SMO reflector for Romisen RC G2?
10 posts / 0 new
Hektor
Last seen: 6 years 10 months ago
Hello
I'm modding my RC G2 light (soon (1-2weeks) will post a thread with beamshoots) and the last thing I want to mod it the reflector. The stock one is an OP and I'd like to try the SMO.
Dimensions are 24.85mm (0.978in) * 19.90mm (0.783in).
Does anyone know if there's any SMO reflector of these dimensions avaiable?
Thanks
Don
Don's picture
Last seen: 2 years 7 months ago
The dimensions are not far from a typical P60 reflector. With steady hands and a grinder they might be persuaded to fit.
This one might do well, but it is OP
http://www.kaidomain.com/ProductDetails.aspx?ProductId=1864
If you ground the base off this one it'll probably fit.
http://www.kaidomain.com/ProductDetails.aspx?ProductId=10969
A typical P60 one
http://www.kaidomain.com/ProductDetails.aspx?ProductId=1843
The numbers from my light tests are always to be found here.
https://spreadsheets.google.com/ccc?key=0ApkFM37n_QnRdDU5MDNzOURjYllmZHI...
Hektor
Thanks for response!
I think I will stay witht he stock reflector...I'm not sure it they will fit,even after some sawing...
arenat
Last seen: 5 months 4 days ago
I did the KD's one and don't worth the hassle , that solid aluminum ring in the bottom is very hard to sand down even with a machine...the result is not noticeable at all, the stock has enough depth to work fine
Hektor
Thank you very much for sharing these info!
arenat
 XP-G R4            XR-E R2                   XM-L T6 (ruined but working )
Soon I'll post some details and beamshoots, the cells are in the charger...
Hektor
Cool! I can't wait... I have in mine Q5 and soon will put the R5 with some good driver!
Hektor
I'm still waiting Big Smile
Piers
Last seen: 7 months 1 week ago
I was looking for reflectors earlier and was sure I'd remembered some about that side. I just looked again but sadly they are all OP on KD
arenat
http://budgetlightforum.cz.cc/node/1559
