The 90 Degree Angled Head Maglite - or - Yes I am certifiably crazy! - It's Finished and ready to go!
43 posts / 0 new
Old-Lumens
Old-Lumens's picture
Last seen: 3 years 3 months ago
What to do with another plain black 2AA Maglite? I've been thinking that myself and I always wanted to make an angled head light. It just seemed too hard to do, so I never did try it.
Aw, the hell with it... Here goes...
901
So, I take an unsuspecting Maglite 2AA and render it harmless, so it can't try to bit me when it realizes what the heck I'm going to do with it.
902
Oh, the Screams! I had to wear earplugs, but I did make the cut. I cut the body at a 45 degree angle. Two 45's make a 90 don't they? Then I figured out that it was going to be very hard to hold this thing together. I held up the two pieces and they just fell apart, Hmmmm.
I got out my trusty copper box, but nothing fits. It's either too big or too small around to go inside the Maglite. I had to cut up some copper pipe, split it and cut some off, so it would go small enough to fit. Then I had to fit it into each end of the body and hold the whole derned thing together with some different kinds of vise grips, till I could hold it still long enough to dribble some solder in the hole. What a mess.
903
Now, that's not a nice solder job, but up inside, there's a bunch of solder, so hopefully it will hold till I get to the point of making it permanent. Then I thought, well Duh, how do I make the positive terminal at both ends? I have to contact the battery and then I have to contact the pill with the XM-L T6 on it.
I found some plastic bushings that just fit the bill to a "T". I will use them inside the copper and finagle some contacts.
904
On the end that the head screws on, I have to make something with a spring, so that as the head screws to make and break the negative contact, the positive stays touching. Well, the spring should do that, once I get it to stay in place and center it.
905
On the battery side, a simple copper contact should work. A wire will be soldered to it and to the spring at the other end.
So, what is this thing going to look like?
906
I already know it's going to work, or I wouldn't post it.Wink
Well, famous last words, but I'm fairly confident with how it's gone so far...
Well, let's try to finish this crazy light up, shall we?
p1
The pill is similar to any other one I have done, but it has an XM-L on it and the positive terminal is much shorter since I am using a spring in the body.
p2
Just a plastic washer and a copper contact work for the + terminal.
tir1
The TIR is a 15 degree one, from CNQG.
90s1
Here's the spring showing, in the body. The top of the body has been opened up a little and the ano is removed, so it will make contact with the copper pill. So you have the negative ring and the positive spring.
bod1
I did use some JB Weld between the two body halves and the copper insert, but I don't believe that will hold, so I pinned them with 1/8" brass rod, right thru the body, copper and plastic inserts. One is under the "O" ring, so the head will cover it, but the other will show.
do1
Here it is. A Maglite 1x14500, 90 degree light. Notice the copper ring in front of the tail cap. I have issues getting the right length for the 14500, since the dimensions seem to be different from Mfg to Mfg and protected to unprotected. I used a Saft 14500 Lithium battery to test fit this and I needed the copper ring so that the tail cap would not crush the battery. Hopefully, with the ring taken off, a 14500 unprotected will fit better and will only need a thin magnet to fit.
Now, this is a great light and it's very bright, but how the hell can you tail stand it? You can't...
Not without this...
cop1
Now the light can tail stand on the shelf, with the rest of the collection!
done1
done2
I really like how this light came out and the foot base really sets it apart from the others. It's a one of a kind.
My PayPal address: oldlumens (insert the @ sign here) gmail.com
My YouTube Flashlight Video Channel
The BLF Modding Links Thread
http://imageshack.com/a/img922/1374/jQ2wdL.jpg
Edited by: sb56637 on 08/26/2014 - 17:29
ryansoh3
ryansoh3's picture
Last seen: 2 weeks 1 day ago
You did the impossible! Shocked
Great job man, appreciate your work.
BLF ≠ B-grade Flashlight Forum
Rufusbduck
Rufusbduck's picture
Last seen: 1 year 2 weeks ago
“I already know it’s going to work, or I wouldn’t post it.”
Don’t think I’ve read that before. The hunch back gets a Mini Me.
Scott
MRsDNF
MRsDNF's picture
Last seen: 8 hours 35 min ago
How are you mounting the magnet, on or in the tailcap?
