @ sign here) gmail.com
My YouTube Flashlight Video Channel
The BLF Modding Links Thread
http://imageshack.com/a/img922/1374/jQ2wdL.jpg
Edited by: Old-Lumens on 11/24/2012 - 21:47
rikr
rikr's picture
Last seen: 1 month 6 days ago
OL, That is going to look so amazing I can’t wait to see it when it’s completed!!! Great work!!
 New Collection / Old Collection
Lumatic
Lumatic's picture
Last seen: 6 years 3 months ago
Lightagra. Shocked
“When I buy something in bulk you should prolly buy at least one too.”…..“They that have light shall rule the night.”…..“Flashaholics feel depressed without darkness.”…….“I’m a very terminal torchaholic. My entire life just flashed before my eyes
Rufusbduck
Rufusbduck's picture
Last seen: 1 year 2 weeks ago
Great idea!
Scott
ma_sha1
ma_sha1's picture
Last seen: 3 years 9 months ago
Nice! Love the burl
texaspyro
Last seen: 9 months 1 day ago
Try West Marine epoxy with their Special Coating Hardener. The Special Coating Hardener forms a very smooth surface as it sets (hint, add a couple drops of silicone oil a.k.a. model race car shock oil to the mix… it helps break up any outgassing bubbles). BTW, that hardener is rather pricey.
I had a small piece (0.75 × 3 inch) of dashboard trim break on Der Mercedes. The dealer wanted $450 for it! I bought a few square inches of walnut burl for a buck, got a free sample pouch of stain, and used the West Marine stuff to coat it. Nobody can tell the difference.
Old-Lumens
texaspyro wrote:
Try West Marine epoxy with their Special Coating Hardener. The Special Coating Hardener forms a very smooth surface as it sets (hint, add a couple drops of silicone oil a.k.a. model race car shock oil to the mix... it helps break up any outgassing bubbles). BTW, that hardener is rather pricey. I had a small piece (0.75 x 3 inch) of dashboard trim break on Der Mercedes. The dealer wanted $450 for it! I bought a few square inches of walnut burl for a buck, got a free sample pouch of stain, and used the West Marine stuff to coat it. Nobody can tell the difference.
Great Planes two part epoxy (30 minute) seems to work well. I have used it as a coating on many wood projects... and it's in my budget.
Old-Lumens
Updated OP with one photo. The burl is now epoxied on the body.
Ledsmoke
Ledsmoke's picture
Last seen: 11 months 3 weeks ago
You certainly have a wonderful imagination O-L. That is half the reason I (almost) never miss your posts. The other half is the wonderful workmanship. Looking forward to hearing more about how this comes together. Keep it up Smile
~ Ledsmoke ~
Dutch humor:
[quote=djozz]
 I do not think that the BLF-community ben
gords1001
gords1001's picture
Last seen: 1 year 9 months ago
I’ve got a woody…. :8)
MRsDNF
MRsDNF's picture
Last seen: 20 hours 6 min ago
Nice work. I have used this product in the past http://www.veneersupplies.com/products/Super-Soft-2-Veneer-Softener-Conditioner.html and unfortunately after 10 days my darling wife feels that it may stay soft permanently. Is my wife the problem or the product? Keep it up. Your flashlight work that is. Cheers.
Old-Lumens
All traces of the softener are gone after 4-5 days. See a doctor.
Pavithra_uk
Pavithra_uk's picture
Last seen: 10 months 3 weeks ago
awesome look
Old-Lumens
New photos in the OP.
TexasLumens
TexasLumens's picture
Dang your hide Justin!!! You gotta quit this. Smile
I just spent $*%&^%%*^%^&%^% !$$$$$$$ On a new lathe and what do you do!!!! OK… you can’t put this up for sal for at least two weeks!!! I gotta RECOVER!!!.
BEAUTIFUL!!!!! Dan.
Texas Lumens Website… http://www.texaslumens.com
WE LIVE IN THE LAND OF THE FREE ONLY BECAUSE OF THE BRAVE!
Old-Lumens
Finally done! It takes a lot of time to finish wood. Each coat sat for 3 days before going to the next.
Photos in the bottom of the OP.
I will do beam shots tonight. I am hoping it will be a little bit of a thrower, but time will tell.
shhh
shhh's picture
Last seen: 1 month 13 hours ago
This came out pretty good.
Of all things I figured you would have cut the body up and drilled out a wooden dowel rod
and press fit it all together.
MRsDNF
MRsDNF's picture
Old-Lumens. That light looks orsm. The veneer, polished bezel and tailcap really set it of.  Thanks for sharing.
Old-Lumens
ISO 100, Daylight WB, F:2.7, 1 Second
w1
w2
w3
ISO 100, Daylight WB, F:2.7, 2 Seconds
w4
It throws fairly well and it's very bright. I thinl some of that is DD with the resistance mods.
kicken_bright
I have been looking for a good smooth reflector for my mags, especially one that would work well with a 20mm star. Mind sharing your source? is it this one perhaps…
http://www.fasttech.com/products/1617/10001275/1208513-plastic-smooth-re...
Old-Lumens
[quote=kicken_bright]I have been looking for a good smooth reflector for my mags, especially one that would work well with a 20mm star. Mind sharing your source? is it this one perhaps... http://www.fasttech.com/products/1617/10001275/1208513-plastic-smooth-reflector-for-cree-xr-e-emitters[/quote]
I use these two
http://www.cnqualitygoods.com/goods.php?id=1429
http://www.cnqualitygoods.com/goods.php?id=1372
One is shallow, one is deep. Both of them need to be "fitted" to a Maglite. The stock LED "D" Maglite reflector is good for a thrower.
