Help, I need a Flashlight Modding Intervention! Maglite Solitaire revisited.
14 posts / 0 new
Old-Lumens
Old-Lumens's picture
Last seen: 3 years 3 months ago
I can't put these damned things down!
I needed to mod another Solitaire, for a single 10440 light, but I am concerned about how hot they get. The last two I did were made wrong. I let the light work as normal, where the head turns up for on and down for off. That leaves the star all by itself and it gets so hot, so fast, that it ruins the led.
So, I'm off on another quest, to get more out of less, or nothing at all. An effort in futility and minutia.
sa1
Gray Solitaire, Nichia 219, TIR optic.
sa2
Had to sand the outer ring of the optic, to get it to fit in the head. Hell, I can't even see it.
sa3
The "pill", ends up being a flat piece of copper sheet, a piece of brass tube and a hand cut copper round for the positive terminal.  I mean, there's nothing here that's over 10mm in diameter and it's so small, it's almost impossible to handle it with my hands. At least the light will now turn on by tightening the head down, causing the heat to go into the body (hopefully).
sa6
The finished pill, wired up and ready to go.
sa4
sa5
Remove the ano on the top of the body and it's ready to put together.
sa7
I ended up using AA to hold the optic to the star. It's so tight and so small, alignment itself may cause the dome to come off the led. Better off assembled and held together this way.
sa8
Finished.  The stack is tall enough that the head can't screw down all the way, so I made a quick copper spacer ring.
Beam Shots - I used 3XAAA Alkalines to test the light.
sb1
sb2
It's bright! It also gets hot FAST. It is a WOW light, but after 30 seconds it's warm and after a minute, it's time to turn it off.
Useful? Hell no!
Fun? WOW.
My PayPal address: oldlumens (insert the @ sign here) gmail.com
My YouTube Flashlight Video Channel
The BLF Modding Links Thread
http://imageshack.com/a/img922/1374/jQ2wdL.jpg
Edited by: Old-Lumens on 11/25/2012 - 22:06
jacktheclipper
jacktheclipper's picture
Last seen: 6 hours 26 min ago
Pretty damned cool .
You've been on a real modding streak lately , Justin !
Keep 'em comin' .
JohnnyMac
JohnnyMac's picture
Last seen: 2 years 4 months ago
Heheheh...you and your direct drive mods. I love it! I'm still waiting for an order from Ric to arrive with those little TIR lenses in it. Once that arrives I start playing. Wink You are an inspiration!
scaru
scaru's picture
Nice work, I certainly want a V2 of mine. Wink For anyone on the edge mine was amazingly bright.
Hill
Hill's picture
Last seen: 1 year 1 month ago
I gave up on trying to do solitaire mods for the same reasons you discovered:
1.  Too damn small to work with
2.  Virtually no room for adequate heatsinking
But, I completely understand your fascination (obsession?) with trying to get the little sucker modded.  I have several carcasses of stock and cut down solitaires in my junk box collecting dust.  I went through my own fascination with small (AAA and smaller) sized EDC's, looking for the "perfect" keychain light.  I have since had several iterations on my keys, from my own creations to off the shelf ones.  I am currently using a TrustFire MINI-01 and simply LOVE it.  It is powered by 1 x 16340 IMR and the WOW factor for a light this small is great.  Runtimes are short on high, but I typically only need a few short bursts now and then.  I modded the stock XML to a neutral tint (5000K) which gives better color rending and easier on the eyes IMHO.
I recall when the XPE's first came out, a CPF member modded a solitaire and sold it for $65!  Not bad for a simple emitter/optic swap (no driver, just DD with 1 x 14440).  Won't see that anymore.  For that price, one could pick up a 6 x XML powerhouse.
My lights here and here
Rufusbduck
Rufusbduck's picture
Last seen: 1 year 2 weeks ago
Was?
Scott
Old-Lumens
Rufusbduck wrote:
Was?
It was amazingly bright right up to the solder melting and the led sliding off the star.Surprised
That's when I decided to try V2 and have it sit on the body, for heat problems, but no matter what, it is a 30 second wonder. Not useful, just the brightest Solitaire around.
Pinetreebbs
Pinetreebbs's picture
Last seen: 1 month 1 week ago
Perfect, like a v8 in a VW Shocked Not something you want to drive very far, but will get you to the end of the block in an instant.
Rufusbduck
O.L., could you tell me where you obtained the optic? This might be a useable light with a single or double stack of 7135’s or a qtc pill.
Edit Never mind, found your video thread.
Scott
TexasLumens
TexasLumens's picture
Justin, tell me the diameter & thickness of the base (yellow arrow) the diameter & height of the tube (purple arrow). If some made from solid aluminum or brass would be ok, I’ll make you some… I don’t think I have any copper rod.
Dan.
Edit…added Image…. We can do small!! Wink
Texas Lumens Website… http://www.texaslumens.com
WE LIVE IN THE LAND OF THE FREE ONLY BECAUSE OF THE BRAVE!
Old-Lumens
TexasLumens wrote:
Justin, tell me the diameter & thickness of the base (yellow arrow) the diameter & height of the tube (purple arrow). If some made from solid aluminum or brass would be ok, I'll make you some... I don't think I have any copper rod. Dan. !http://www.positiveflow.com/lumens/justin.jpg! Edit...added Image.... We can do small!! Wink !http://www.positiveflow.com/lumens/smallstuff.jpg![/quote] Dan,
If I could only remember.Undecided I didn't write down the dimensions and off the top of my head, I just don't know.
Actually, I would not recommend doing this mod again. Yes it's bright as all get out, but it gets way too hot, way too fast. Also there's just no real room for anything. I think it was one of those "I just had to do one", kind of mods, but I don't plan on doing any more of these. (subject to change).
TexasLumens
Old-Lumens wrote:
TexasLumens wrote:
Justin, tell me the diameter & thickness of the base (yellow arrow) the diameter & height of the tube (purple arrow). If some made from solid aluminum or brass would be ok, I’ll make you some… I don’t think I have any copper rod. Dan. Edit…added Image…. We can do small!! Wink !http://www.positiveflow.com/lumens/smallstuff.jpg!
Dan,
If I could only remember.Undecided I didn’t write down the dimensions and off the top of my head, I just don’t know.
Actually, I would not recommend doing this mod again. Yes it’s bright as all get out, but it gets way too hot, way too fast. Also there’s just no real room for anything. I think it was one of those “I just had to do one”, kind of mods, but I don’t plan on doing any more of these. (subject to change).
That sounds like me!! OH… “I’ll remember!!” Yeah, right…. TILL I BLINK! Ha!
I might do one and just try using some grooves to create more surface area. I have found over time that you can have less contact area between the pill and case….IF you increase the surface area with some grooves or as one I do… “dots” machined into the pill surface. Sometimes though… you just can’t get rid of enough heat when they are so small….Good mod though!!!! I enjoyed seeing what you were doing…as always!! Thanks for sharing. Dan.
Rufusbduck
Here is a link to CPF Ma sha1’s solitaire thread using a small resistor to control current/heat. He uses Lisa optics or ground down(method NOT reccommended) asperics for focus.
Scott
Rufusbduck
Another item of interest. A 3/8” copper pipe bushing (fits 1/2” fittings) is an almost perfect fit over the head of a Solitaire. Might do well as an external sink/collar.
Scott