Lumatic
Lumatic's picture
Last seen: 6 years 3 months ago
MAGnificent!!!!!!!!!………………… 8) Shocked
“When I buy something in bulk you should prolly buy at least one too.”…..“They that have light shall rule the night.”…..“Flashaholics feel depressed without darkness.”…….“I’m a very terminal torchaholic. My entire life just flashed before my eyes
borstar_micke
Last seen: 2 years 5 months ago
Beautiful work as always!
scaru
scaru's picture
Nice! A while back I had been trying to do the same thing so I am waiting to see how this turns out. Big Smile
MRsDNF
MRsDNF's picture
You know I'm just playing with ya. Sealed
jacktheclipper
jacktheclipper's picture
Last seen: 1 day 17 hours ago
ruffles
ruffles's picture
Last seen: 11 hours 55 sec ago
All I can say is… WOW!
Thanks as always for sharing your creative madness.
Pinetreebbs
Pinetreebbs's picture
Last seen: 1 month 1 week ago
Looks like a right turn on the well lighted road to creativity.
Slim Pickens
Slim Pickens's picture
Last seen: 2 days 12 hours ago
So cool
Old-Lumens
Just playin wid me? For shame, Laughing
I finished the pill, but it's late, so I didn't take photos. Maybe Wednesday.
sb56637
sb56637's picture
Last seen: 2 hours 21 min ago
Ha! Very nice. I think you just won our (not yet existent) Most Unique BLF Project of the Year Award. Thanks for sharing!
Frontpage’d and Sticky’d.
Old-Lumens
It's Finished!! Beam Shots tonight, when I come home from work.
sb- thanks, I really like this light and the base it sits on. It's one of only a couple lights I have ever really felt proud of.
jacktheclipper
That foot needs some toes cut into it ...
Laughing
Cool little mod , Justin
Keep 'em comin' .
And thanks for all of the giveaways !
ILIKEFLASHLIGHTS
ILIKEFLASHLIGHTS's picture
Great job!
Slim Pickens
If one were so inclined, could they simply swap out the provided head for another that has been Match-modded to take a P60 pill?
Imagine the combinations…this light could be adapted and lego’d to your heart’s content Love
If one were so inclined?
JohnnyMac
JohnnyMac's picture
Last seen: 2 years 4 months ago
Great work, Justin!  With the base on it it reminds me of a little one legged scuba diver with a mask and flipper. LOL!
TexasLumens
TexasLumens's picture
Justin, I am changing your user name to “Crazy Lumens” !
You may be crazy but you are on heck of a modder!!!!
Beautiful, unique work AS ALWAYS!!! and AS ALWAYS….. VERY MUCH APPRECIATED!
Thanks!
Dan.
Texas Lumens Website… http://www.texaslumens.com
WE LIVE IN THE LAND OF THE FREE ONLY BECAUSE OF THE BRAVE!
Hill
Hill's picture
Last seen: 1 year 1 month ago
Nicely done!
Maybe you should shoot Maglite an email and photo of your work.  It could give them some ideas, or better yet, perhaps they will send you a free complimentary light for your innovation!
My lights here and here
dthrckt
dthrckt's picture
Last seen: 6 months 6 days ago
Very nice work.
Reminds me of an GI light…
which makes me think, a clip would make it even handier.
____________________
Girls can shoot!
gords1001
gords1001's picture
Last seen: 1 year 9 months ago
I really hope you keep this light for yourself, you turn out so many that go, this one should have pride of place.
Nice job o-l, I really like this one.
Old-Lumens
dthrckt wrote:
Very nice work. Reminds me of an GI light... which makes me think, a clip would make it even handier.
Yep, GI light or Boy Scout light. I remember both of those and that's what got me to thinking.Wink
NightCrawl
Last seen: 4 years 4 days ago
That foot..
Old-Lumens
gords1001 wrote:
I really hope you keep this light for yourself, you turn out so many that go, this one should have pride of place. Nice job o-l, I really like this one.
I thought about that... for about one minute and then I realized that it would not do me any good sitting on my shelf. Might as well sit on someone else's shelf, LOL.
It's already destined to go to a new owner. Another holiday gift heading out tomorrow, on it's trip to the Southern Hemisphere.
Old-Lumens
NightCrawl wrote:
That foot..
You seriously need help.Tongue Out
NightCrawl
Judging from the folks here I was sure I already was in some kind of insane asylum..
Old-Lumens
You areWink
MRsDNF
MRsDNF's picture
Ok, you win. Copper coloured magnet. You could make this a multi purpose magnet by sticking a magnetised suction cup on it to stick on any flat surface.
Another terrific job and yes you should give yourself a pat on the back. well done.Sealed
scheven_architect
Last seen: 2 years 3 months ago
Now you only need one of these bad boys:
