Will this RadioShack charger, charge eneloops?
I just purchased a Fenix LD41… I already have this charger that came with 1.2v 2100 mAh batteries but was looking to buy these batteries… Amazon.com
Is my charger capable of charging these?
http://i.imgur.com/aXfPs.jpg
http://i.imgur.com/FDudK.jpg
Thank you
Yes.
Thank you for the reply
Could you recommend better eneloop batteries that will work with my charger?
It chargers in pairs, that’s not good. Get a better one.
The flashlight I will use takes 4x AA… So I will be charging 4 at a time always…
Those Eneloop are fine. (2000 mAh)
You could try the Enloop XXX (2500 mAh)…more expensive.
It’s up to you.
Thank you…
One more question. Regular non-rechargable batteries are 1.5v and rechargeables are 1.2v… Will using eneloops @ 1.2v reduce the output noticeably?
No. The output with NiMh will stay constant until they are almost drained, whereas alkalines will slowly dim as they run down.
Thank you Ouchy. I will buy those and use the charger I already own. I appreciate your help.
Depends. It will quite likely increase the output, since NiMH maintains its voltage much better under current draw, as well as maintaining a more stable voltage as it discharges (below half-full or so for each, NiMH actually has higher voltage than alkaline!).
